Question about Toshiba Satellite A135-S2386 Notebook
Toshiba startup My toshiba laptop will not turn on. I recieved an error saying that windows was not able to startup. To put in safe mode to prevent any damage and to check for updates and any recently installed software or hardware.
    Genius:
  • 2,028 Answers
This is one of two things, 1- an operating system error or glitch, a system repair with your recovery or operating system disc will fix it, or 2- a hard drive failure. If the system repair doesn't work, then reformat the hard drive and install a new operating system. If the drive will not format, or you have any issues during or after the install, then the hard drive is bad and will need replaced.
Posted on Aug 26, 2008
Will turn in but won't really start up, message pops up sayin I have problems on my laptop but it can't fix them? Read description
When your toshiba splash screen is showing on startup, press F8 continuously, then you should get some options, go to the one that says safe mode. After loading windows in safe mode click start, search, and type system restore. Open system restore, find a date where your pc was working correctly and click restore. If this doesn't do it on the toshiba spash screen (if you have a new enough laptop) there will be an option called system recovery usually f11 key, this will restore your pc back to its factory state and should resolve any problems your having. If you don't have that option go to https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp and see if you can order a set of recovery disc's for your model, they usually run from $25-$30. Hope this helps.
Mar 01, 2012 | Toshiba Computers & Internet
When I turn on my laptop it goes to a windows error recovery page and gives me the options to launch startup repair or start windows normally. When I launch the startup repair my screen goes black and only...
Hello.
Sounds like the Windows Recovery Partition is corrupted or your hard drive may be faulty.
But, first try to boot your system in Safe Mode (press F8 repeatedly as it boots) and choose Safe Mode or Last Known Good.
If it still doesn't boot properly, try the diagnostics to determine if a hardware problem - boot your system and press F 12 (or F2) repeatedly.
Hope this helps.
Jan 11, 2012 | Toshiba Computers & Internet
Error code 0x80070002
Reset the default security provider in Windows XP To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry:HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\ProvidersHKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
  4. Quit Registry Editor.
  5. Restart the computer.
  6. Use a system utility software like ReginOut to fix this problem without performing the above steps.
Dec 31, 2011 | Toshiba Satellite A55-S106 Notebook
Windows canot find windows system32 drivers prgds exe
Are you getting this error message on startup/login? Does it prevent you from logging in? If so then try starting in Safe mode. See http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode for instruction on doing this in Windows 7.
What version of WIndows are you running?
Sep 07, 2011 | Dell Computers & Internet
When computer is turned on the windows error recovery is that windows did not shut down successfully. So I choose safe mode to start windows. Window loads files and then just goes into Welcome and then...
Ok, well try this, Startup PC, press F8 at instant of turn on... choose Safe Mode. when you are asked if you want safe desktop or system restore choose restore, when you get to the restore menu, choose a date BEFORE you had problems there may only be one or two to choose from. just follow the instructions and you should be back to working with all that behind you.
Feb 17, 2010 | Toshiba Satellite A135-S2326 Notebook
WINDOWS WONT START UP when i try to repair it it says it is dowhloading windows and then a minute or two later it says it could not start and to turn off the laptop
  1. Hi, try rebooting the computer in one of the different "Modes" at startup, when the window prompts, "press the F2 button, select either "recovery mode" or "Safe" mode, if the computer, recycle back to the "Option start modes,; choose "Normal Mode." Next go to the Computer, open, and select "Properties," click to "Tools," in the (Error checking) window, select the (Check Now), you may have to choose "when the computer startup option." click "Apply and OK." When you start the computer again, a "Full" Disk Scan, will begin; be patience! this can take awhile. After the scan is complete, you should have an idea of what the problem is exactly. If you need further assistance afterwards? I'll be looking for an updated "Post" Thanks"Did this solution help?"
Jan 17, 2010 | Toshiba Computers & Internet
Screen says windows didn't start properly...help! :(
Acctualy you hadn't specified, that the computer is working and then you find this messege every time, or that the computer is not working and this messege appears every time, First if the computer is working properly and you recieve this messege every time, so you must check if you were closing the computer properly (closing all windows before shutdown), Second if this didn't work and the screen still appears, thats means there is corrupted system files due to many factors (from it Infection with a virus), and you must reinstall your windows.
Jan 08, 2010 | Toshiba Satellite A105-S4384 Notebook
Toshiba a8/420cme
Did you try restarting in safe mode F8 ?
It should then lead you to operate normally.
Sep 19, 2009 | Computers & Internet
Frozen Toshiba P100
Try This. Restart your computer and as soon as it boots up tap the F8 key repeatedly until you see windows advanced options menu. select safe mode. when it asks you for the operating system just hit enter. as soon as it boots to safe mode do this. click start> run> type msconfig then hit enter. On the system configuration utility click on the startup tab then select disable all. Click apply then close. restart your computer again. It may be a corrupted startup program that is preventing your computer to boot up properly.
Oct 08, 2008 | Toshiba Satellite L25-S119 Notebook
Computer shutting off
because of virus you start windows in safe mode an try booting if it work in safe mode > go to run > type= msconfig > disable all in startup, reboot windows see if it works if not please reinstall windows xp.....
Apr 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A135-S2386 Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
