How do I get a wide screen, hi def display on a wide screen Hitachi 55HDT52? Right now I have to choose between chopping off half the heads or losing the captions. I tried to contact Hitachi about a possible softward upgrade but have had no reply. They only have email contact; no phone numbers.
I found a phone number for Hitachi and was told that's the way these TVs work. The problem isn't the TV but the broadcast format and their's no way to adjust the height of the picture on the plasma TV sets. I told them it's something they should consider. My $300 plasma montor can do it so why can't a $5000 TV? He laughed.
Posted on Aug 27, 2008
No picture no sound , 55HDT52 TV . we where watching it and it just went out ?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 25, 2016 | Hitachi 55HDT52 Plasma Television
Volume but no sound on hitachi 55hdt52 tv
Check its speaker. If it is OK, check and replace the audio output IC.
Jan 29, 2013 | Hitachi 55HDT52 Plasma Television
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Sony LCD cutting off image when hi-def cable hooked up.
This will happen invariably. Depends on the nature of the signal that is being received. Some will fill entire screen, others will not.
Just go with the flow - tv is operating normally.
Aug 23, 2017 | Sony WEGA KD-34XBR970 34" TV
Picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
Nov 17, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi tv no picture
It sounds like the tuner demodulator has failed. Many times I have found that it is cheaper to buy an external hi-def tuner than repair the one that is in the set. The fact that the tuner is finding channels but not displaying them is a good sign that the demodulator has failed. In one case I had with Sony rear projector, it would have been $800 to repair the internal hi-def tuner and the customer can buy an external tuner for $100-$200. Sorry if this is not the answer you wanted; if you fel this si a good response to your question, please be sure to rate me,. Thanks!
Oct 22, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Philips 61"TV chopping heads and bottom off
Check the formate and make sure it is nit 4:3 try wide screen and the other formate options.If that don't fix the problem the problem is the SSB part number 310432716308 that is the video processor.
Jul 13, 2008 | Philips 60PP9202 60" Rear Projection...
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
