Question about Linksys Wireless-G WRT54GS Router (e125894)
Programm trasfer to my cpu?
I,can't seem to get my cd to start
  • 35 Answers
If it is a mac computer just configure router manually.Cd is just a guide through anyways.
Posted on Aug 27, 2008
Every thing i click on on my desktop starts then
I played around with W8 on an Asus notebook with a 1GHz CPU and found that each programme will open over the top of another.You could have many trying to run and causing the CPU to overload and freeze.
Waiting for the activity to slow from startup by observing the LED activity of the hard drive usually means all startup programmes have loaded and there is less draw on the CPU resources.Trying to access other software while startup is incomplete will compound sluggishness especially if the laptop is a netbook or has a low speed CPU.
If you experience the issue again please wait a few minutes before trying to access or cancel any programme to see if will work through any bottleneck created.
Sep 03, 2014 | Computers & Internet
CAPLE D1475
try removing power supply and then back on it will reset the CPU
May 26, 2014 | Dishwashers
2006 Avalon..6 CD Player displays Error code 4...what can be done!!!
It depends on what you are trying to use that gives you the code. Error Code 2006 with Outlook seems to arise when you try to sync with Outlook 2007 not running. Open Outlook 2007 and then try to sync.------------------------------------------------------------------------------------
motorola ecu programmer
Feb 21, 2013 | 2006 Toyota Avalon Touring
Commercial generator 20kv not working properly
Troubleshoot like this:
1 - With the generator control in Auto, jumper from terminal 3 to 4 on the control board. Generator should start without transfer switch doing anything. If it won't you have a bad controller board.
2 - If the Generator started, remove the jumper - controller is OK. Next go to the 1st transfer switch and find the remote start terminals. These will be the same wires that were connected to controller terminals 3 and 4 at the generator. Use your jumper wire to connect them and see if the generator starts, if not there is something wrong between the switch and the generator, probably a broken wire.
3 - Don't forget to check the other switch, the remote start terminals of the switches connect in parallel across controller terminals 3 and 4 so that either switch can start the generator.
4 - Each switch should have some sort of a test button/switch, power down as much of the building as you can, then run the test function of each switch one at a time. Don't stand directly in front of the switch while you do this.
Nov 20, 2008 | Electrical Supplies
Task Manager/CPU Usage
first thing scan ur pc..it may be infected by viruses
and check usage
Sep 30, 2008 | Microsoft Windows Xp Home Edition Sp2...
I have Camedia Master 4.1 which works fine on my XP computer, but I don't seem to be abl;e to install the program (from the CD) on my Windows Vista Home Premium computer. Can you help please? Thanks....
Put Camedia CD into CD slide.
Went to Start - All Programs - Accessories - Run
The Camedia programme was then loaded onto my Vista PC
Cheers, and no charge.
Michael,
Sep 10, 2008 | Computers & Internet
Aspire 5002 WLMi getting turnoff
There is a CD tool called "Ultimate Boot CD" which can be downloaded athttp://www.ultimatebootcd.com. On this CD there are quite a few toolsthat you can use to test your RAM, CPU, Hard Drive, etc.. for problems.Just boot up with this CD and select the corresponding testing programto use. Test each component until you find the component causing the issue.
Cause it seems something is overheating.. Probably the CPU.
Aug 18, 2008 | Acer Aspire 5002WLMi Notebook
Copying phone numbers from phone to computer
i have lost my cd which was provided with N72 set. how can i connect the phone with computer now for trasfereing phone numbers to computer
Aug 03, 2008 | Nokia N72 Cellular Phone
Linksys Wireless-G WRT54GS Router (e125894) Logo
16 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
