Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Can not view to take picture
Can not take a picture black sceen
  • 374 Answers
The lcd has gone out. you can send into repairs or find someone local to fix it for you.
Posted on Sep 10, 2008
My color went out and how can i get my color back on my sceen and so color show
When you view any photo on your computer or print out a picture, is it also not in color? If that is the case, I would suspect it is a setting somewhere in the camera menu and it is set to black and white. Cameras allow you to change colors to b&w, sepia, polarize etc. and this may be what you are seeing.
Sep 02, 2015 | Cameras
Laptop sceen black
If everything else is working, hook a spare monitor to the video output, if picture okay! the inverter board just below the screen is more than likely faulty, or the backlight behind the display has failed, but if both show the same symptom it is the video graphics card usually built into the motherboard, I suggest a computer repair shop to address.
May 05, 2012 | Toshiba Computers & Internet
The sceen is black but wen u press the power
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 13, 2010 | Neovo AG E-17A 17'' LCD Monitor
No picture or sound sceen is black
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Most likely a power supply component has aged and thus changed value and/or failed. Take it to a reputable repair person.
Mar 13, 2010 | Vizio L32 32 in. LCD HDTV
Pink tint in pictures taken using canon s500
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
May 05, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Turn on camera but the lcd sceen is black
I tried all the solutions offered on the net and none worked except one. It simply said "hit the camera with the palm of your hand" (when it is on) and the screen will return. I thought, well I have nothing to lose and so I hit it on the side and sure enough the LCD is again working !!! Contacted Canon prior to this and they had no idea but suggested I send it in to be repaired at a cose of $163.50 Australian. Pleasant staff they have, but no help in solving what looks like a common problem of Canon cameras. I will have second thoughts purchasing Canon from here on in.
Mar 23, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Ideal settings for Samsung LN-T 4234H
sure, lcd tvs need to be tweeked depending on the light in the room the darker the worse the picture. so try this
from standard:
picture: 85 to 95 %
brightness: 45% or adjust the black of the video to the black of the pilar bars to equilize them.
color: 32 to 38% or until the flesh tones are not so hot
sharpness: low 10%
tint: always to center
color temp: cool1
back lamp ( if avalible) low when lights are dim, high when lights are bright.
the problem with LCD is they don't look so good with dark sceens. the contast ratio is very low. natively 3000:1 aas compaired to plasma or other direct view TVs. the LCD is back lite and the thin materal of the LCD can not completely block the back light from coming thru. there for the complete "black screen" is illuminated "blue". the best thing is to keep the lights on bright in the room for the best picture.
Feb 22, 2008 | Samsung LNT3242H Television
Image not visible on monitor screen
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
32 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
