Question about Panasonic Lumix DMC-FZ20 Digital Camera
Sunpak softlite 1600A for fz20
I have an OLD sunpak softlite 1600A flash. Will this work on the fz20?
    Master:
  • 903 Answers
According to this site, the Sunpak 1600A is NOT USABLE with the FZ20: http://www.botzilla.com/photo/strobeVolts.html The tested voltage of the 1600A is 46.6V, which is WAY above the 24V max specified by Panasonic. Don't even try it...
Posted on Sep 06, 2005
SOURCE:
I inherited an old Sunpack Softlite 1600A Flash, with no manual. Does anyone know if will work with an Olympus OM-D e-M5?
Yes no problem. it is a standard Hot Shoe Flashgun. I have an OM-1-MD and and an OM-4. Haven't used them in 15 years!
Sunpak Softlite 1600A Specs
Olympus OM M5 Google Search
Jun 27, 2018 | Olympus Cameras
How does the Sunpak Auto 555 Thyristor Flash Unit work concrning a battery? Does it always need the ourside battery pack unit also?
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
Aug 07, 2010 | Sunpak Auto 555 TTL Flash
About parts of Sunpak 544 flashes!
IF you are working on them then you know the part number on the transformer. You may need to use Alibaba to see if the part is available in China.
Jul 31, 2017 | Sunpak Auto 544 Flash
Can I use sunpak 1600a flash (older) with Pentax k10d dslr ?
Yes, it's possible.
The flash sensor is calibrated for a 35mm optics & iso (asa).
You may have to "UP" your digital camera's iso sensitivity to 800 or so.
You will have to experiment with it at various settings.
Try using the "bracket" sewtting on the camera.
It takes three pictures when you press the shutter button; the three have different "values" of brightness.
The bracket setting is on the UP arrow, where you can choose "single frame", "continuous frame", bracket, etc.
Hope this helps!
Sep 14, 2009 | Sunpak Cameras
Need manual for Sunpak 4000AF Power Zoom Flash
Regarding using the Sunpak 4000AF flash with my Canon EOS Digital Rebel, I can't get the flash to fire. There seems to be no combinations of settings that works to make the flash work. Could a weak battery in the Canon cause this? Does it require some other wire connector between the flash and the camera?
I know this is old technology now, I have a pocket digital for most of my uses, but I'd like to try bounce flash again on my old Rebel digital, and so I've gotten out my old camera and the flash I had bought for it. I had bought the Sunpak flash years ago and I honestly don't remember if I got it to work back then or not.
Thanks for any advice.
Jun 25, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Sunpak PZ 4000AF for Canon EOS 35mm SLR body
Canon digital uses E-TTL metering for best flash results, the older Sunpak unit isn't compatible with this, so it is not fully compatible. It may work in manual mode - but won't be as good as a more modern compatible digital flash like the Canon or Metz (eg 58AF1 Canon) versions.
May 11, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Sunpak 2000 DZ
see if this helps:
http://www.flickr.com/groups/400d/discuss/72157603805472662/
Feb 10, 2008 | Sunpak 2000DZ Flash
Sunpak pz 4000af for minolta
The Alpha 100 only supports pre-flash TTL and ADI flash control which are not supported by the Sunpak. The flash should ignite, but automatic controlling of its brightness is not possible.
For more Information about the different Minolta/Sony Flash Metering modes cf. http://www.mhohner.de/sony-minolta/flashcomp_mm.php
Jan 20, 2008 | Sunpak PZ 4000AF for Canon TTL Flash
Old flash
at a whopping 46.6V.. yes, it would damage it.
Nov 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Panasonic Lumix DMC-FZ20 Digital Camera Logo
610 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
