Question about Olympus Camedia C-2500L Digital Camera
How many pics can you take with a digital camera? After 1200-1500 pictures my C2500L says funny then using the autofocus. It's still working fine, but I'm a bit worried about it. And what about the shutter? What is the average lifetime for it?
Take a look at this discussion of shutter lifepsan. http://www.dphoto.us/forum/archive/index.php/t- 4531.html To summarize these posts, average number of cycles (one instance of open and close shutter) is somewhere between 50,000 and 150,000 cylcles. As one poster pointed out, we seem to take more pictures with digital than with film cameras, so a hundred thousand cylces might not be that many. I have a c2500L bought used at online auction and have probably taken about 1500 pics so far. Don't know how much previous owner used it. It's amazing how many pictures you take when you don't need to spend money on film and processing! The c2500L is a really nice camera and I hope that mine lasts many years. My c2500L is an early one with version 1.0 firmware (later models have version 1.20 sticker on side) and was built in about 1999 I think. As for autofocus, mine works great as long as I have the focus mode (regular, macro, super macro) and zoom level set correctly for my distance to subject. Fortunately, the green focus indicator lamp near viewfinder flashes when focus isn't right. A few other thoughts on focus: taking picture through glass, in mirror, or scene with no contrast (like a solid grey sky) might require you to use the manual focus or focus lock modes. Window glass fools camera, which tries to focus on glass instead of your desired subject. For mirror, you need to double the normal focus distance (measure distance from camera to mirror, focus on something twice as far, then lock focus and take your pic in mirror). With SLR film camera, mirrors and glass don't cause trouble because you are focusing manually. One other note on fuzzy or dark corners on pictures: if you use filters, especially a thick filter like a polarizer, you should probably get a 43mm to 46mm adapter and use bigger filter. At widest angle zoom, my polarizer causes vignetting in corners because the filter actually is "seen" by lens in corner of pics. Oops, I should have thought of that before buying filters I guess. Hope this helps some.
Posted on Aug 17, 2007
  • Hydra Aug 17, 2007
    Oops, link to discussion forum is
    http://
    index.php/t-4531.html
    Sorry, URL doesn't fit on one line and doesn't format properly when line is wrapped, as I just discovered. Or search for "digital camera shutter average lifespan service life" and you should get search results similar to mine.
SOURCE:
My Canon EOS rebel suddenly won't take pictures in dim light. The flash pops up and blinks and blinks trying to register the image but won't ever autofocus and take the picture. The light has to be very...
To autofocus the sensor needs a fair amount of contrast (light and dark eges) to operate. If you're trying to take a photo in a dim room of a dark colored subject for instance the focus won't lock and the camera won't take the picture. Try switching your lens to manual focus and shoot that way.
Jan 07, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
My camedia c2500l camera shows a card error message when loaded with a 1gb CF card. The card reads OK on my PC. It is loaded with about 200 photos that have been taken on the camera over the past 2 years...
Get all pictures to your PC and format card on PC(FAT32).
Try to put it in the camera.
If it's not going to work, pins are bent inside the camera's card reader.
Needs service.
May 26, 2010 | Olympus Camedia C-2500L Digital Camera
There is a delay from when I push the button to take a pic and the actual pic of a second maybe. How to get pic in the moment?
The delay is caused by the flash charging. Put the camera in Program mode (P on your dial). This is similar to Auto, but you can turn off the flash. Press the button with the lightning bolt by it until you see the same icon but with a slash through it in your LCD screen.
Now keep in mind taking pictures this way will often result in blurry pictures because you're overiding both the Autofocus (by pushing all the way down on the shutter instead of first half way), and the flash (you may need to keep the camera extra steady in low light situations).
Nov 15, 2009 | Canon PowerShot A75 Digital Camera
What can i do when my digital camera suddently says no photos when i didnt delete any of them i dont know why this happened randomly. also i holds 300 pics, before it was working funny i had 171 pics on my...
Take the memory card to a camera store and ask for a data recovery. As long as you do not take any pictures on that card until after the data is recovered you may get most or all you pictures back. If you take pictures over the ones on the card they are lost forever.
Jul 08, 2009 | Cameras
Funny coloured screen when i turn on the camera
did someone find the solution ; let me know.. best regards theodore
[email protected]
Jun 08, 2008 | Nikon COOLPIX S200 Digital Camera
Miss all the action shots with this camera
The longest part of the shutter delay is caused by the autofocus mechanism. Most cameras will let you press the button half-way down and wait until the autofocus is locked. Then wait for the action to occur. When you press the button the remaining distance, there will be a shutter delay of about 0.2 seconds before the picture is taken. Using that technique will let you capture action shots. There is no way to improve shutter delay on any particular camera. The newer digital cameras are showing improvement in this area. Some are achieving autofocus lock in 0.4 seconds and shutter delay of an additional 0.1 seconds.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Olympus Camedia C-2500L Digital Camera Logo
104 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
