Question about Lanzar Vibe 235 Car Audio Amplifier
I have a lanzar mxa232 there is a L & R low. I do not have that on my head unit. How do I tie them in?
  • 631 Answers
You would need a Line Output Converter (LOC) to convert the speaker level of the head unit to preamp level.
The amp also has speaker level inputs but the LOC will probably produce better results.
Let me know if you have any other questions.
Posted on Aug 27, 2008
I have a lanzar vector VCT-2210 2000 watt amp hooked up to two menace 1300 watt subs. when i turn the volume up on the head unit the amp goes into protection mode. i checked all my wiring and it seems all...
Things to check: Is the wire between the amp and the subs heavy enough to pass 167 amps? 2000 * 12 = 166.66666 amps. Max volts on the subs are 10 volts....close enough. Are you sure you're using the line out on the head unit? You may be over driving the amp if it's anything else.If the head unit doesn't have line out connectors then you'll need to get an attenuator for each channel. Do you have caps on the 12 v power in wires? They'll keep the headlights from dimming and the alternator will last longer if you do.
Apr 09, 2014 | Lanzar VCT2210 Vector Series 2 Channel...
This is my second lanzar 1500 wat amp in 4 months lights up but no sound
I suggest you double check all connections and cables.
A thumbs up would be greatly appreciated if this answer is helpful to you. Lanzar
Nov 26, 2013 | Lanzar Car Audio & Video
Prot
not really a question here...
May 10, 2011 | Lanzar MXA232 Car Audio Amplifier
My mxa232 starts smoking when powered
There is some internal problem, not easily fixed by you. I would suggest taking it into a car stereo shop and having a professional look at it.
Mar 08, 2011 | Lanzar GPS
My amp lights aren't all coming on. the green power light is on. but not the blue light behind the lanzar logo. the light turned on earlier when i checked it to see if it worked.. and now. 3 hours later,...
Make sure that the remote switch is activated by the head unit so that the relay trips to contact making the amp come on.
SO make sure you have the auxillary power to switch on, use a multimeter to check the + 12 volt when the head unit is switched.
If there is power and still the amp is not working check onthe main fuse or the relay drive inthe amplifier.
Sep 16, 2010 | Lanzar Car Audio & Video
Lanzar subwoffer speaker keeps flaping when volune is raised
x over frequency sounds wrong , level match head unit to amp , see amps gain , turn it all the way counterclock wise first then check , check surround on sub .
Dec 22, 2009 | Car Audio & Video
I need help?
id check remote signal with a test light and also if there is a High pass or Low pass filter either on the head unit's settings or the Amp's controls
if your amp or head unit has a High pass filter setting enabled that would explain no bass being sent to your speakers,
if you are using a separate crossover to send the bass signal check those settings too..
if all else fails
test another amp on your system (if it works that would discard problems with the rest of the system's output)
Jun 23, 2009 | Lanzar VIBE266 Car Audio Amplifier
Annoying thump from two 15" kicker comps powered by a lanzar vibe 266 amp
It sounds like it may be oscillating. This can be caused by a broken ground in the signal line. You need to check the RCA shield on the head unit.You'll need an ohm meter. The following page has more details. If the head unit isn't damaged, the shield ground could be open in the amplifier.
Temporary Shield Repair
Apr 05, 2008 | Lanzar VIBE266 Car Audio Amplifier
Lanzar vibe 230 400 watts amp
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 27, 2008 | Lanzar Vibe 235 Car Audio Amplifier
Lanzar Vibe 235 Car Audio Amplifier Logo
43 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
