Question about D-Link AirPlus DI-614+ Wireless Router
D-link 614+ will not connect with Qwest M1000 modem
Idiots at Qwest told me my Dlink router would work with their modem. System error message says "not supported." What to do?
  • 35 Answers
Well what everybody really doesnt know is that if Qwest provided you with a modem named Actiontech that modem has the same ip address of router so just change routers ip address to 172.16.0.1 and subnet mask to 255.255.0.0 and the problem should be solved.Im a product specialist for dlink.
Posted on Aug 27, 2008
Perfect!!!!!
Posted on May 18, 2009
Where can I get a quest m1000 mnual for a quest m1000 modem
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Nov 11, 2014 | Actiontec M1000 Dsl Wifi Modem In Box W/...
I have a Qwest Modem - M1000. I bought a DIR601 router so my some could use his Kindle. When I try to access the internet, I get "modem cannot connect to DSL line."
Let's see if I can help you.
Begin by turning on your computer and your router
  • Open Internet Explorer;
  • Click on 'Tools';
  • Click on 'Internet Options';
  • Click on 'Connections';
  • Click on 'Setup'
  • Click on 'I want to set up my Internet connections manually . . .';
  • Click on 'Next';
  • Click on 'I connect through a local area network (LAN);
  • Clock on 'Next'
  • Click on 'Next' [This is not an error];
  • Click on 'No';
  • Clcik on 'Next';
  • Click on 'To connect to the Internet immediately . . .; and,
  • Click on 'Finish'.
That should have you online
All the best
Ben
May 24, 2011 | Computers & Internet
Trying to connect dir-615 to qwest modem pk5000z. Can you help? We have two computers hooked up to pk5000z.
It looks like the Qwest modem is a modem/wireless router. It's hard to set up a router through a router. It's easier to connect multiple devices with a switch or hub going through a router then a router through a router. Other then me trying to guess at the problem below is a link to Qwest's support page. They have an excellent support page with troubleshooters, manuals and guides. I would try there first because the support page is so good.
If you don't need the second router then please don't try to set it up.
May 19, 2011 | D-Link DIR-615 Wireless Router
How do I connect to a qwest dsl m1000 modem
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 20, 2010 | Linksys Wireless-G WRT54G Router
My router won't work with my Qwest modem.
Are you trying to set up the router.
You can do it manually without the CD.
When you connect the computer to the quest modem, does it work?
Then you need to connect the computer to the router ad the modem to the router.
Click Here for step by step by instructions
Feb 07, 2010 | D-Link Computers & Internet
I need instructions for a Linksys Wireless G router to work
Call your internet provider they will walk you thru the process.
Jun 18, 2009 | Linksys Wireless-G WRT54GS Router...
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Problem between my Qwest actiontec modem and D-link router
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
Dec 30, 2008 | D-Link DIR-625 (790069292637) Wireless...
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Dlink solutions
you just cleck dlink, then properties, then cleck advance check the computer internet
Jun 18, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link AirPlus DI-614+ Wireless Router Logo
526 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
