Question about Denon AVR-1802 Receiver
No sound with the front speakers
For an unknown reason, I don't get any sound from the front speakers anymore, the only one speaker that is working is the central one...
If I switch my front speaker with the central one it works so the problem does not come from the speakers.
When I put a headhone I have some sound in it too.
The lights "speaker A/B" are off, it's a bit strange...
  • Anonymous Jan 23, 2009
    I Have the same problem.
  • 431 Answers
Sound to headphones comes from the pre-amp stage of most units otherwise they wouldnt be able to handle the power output . 150 watts into your ears ouch lol .
So it sounds like your slave amp has gone down on one channel . a slave amp is the final output stage and the power stage to the speakers . to make sure it is the amp change your speakers over if the sound then works from the speakers that had been dead then its the amp and requires an engineer to check it out with the prospect of a new output IC or final stage / capacitor replacement
unskilled persons should not attempt to repair electronic equipment as it is unsafe to do so , and may cost you far more in the long run ?. Regards Vortash
Posted on May 02, 2009
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
I search service manual for Sony vaio CR23
No I don't but it is very likely the left speaker is open, if you have a digital meter set it to ohms, unplug speakers from motherboard to remove any loads and compare readings on both sides. Then check out www.ebay.com Type make and model of laptop, and refine search to speakers.
Jul 02, 2012 | Sony VAIO Computers & Internet
My speakers just for some unknown reason aren't working.The remote control won't light up anymore
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
if you don't have the drivers you will need to download them
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
Jun 29, 2011 | Creative Labs Inspire T3030 Computer...
The speakers don't work at all. The blue light goes on fine, but there's no sound. They used to work fine with my iPod and iPhone, but not anymore.
Hi, Have they been turned off?
These speakers have a habit of setting their volume level to zero if the power is removed.
At the bottom of the right-hand speaker you should see some tiny volume up/down buttons.
Try pressing the up and see what happens.
May 05, 2011 | Harman Kardon Harmon Kardon SoundStick II...
I need the radio wiring color codes to a 2008 dodge avenger sxt
Clarification Request Posted by emissionwiz on Mar 17, 2010 Dodge Avenger with Infinity Audio Car Radio Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Red Car Radio Accessory Switched 12v+ Wire: Blue Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Green/Orange Car Stereo Dimmer Wire: Green/Yellow Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: White/Black Car Stereo Amplifier Location: Mounted under the rear deck. Some models have a black plastic trim covering the factory amplifier. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): White/Blue Left Front Speaker Negative Wire (-): Black/Blue Right Front Speaker Positive Wire (+): White/Red Right Front Speaker Negative Wire (-): Black/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Yellow/Blue Left Rear Speaker Negative Wire (-): Gray/Blue Right Rear Speaker Positive Wire (+): Yellow/Red
For some unknown reason your answer was changed to a clarification
Mar 17, 2010 | Car Audio & Video
Problem w/ Panasonic SA-HT700 speakers
Try looking in the audio settings,it might be configured for stereo/mono or any number of surround sound settings e.g; 5:1, 7:1 In which case it might shut off the power to the circuit board inwhich the speakers are connected.If that fails .......Take it back!! Either the connection inside the speakers is faulty or the connections in the unit are faulty.
Oct 25, 2008 | Panasonic Home Theater System System
Speakers stopped working
Hello there!
It sound a power adapter failure,
check your speakers for power failure, or bad connections,
check also your sound card, mixer, and drivers.
perhaps if a onboard sound is disable for some reason.
check that too.
Good Luck
Dec 29, 2007 | Harman Kardon HK19.5 Computer Speakers
Denon AVR-1802 Receiver Logo
223 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
