Question about Bosch Dishwashers
Dishwasher going through full cycle but not draining water at end. We have checked the drain pipe at sink and it does not appear to have any blockage. Should you be able to blow back in the drain pipe past the pump?
Fish bone in the impellor
Posted on Aug 27, 2008
Dishwasher Whirlpool quiet partner 2 will not drain
Check your drainage hose going to the kitchen sink. It should be routed up to an air gap on kitchen sink, or ran to the highest point as possible under the kitchen sink counter and then slope down into the disposer or branch wye tailpiece on your drainage piping depending on what your drainage configuration is. Not going up to the highest point, or an air gap, before draining into your drainage piping allows the water inside the dishwasher hose to drain back into the unit.
Feb 21, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Fisher Paykel Dishwasher drawer not draining water.... F1 error... Drawer is holding water......possible hard water build-up...
F1 means that your machine has activated the flood switch. check the drain hose that is connected to the sink pipe is not blocked. remove clip holding hose to pipe, put end of hose into a bucket and turn on cycle. it should start draining straight away. if it does drain into bucket stop cycle and clean nossel of sink pipe with a small screwdriver. then refit hose and turn on cycle. if it doesnt drain into bucket please reply and i will guide you thru how to check to see if you roto motor is jammed or faulty.good luck
May 05, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
The waste water backs up into the dishwasher when sink is plugged
Dishwasher manufacturers recommend a syphon break be fitted - but usually there is not a problem if your sink has an overflow pipe incorporated.
You have a partially blocked drain - causing wastewater to flow into the dishwasher instead.
Use 1/2 a cup of caustic soda or proprietary drain cleaner down the sink drain. Add about a pint of water, and leave overnight.
Next morning pour a full boiling kettle down the drain which should move things on and clear the drain.
You may have to repeat this process once, but is preferable to taking your pipework apart - which is next if this does not clear it.
Sep 14, 2009 | Dishwashers
Water leaking from underneath pipe connector to the dishwasher
Check the following:
* Loose or mis-positioned hose clamp at the drain spur connection
* Rotted or brittle hose
* Split hose
* Cracked joint at the drain spur connection or split drain spur fitting
Apr 27, 2009 | General Electric Dishwasher Timer
Just plumed in my hotpoint ultima it has done a
when you start the cycle the water will disperse. but check the fillters at the bottom of the dishwasher and make sure the drain pipe end is not crushed if you are enptying into the kitchen sink drain make sure the pipe is not kinked back on its self. try and get it as strait as you can.
Mar 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Water gets into disher when not inuse
dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Oct 27, 2008 | Kenmore 22422 Top Load Washer
Intake drain light flashing
1. Unscrew air gap which is on the counter-top next to sink.
2. Unscrew drain clamp under the sink which s connected to the air gap.
3. Use a wire hanger to push down debris clogging the drain.
4. Screw clamp and air gap back in place.
5. The dishwasher should work. Routinely clean out air gap every half year.
Jul 30, 2008 | Miele Dishwashers
Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Sep 16, 2007 | Kenmore 24 in. 15173 Stainless Steel...
Dishwashers Logo
113 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
