Question about Casio Cassiopeia E-100 Pocket PC
Activesync Problem, Help Pls
Please help me snyc my Casio E-100. I have the following: PIII 450 - Win 98 Machine Outlook 2000 (Office 2000) It connected via a Com 2 serial connection. I've install the latest activesync. But when I sync the E-100 in keeps telling me there are unresolved problems when attemping to synce anything but files. Please help, I've gone through most of this board and nothing helped. Please keep in mind that it actully connects but it doesn't sync with anything but the files. Thanks, Dave
    Master:
  • 551 Answers
Try the following. FIRST & FOREMOST BACKUP YOUR DEVICE TO A "CF CARD" USING THE BUILT IN "CardBackup" UTILITY. This is a much faster option than using ActiveSynch. It ca restore also much faster. Once your files have synched go to options & change the synch options to manual & file conversions to NONE. Remove or switch off the device. Next delete the partnership WITHOUT DELETING THE SYNCH FOLDER !!! Be very careful. Switch on or replace the device on the cradle. Active synch should recognise the device & offer to setup the partnership. Let it do so with "THIS COMPUTER ONLY" option. Once your device is scanned by activesynch one of the options it will offer is of combining the records. Select it & let it synch. I most cases this should solve the problem. Hope this helps.
Posted on Sep 06, 2005
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
How i can sync my Ipaq h3955 with my pc win xp
In order to sync your iPAQ with Windows XP or earlier, you will need to download and install Windows Microsoft ActiveSync 4.5 from:http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx.
Notes:
You can use ActiveSync 4.5 only with phones that run Windows Mobile 2003 or later versions. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 phones. (To see which Windows Mobile operating system you’re using, if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync information to any of these phones, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
Download and install ActiveSync:
1. Click the download link on this page, and then click Continue.
2. Select whether you want to register for the Windows Mobile newsletter, and then click Continue.
3. Click Download files below, and then click Download (next to the Setup.msi file).
4. In the File Download dialog box, click Run.
5. Follow the instructions in the Installation Wizard to install ActiveSync.
Note: You must use a USB cable to connect your phone to your computer the first time you use ActiveSync to synchronize information.
Jan 10, 2010 | Compaq iPAQ H3955 Pocket PC
Won't accept win xp
the minimum hardware specification of the win XP is
atleast PIII-800 Processor
128MB Memory
32 mB videocard
Aug 14, 2008 | Computers & Internet
Sync with nokia
First sync your Nokia with PC. In settings choose either Contacts or M$ outlook, whichever you using. Then install ActiveSync 4.5(for Win XP) or WMDC(for Vista) and again in settings choose one of above mentioned programs to sync, ie Contacts or M$ outlook.
Jun 08, 2008 | HTC S710 Smartphone
Activesync connection problems
this due to usb you just download hotfixes form microsoft updates and also download win xp service pack 3 which is available in windows site
Feb 15, 2008 | HP iPAQ rx1950 Pocket PC
Just Need A Driver For Win 98(SE)
You may try the windows 2000n driver from www.hp.co.uk downloads but hp stop supporting windows 98 and you will not be able to get the driver for that machine on 98. Millennium had some qualities of 2000 so try that.
Thanks please rate me
J
Dec 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Will Dell Axim sync with Outlook 2000 on Windows 95?
It should if you have USB on the W95 machine. ActiveSync is compatable with W95. It worked for me with Outlook 98 on a Win95 laptop synching to a PC2000 PDA (Jornada), however I was using a serial cable.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Need help on connecting E-125
I doubt it... I mean it is unlikely there is any incompatibility there. Go to your device manager and make sure that your USB ports are installed and configured properly for your USB cradel.
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
BE 300 on xp home ed.
http://www.abfnet.com has a bunch of be'ers that can help you - you can also search the forum for ton's of answers. One thing, if you have Microsoft Activesync on your system pc connect won't work unless you shut off the activesyncs access to usb ports. Just a thought.
Sep 06, 2005 | Casio Cassiopeia BE-300 Pocket PC
HELP: Activesync XP Reboot Problems!
Now don't laugh :-) on win 98 windows - I'm told - had a certain limited ability to fix itself. I don't know if xp does or not. Anyway on 98 if you ran into a problem you could let it reboot three or four times without doing anything but booting and shutting down - it at times would correct itself. This was normally on boot problems, but it might do some good - don't know of anything else to suggest. In your case I'd try this then try running active sync two or three times without doing anything else. Anyway that would keep you busy till a good tip comes along :-)
Sep 06, 2005 | Casio Cassiopeia E-115
Casio Cassiopeia E-100 Pocket PC Logo
98 people viewed this question
Top Casio Computers & Internet Experts
k24674
Sunil Pratap Singh
Sunil Pratap Singh
Joseph Hoffmann
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
