Question about Olympus C-3000 Zoom Digital Camera
In shutter priorty mode it seems that the apeture is always set to f2.8 regardless of shutter setting.
    Master:
  • 852 Answers
Are you sure you don't mean the PROGRAM mode here ?? - The Oly program mode favors the f 2.8 f stop until the shutter speed rises to 1/300th to 1/400th - only at this point will the f stop start to rise. If it IS the shutter priority mode then you have the shutter speeds set too HIGH and the camera is making an attempt to do the best it can by setting the lens as WIDE as it can at f 2.8. James, Try this again in good light and reduce the shutter speed lower and lower - eventually the f stop will start to rise
Posted on Sep 06, 2005
SOURCE:
I can't get my 5D mark iii to operate at night with available light
Try using manual focus - if the autofocus won't work, because of low light, then you can't take pictures.
Jul 23, 2017 | Canon 1d 1ds 3d 5d Mark Ii Iii 1v 1n
Nikon ED AF-S nikkor 300m 1:2.8 D II connecting to D80
If there is an option to reset the device , reset it inorder back to default settings.
Hoping for such approval to make my rate solved.
Best regards,
Philip
Nov 14, 2007 | Cameras
How could use vivtar 500mm in D40x. the seller asked me to put the camera in Manaul mode and set off to the shutter priorty to off. I could not find how to set the shutter priority to off in the setting.
A 500 mm mirror lens is a fully manual lens (manual focus no aperture change) using a T mount adapter to your specific camera. The T mount costs some $15. It depends on your camera how to turn off the auto focus and go to aperture priority mode. The aperture on a mirror lens is set, usually at F8, so the shutter is the only item that can be adjusted to get a correct exposure. A digital camera (set in adjustable ASA setting) can change it's ASA to help with getting a correct exposure. Manual for digital camera are usually on the companies' web site.
Feb 22, 2014 | Vivitar 500mm 8.0 Lens Nikon D3000 D5000...
My Pentax K100 DSLR is flashing "av" and will not take a photograph, though the shutter works fine and takes pictures without the lens.
"AV" means apeture priority. This means that you set the apeture that the camera will use, and it decides the shutter speed. The flashing "av" means that you've picked an apeture that the camera can't pick a suitable shutter speed for at this light level. I would suggest picking a different apeture, or switch the camera to full automatic mode via the dial on the top left of the camera.
Mar 03, 2011 | Pentax K100D Super Digital SLR Camera
I have a Nikon 33mmSLR on maunal setting, to control apeture and shutter speed. There is an automatic setting, but I have it on manual and I am still getting the FEE error. If I switch it to lowest apeture...
Ignore the error. Control the aperture by turning the aperture ring on the lens. You will get no help from the camera's exposure meter.
If the shutter cannot be fired this way, please reply to this post and we'll go on from there.
Nov 17, 2010 | Nikon N65 35mm SLR Camera
The LCD-screen seems to work normal. But when we take a picture (camera-mode normal and record-mode normal) the result is overlighted and misty and full of horizontal lines. In video mode the camera works...
Try to use a different setting like a bright light setting to see if the apeture is closed down further and brings back focus.
the problem is the auto focus which can be going stray and is not setting right.So take time to shoot with the shutter button down to half to allow it to focus and then once the indication of the focus has confirmed to click.
If not contact Sony service for help.
Sep 28, 2010 | Sony Cyber-Shot DSC-T3 Digital Camera
I never got a manual for my s 5200 fuji fine pix. My problem is I'm not sure what the M, A, s, P, and different settings on my camera mean. And am having a hard time finding the site on here.
M-manuel, you set up all of the functions, difficult as the camera will not give you any help A-apeture priorities, you tell the camera the apeture you want to use, the ISO you want,the white balance you want the exposure level you want, and it adjusts the shutter speed to compensate S-shutter priorities, just like apeture priorities except the camera adjusts the apeture fou you instead of the shutter speed P-program mode, lets you tell the camera how bright or dark you want the picture to be, and it adjusts everything else
Here is a link to a website that has an instruction manual
Jul 28, 2009 | Pix FUJIFILM Fine F200EXR Digital Camera
Bought nikon d2x but some of the setting are lock. How to unlock
The camera is probably in Auto Mode. Set it to manual and you can change your ISO, Shutter, and Apeture settings.
Rb
Feb 26, 2009 | Nikon D2X Digital Camera
Will a lenses without the A setting on the apeture ring work on a DS
They will - fully open in Av mode, and with any aperture in manual mode - after you allow the Ds through the custom settings menu to use aperture settings different then "A". To choose correct exposure with such a lens in manual mode you can use the AE-button - it stops down the aperture, reads the EV and sets the shutter speed according to the chosen aperture.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Focus on a subject
Question 1 - This should not happen as you describe. f 2.8 at 1/100th should give you about f 5.6 at 1/25th. Try this again and check to make sure the light level and your subject doesn't change
Sep 06, 2005 | Olympus C-3000 Zoom Digital Camera
Olympus C-3000 Zoom Digital Camera Logo
59 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
