Question about Casio Cassiopeia E-15
Cannot start communications with the desktop computer
Please could someone help me? I have a Casio E-15 with Windows CE 2.11. Whenever I try and connect to my desktop PC (Windows XP), i get this error : Cannot start communications with the desktop computer. The computer is not available or busy and cannot accept connections Anyone know what the problem could be? Kevin
    Master:
  • 551 Answers
I have connected XP machine with Active Synch 3.1 to a wide range of E series Cassiopeias including E-15. The installation on XP is different from all previous versions of Windows. Without installing Active Synch you have to connect the switched on device to your PC & let XP find the device & install its own internal driver/service. Reboot the PC. Next install Active Synch - any version which should now find your device & start the service & establish your connection.
Posted on Sep 06, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I'm trying to reprogram the receipt header to show our change of address on a Casio-CE-4700. I have all the character codes I need, but I don't have the code to end a line and start a new one. ...
The codes are listed under file 32 worksheet, so look through your manual until you find the worksheet with file 32 listed, then you will see the line codes for header foot, commercial message etc.
If anyone needs more information, the Casio CE-4700 programming manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-2300_and_TK-2700_and_CE-4700_programming_manual.html
Aug 26, 2011 | Casio Parts Cash Register PC Desktop
I have a Casio CE-6100 cash register. Whenever I try to finalise a transaction with the "Cash" button i get a long beep and nothing happens. If i use the cheque or credit card buttons instead...
You may have changed the key feature settings for CASH accidentally. Try this:
Turn key to program mode 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL
Turn key back to REG mode and try it - you may have to sign a clerk on
If anyone needs more information, the Casio CE-6100 manual is here:
CE-6100 programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-6000_TK-6500_TK-7000_TK-7500_TK-T500_CE-6000_etc_dealer_manual.html
CE-6100 user manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-6100_users_manual.html
Aug 18, 2011 | Casio Parts Cash Register PC Desktop
EO4 error on Casio CE-700 can you help please?
I have never heard of this model. Did you mean a CE-7000?
Aug 07, 2011 | Casio Parts Cash Register PC Desktop
I have a casio CE3700 cash register. The machine locked up. I followed the normal procedures to resolve this, however when I turned the power back on from the socket the machine fails to turn on at all...
It sounds like there is a good reason for it locking up the first time then. Most commonly it is caused by a printer problem. Most Casio models will run the printer before they turn the display on, so if you can't hear the printer run at turn on, I'd start there. Look for paper jams. make sure the motor can turn freely. If the motor is okay, check the battery. You can experience weird problems if the battery has not been replaced on time. ------------------------------------------------------------------------------------
If anyone needs more information, the manuals are here:
Casio CE-3700 Service (repair) manual: http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/CE-3700%20and%20CE-3750%20service.TOC.pdf
Casio CE-3700 User and programming manual: http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/CE-3700%20operators%20and%20programming.TOC.pdf
Jun 10, 2011 | Casio Parts Cash Register PC Desktop
CASIO SA 1000
Hi.
I haven't worked on an SA-1000, but it will probably be the same as the other Casios.
This should work for the CE-7000 and possibly the SA-1000:
Turn key to program mode.
2 SUBTOTAL
Department number
05 SUBTOTAL
Type new name
00
CASH
SUBTOTAL
To input the new name, just use the keyboard. It will act as a character input keyboard. The layout should be shown in your user manual.
Mark
Jan 30, 2009 | Casio Parts Cash Register PC Desktop
I want to connect my casio CE-4000 cash register with my computer
Sorry. Far too old. No connectivity whatsoever for this model. It was a very low end register.
Mark
Jan 03, 2009 | Casio Parts Cash Register PC Desktop
Be-300 picture and music won't load
Be-300 is not the standard Win CE 3.0 It requires PCConnect software for communication. Download it from the following link. http://casio.monacocorp.co.nz/cassiopeia/
Sep 06, 2005 | Casio Cassiopeia BE-300 Pocket PC
E 115 and windows ce?
Tascal software has a software for changing the wallpaper on the CE devices. File name is wpc032mp.zip. Try it.
Sep 06, 2005 | Casio Cassiopeia E-115
Casio E-15 and Linksys WCF11
Well - if your PDA runs CE 2.11, it should install. Try downloading specific CAB file from Linksys's website for the MIPS processor (E-15 uses VR4111). If you have Linksys WCF11 card, go to http://linksys.com/support/support.asp?spid=71 If setup still doesn't work - copy a MIPS CAB file to your Casio via ActiveSync and run it from there. However, even after you install it - you might face problems. I still wasn't able to run my Linksys WCF11 on Casio E-100. Apparently, there is no easy way to specify IP settings (gateway, WINS, DNS) in Windows CE 2.11 for Linksys (unlike PocketPC OS, where we have network settings in control panel). I tried playing with registry - however, it messes up big time.
Sep 05, 2005 | Casio Cassiopeia E-15
Casio Cassiopeia E-15 Logo
294 people viewed this question
Top Casio Computers & Internet Experts
k24674
Computer Links
TimK
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
