Question about Dynex Wireless Optical Laptop Mouse
Range? How far away from the base unit can the mouse be? Mine seems only to work 2-3 feet away? Is there a way to extend the range?
    Problem Solver:
  • 39 Answers
Hey,
regarding the range i dont think its this less i mean 2-3 feet, mine works at some 5 feet also
Try replacing the batteries, if that doesnt help i guess the receiver is not able to receive the signals properly because of some obstruction. Try and put the mouse in clear sight of the receiver.
If still the problem persists.. check out your mouse range from its website.
Cheers
Kushal
Posted on Aug 27, 2008
Have an EDIMAX range extender. Extender showing connected to router with no problems. Tried connecting my tablet and mobile to range extender and both come up with "Authentication Problem".
Have an EDIMAX range extender. Extender showing connected to router with no problems. Tried connecting my tablet and mobile to range extender and both come up with "Authentication Problem" Wireless Mouse AmanStino ML11 2 4G Cordless Mouse with USB Nano Receiver...
Nov 29, 2016 | Tablets & eReaders
I have binatone luna 1220 phone but on the screen it says 'OUT OF RANGE' WHAT DOES IT MEAN?
If the display says out of range, it means it can't connect to the base station. Could be because it is to far away, or it is switched of, disconnected from the mains or just defect.
Nov 24, 2014 | Binatone Lands Phones
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
What is an out of range indicator
Out of range means your hand set cannot communicate with its base set. Several possibilities ... one ... you are simply too far away (more than 100 <> feet) ... two ... you have battery issues ... three ... you have metal based wall paper on the walls of your home. There are other reasons ... these are the ones I have had experience with.
Thanks for your interest in FixYa.com ... please evaluate this response.
Thanks.
Jul 05, 2010 | Coby 2.4GHZ SILVER Phone (CTP7000SVR)
Range out
You don't give much information to go on here; it would have been a great help if you'd added details of the make and model and whether the problem occurs some or all of the time.
Assuming it's a cordless home telephone then your phone is telling you that it cannot communicate with the base station. Typically this will be when you're too far away (out of range, hence "range out"). Too far away simply means that either the phone or base station antennas are not fully extended (not all models have external antennas though), or it can mean that there's too many solid walls/obstructions between the phone and the base station; these kinds of phones can also have problems with certain types of building construction. It can also be if there's interference on the carrier waveband, so try switching the base station and all phones to an alternative band if available. Other causes will be that the phone battery has been recharged to the point that it cannot hold sufficient power any more or that there's a fault with the base station. Any large metal objects close to the base station will also cause a weaker signal than normal.
I hope that I've helped, if so then please rate my answer. if not then please supply additional details and I or another expert will be able to provide a more relevant answer.
Mar 04, 2010 | Lands Phones
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
2 xTargus wireless mouse- both seem to be working on same freque
there is a range limit and if u move far enough apart they will stop interfering, or use differant mouse on one computer and kep other mouse for replacement
Jul 07, 2009 | Targus ACP50US Docking Station
My garage door opener remote range limitted
Yes the receiver can go bad over time and lose range. Most likely the receiver cost plus the labor will cost as much or more than a new unit...depending on who does the repair. FYI another cause of reduced remote range can be signal interference from other sources which would be a little harder to track down unfortunately. Wireless routers, new appliances anything with electronics are a possible source of trouble.If you or a neighbor bought any new gadgets there's a small possibility of thatbeing the issue. But based on the age of the unit that's my first guess.
Rustym62
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless Networking
try this this is a very very good info site
Apr 24, 2008 | NetGear WG111 802.11g/b Wireless Adapter
How to extend the range of my MN-700 Base Station
Hi Entry Level Extenders (or by their real technological name Repeaters) are chipset dependent and therefore guaranteed to work with Hardware of the same Brand. You can try to build your Own Extender. Buy two Access Points (AP) one of them has to be able to be configured as Client. Configure the client AP to communicate to the MN-700 and then plug the second AP to it and configure it as a regular AP. Put the concoction in the middle of the way between the MN-700 and the destination computer. Doing such an arrangement might cost a little more, and be a little bulky. On the other hand it would not cut the bandwidth into Half as Repeaters do. Otherwise may be this can Help. Extending Distance: http://www.ezlan.net/Distance.html Wireless Bridging: http://www.ezlan.net/bridging Wireless Segregation: http://www.ezlan.net/shield.html
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Dynex Wireless Optical Laptop Mouse Logo
115 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
