Question about Hobart Dishwashers
Hobart Dishwasher We have an old smaller built-in dishwasher at our church (Hobart model WM5H). It doesn't stop spraying water if you open the door to remove a rack of dishes to put the next rack in like it is supposed to. One member thought it may be the Electrical Timer Switch? Would this be a fairly easy repair?
    Problem Solver:
  • 4 Answers
I guess I didn't understand your statement of the problem. If you know that the washer has gone through an entire cycle, and it is time to take out the RINSED dishes, yet the washer turns on when you do this, play with the door interlock and the door handle switches. If the cycle seems to have stopped, but you timed it from the beginning of a new cycle and it hasn't done all the steps, and it sprays when you open the door, then you may want to remove the timer motor and clean the contacts/ check for tine damage along with checking the door switches.
Posted on Oct 13, 2010
Looking for parts for Hobart WM5H Dishwasher.
Here's the link to get Hobart parts.
I hope they have what you need.
Aug 19, 2011 | Hobart Dishwashers
Hobart LX 30 undercounter dishwasher, commercial Does this model require booster?
Most of the Hobart LX series of dishwashers have their own built-in booster heaters. To check for one, remove the lower front panel (2 screws). The booster heater, if present, will be a stainless steel tank on the left side. If it doesn't have a built in booster heater then it was meant to be used with chemical sanitizer instead.
Jun 29, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have a hobart wm5h undercounter dishwasher. the water is not coming in to the washer? any suggestions?
After checking to see if the water source is supplying water, if the timer motor is going through the entire cycle then focus on the fill solenoid. It will make a big clicking sound as it opens and closes.
Dec 01, 2010 | Dishwashers
Hobart commercial d/washer can't stop water from spraying top/bot
try not to turn off the water supply,if i where you i would get this machine checked out.What i cant understand is the machine spraying water when it has power of.adrian,,,,
Jul 14, 2010 | Hobart 29 in. AM15-1 Free-Standing...
Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Jan 10, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Seeking the manual for an old Kitchenaid dishwasher model KDS-17 serial no. 220-2691847 Any help will be much appreciated. My email
kitchenaid didnt make that d/w, hobartmade it for kitchenaid, thats why they are still running from the 1960's the mod# from hobart should be a wm5h
Oct 26, 2009 | Dishwashers
Leaking on LXIH dishwasher that is level
No. The water level is controlled by two probes inside the back RH corner of the tank. Level the unit with the smallest tilt backwards.
I would closely look at the wash (and rinse arms if equipped). Make sure there is no missing plugs (depends on how old unit is if plugs are used), and that there is no debris inside the wash arm. Debris will cause the water to spray off-line and hit the door seam directly.
Jun 18, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher does not run
I'm a hobart tech and repair these units often.I can tell you this---If you open up the control panel and see water the wash tank has a crack in it.If this is the case depending on the serial number you may be able to get a new dishwasher.What happens is the water gets onto the electronics and shorts out.What is the exact serial number,model number and ml number?How old is it and where are you located?Have you had any repairs done by hobart or any other service company?
Jan 10, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Looking to find out how old a hobart dishwasher model# wm-es-2 is
Hi Bobbertb
Let me see if I can help you. If the unit have a hot water booster behind the bottom panel, and it is located on the left and oval shape; well that's old. most parts are no longer available. If the booster tank is on the right side and somewhat square looking, then there is a chance.
Normally the model and serial number are stamped on a piece of metal, riveted on the upper section of the door.
More, models like wm5h or sr24 were very popular and most parts are still available.
I suggest you search the internet for those models, see if they match what you have.
Dec 01, 2008 | Dishwashers
Dishwashers Logo
355 people viewed this question
Top Hobart Dishwashers Experts
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
