Question about Dishwashers
Not filling up with water all of a sudden - Dishwashers
  • 1,543 Answers
Check the water inlet valve solenoid. Look for blockage at the inlet screen of the water valve. Check that the float switch in the bottom of the tub is not gummed up with gunk and sticking up. (Making the dishwasher think it is full)
Posted on Aug 27, 2008
Front Fill water dispenser suddenly stops
Not totally up with that Amana but just check you have not inadvertantly set it up to fill at a certain level, low, meduim, high etc.
Nov 29, 2013 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool lsb6000pq2 washing machine won't fill with water
Humming could be a blockage on the fill solonoid valve remove water fill hose and clean the filter at the valve it pulls out or use an old toothbrush
Jun 26, 2012 | Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Ice maker no longer works. It has been working for years and all of the sudden the ice tray does not fill up with water, however the water dispenser dispenses water just fine....
    The unit uses a dual water and possibly the side which supplies the ice maker has become defective. Also check to see if the fill tube has frozen.
    Apr 30, 2010 | Thermador KBUIT4260A Stainless Steel
    Maytag neptune washer wont fill water
    It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
    Jan 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
    Washing Machine will not fill with water
    It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
    Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
    Over flowing washer
    If the water valve not getting 120 volts and its start filling that means its bad water valve if its getting 120 volts bad timer
    Nov 03, 2008 | Kenmore Elite 45986 Front Load Washer
    Water inlet not filling
    check it has drained completely after the last cycle.
    if that is ok, take top off and check continuity thro the inlet valve coils
    Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
    Dishwashers Logo
    274 people viewed this question
    Top Dishwashers Experts
