Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
FDB956RBC1 series lights blinks sometime after start cycle
The dishwasher will cycle through the test sequence on the enclosed troubleshooting guide with no problems. The times etc are on que. After starting a wash cycle, at some point the washer will start clicking with the panel flashing. Acts like a motor contactor dropping out them picking up. After a few cycles of this it just stops. Will restart again later. Ideas?
  • 1 more comment
  • chriswendy Aug 27, 2008
    Checked all electrical "slip on" connectors. Remember the troubleshooting sequence went through the cycles without the blinking panel lights and clicking sounds.
    removed the cover for the impeller in the tub. No blockage or broken fins. Turns freely.
  • chriswendy Aug 30, 2008
    Taking the dishwasher back out of warranty for repair isn't a good solution. So far nothing has led me to the issue at hand. Maybe techexpert can repost his ideas.
    Genius:
  • 1,011 Answers
Sir,
Try to turn your breaker off to the dishwasher for about 5 minutes to see if it will reset.
thanks
good luck
Posted on Aug 30, 2008
    Genius:
  • 1,269 Answers
Sounds like a drive motor problem. Re-align the drive motor and please double check the Drain and Wash pump for any leak. In addition, please clean the solenoid.
Posted on Aug 29, 2008
  • 1,879 Answers
Techexpert12's suggestion covers all that you need. have it repaired if it still doesn't work.
    Master:
  • 763 Answers
If no other solutions then try send it back to the place where you bought that and ask for a service so that they can replace some parts of it(if its on warranty and be sure to bring the warranty card or proof that you bought this item in their shop)
CHARCOIS
    Master:
  • 521 Answers
Posted on Aug 27, 2008
  • tech expert12 Aug 29, 2008
    www.repairclinic.com
    click your product and then model number
    it will provide u all the details.and possibilities to solve the problem.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
  • 6,487 Answers
Must pull out dishwasher and remove ortilt/block up tub to remove orreplace motor, do so only if certain motor has failed or impeller is jammed with debris
Hope that helps........
  • Mark Gil
    Mark Gil Aug 28, 2008
    Put everything back in and make sure you put them back properly and after that trt to check if still have the same problem...
  • 157 Answers
There is somethn loose in it
Posted on Aug 26, 2008
My maytag dishwasher's "clean light"
If this is a Whirlpool manufactured dishwasher, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat related problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccurring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel.
If you still need assistance, please post back and let me know
Jul 26, 2011 | Microwave Ovens
Clean light keeps blinking. Will not start a new cycle. pushing cancel or other buttons does no good.
If this is a Whirlpool manufactured dishwasher (such as the one pictured), the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat related problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
May 26, 2011 | Whirlpool DU1055XTV 24 in Builtin...
Kenmore dishwasher model #665.17034401 --- Clean light blinks
The blinking clean light is an interruption in the dishwasher program that indicates a component malfunction, or it can be a result of a momentary program glitch. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
May 07, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Clean light will not stop blinking and that will not allow me to start another cycle
Feb 24, 2010 | Kenmore Dishwashers
Clean lgiht on door is blinking won't start washing
The blinking clean light is an interruption in the dishwasher program that either indicates a component malfunction, or a program glitch. The following link explains how you may be able to clear the blinking clean light problem:
I hope this helps you solve your problem.
Jan 12, 2010 | Dishwashers
The clean light is blinking, and the cycle won't
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or a simple program glitch. The following link explains how you may be able to clear the blinking clean light problem:
Jan 06, 2010 | Dishwashers
The "clean" light keeps blinking. It will not allow me to start another cycle or to cancel/drain.
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
I have often found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
If you have any questions, please let me know. I hope this helps you solve your problem.
Dec 09, 2009 | Microwave Ovens
Our Whirlpool Gold GU180 start light blinks continuosly. It will not start going through the cycles even when we press on the start button for 5 seconds or more.
   The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using fixya.
May 03, 2009 | Whirlpool Dishwashers
My normal cycle and cancel button lights are blinking on my kitchenaid dishwasher. Model # KUDP02CR8S2 Any suggestions?
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Apr 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
140 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
