Por favor, donde puedo consegir los drivers para la placa base marca Pcchips modelo M935LR o dime algunos que sean compatibles con el modelo, que funcionen bien...
I used to have the PCChips motherboards just as you have now. However then and now, PCChips claims that there is no such model on their Taiwan website which is their major support website for all models. I have in the past used the M935L drivers to fill the LR needs and if I remember correctly used the Bios updates too, but don't claim that I am leading to you install an improper bios as neither I nor PCChips would agree. Install Bios updates at your own risk just as the manufacturer website says.
- To find the motherboard on their site, simply go to the site i have
given and in the three ' input ' boxes, select ' motherboard ' on the
first. On the second ' input ' box select the type of motherboard ( in
your case ( socket 478 ). On the third input box, select the model # closest to yours, M935L in this case. The small fourth input box is for PCB ( Printed circuit board ) version which in some cases can be very important within the same model series. So important that installing a Bios for one PCB could and probably would corrupt a board of an different PCB version but same model #. PCChips used to get at least some of their boards from ECS, however the model #s are entirely different and are not easy to verify against one another. I've been down that row so don't involve yourself with trying to check the ECS mainboards against your PCChips. Stick with the PCChips website.
Was this helpful?
Yes
No
Popular Solutions for EliteGroup P4VMM2 Motherboard
my computer is a dell inspiron 531. 2 1/2 years old. it developed shut down problems 2 months ago....
(More)
my computer is a dell inspiron 531. 2 1/2 years old. it developed shut down problems 2 months ago. at first it would run for 4-5 days then shut down. I have replaced 1. Power supply. 2. Hard drive. 3. Optical drive. 4.Rewired ac line to larger gauge wire. 5. new heat sink and fan for the processor. Problem still exists. Only thing left to replace is the motherboard or processor. Does anyone have any clue? Please email me to cqk7yg@yahoo.com. Thanks
can you you tell me how i can fine a wedsite with a clear motherboad diagram with a step by step...
(More)
can you you tell me how i can fine a wedsite with a clear motherboad diagram with a step by step describtion of all the parts on the motherboad circuitry ?
