Question about Casio Cassiopeia E-125 Pocket PC
E125 screen failure symptoms
Hi all, what are the sypmtoms of an LCD screen failure? im just a little confused at the difference between a touch screen and LCD failure. i guess if your LCD then its not a DIY repair job is it? my screen refuses to light up at all, no cigar. some folks say it a dodgy battery, others say check the touch screen, or its an LCD prob if u can see dark splotches on it... any more checklists you have i can run through to make sure? cheers
    Master:
  • 551 Answers
As a rule the failure of the LCD on a Casio pertains to greying out of the top 1/3 portion of the screen. The touch screen - the part that senses your stylus inputs i.e. taps, double taps, tap & hold / drag continue to work. Seems like the failure is not in the LCD but the fluorescent lamp at the top end of it. It could be the lamp itself or the inverter circuit. Have an experienced technician check the lamp out. It is not a very diffucult item to replace. Nor is there any desoldering / soldering involved.
Posted on Sep 06, 2005
Thin white horizontal line in the center of the screen when the tv is on.
Hi Tim,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 22, 2015 | Emerson Televison & Video
Samsung s42ax-yd01 - No picture / Sound OK problem
- Flickering screen
- Dim screen
- Slow start
May 22, 2015 | Samsung Televison & Video
Lc32le10m showing only standby ligth no ligth on the screen
- Flickering screen
- Dim screen
- Slow start
May 22, 2015 | Televison & Video
Sound is good but no picture
Hi Tollie,
- Flickering screen
- Dim screen
- Slow start
component failure.
May 13, 2015 | Televison & Video
Why is there no picture?
Hi ricky
- Flickering screen
- Dim screen
- Slow start
component failure.
May 13, 2015 | Sylvania LC320SLX 32 in. LCD TV
How to repair crt tv the different stages and symptoms causes and remedy
Take it to one of the Cell Phone Repair Shops and ask them to replace the screen. If you attempt to do it, I promise, you will be sorry. You should take to someone to replace the glass. I think they only charge $30 or so. Otherwise if you do not have insurance you will have to buy a new phone
Jul 23, 2014 | Samsung Cell Phones
Hi my keyboard problem some time the screen turn on normaly and some time not i have to turn it of again how can i fix it tnx
It is possible that there iis a compnent failure in teh POR (Power-on-reset) circuit. This is NOT DIY unless you are adept at electronics. I do NOT have the shematic for this keyboard. I looked at the schematic for a PA500 which MAY be similar and it has a touch screen. SOMETIMES dirt gets under the edge of a touch screens and confuses the processor with a false input. If yours fits this scenariom you might try running a piece of copy paper under the edge where the case hits the LCD screen.
Jan 03, 2011 | Korg Pa800 Synthesizer
Monitor on a emachine 250 computer comes on picture is very light faded in the background but no light
This is a typical symptom of a failing LCD screen inverter board or LCD screen backlight lamp. The backlight lamp failure symptoms are very similar to the inverter board failure symptoms. If you have to guess which one is causing the problem, try replacing the inverter board first. LCD screen inverter boards fail more often than the LCD screen backlight lamps.
Feb 16, 2010 | Acer Computers & Internet
Monitor L17AMTN flashes WinXP desktop, then blanks.
dmellman, Before you open it up, try this! With fully booted pc and WIN DESKTOP screen up, reconnect the L17AMTN . Have a bright flashlight handy so that when the lcd screen flashes on for 1 second and then goes dark, you will want to check to see if the desktop remains on the screen even though you think it went away. Shine the light 1-2 inches from screen at different angles. Has the desk top completely disappeared or is it still being displayed? Do you know about Cold-Cathode-Fluorescent tubes and their Inverter type power supply? I assume that this unit also has a "lay on floor black box switch-mode-power-supply" that is supposed to supply raw 12v-14v dc to the monitor? This symptom is typical of lcd monitor power supply failure, and or inverter board failure. Not to mention the fact that the CCFT's could be a bit tired from use. YOUTUBE has some videos on taking apart lcd monitors. also do search on web for "bad caps on lcd boards" or "bad caps in lcd monitors". I should think that this Tatung might suffer from swollen cap-itis. get back to me with results of your investigation. Im louie12fix on fixya or lmistyrel@aol.com just nrth of Windy City
Apr 17, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
88 people viewed this question
Top Casio Computers & Internet Experts
k24674
Sunil Pratap Singh
Sunil Pratap Singh
Joseph Hoffmann
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
