Question about Panasonic Lumix DMC-FZ2 Digital Camera
Landscape picture
It is recommanded to set F-stop to F8.0 all the time for landscape picture or a value of F4.0?
    Master:
  • 903 Answers
You don't normally want to focus on infinity for landscape shots. Auto focus on mid distance between you and infinity [horizon or most distant object] while half holding down shutter button re compose your pic and shoot. Depth of field will help to ensure that everything is in focus larger F stop more depth of field. f2.8 minimum depth of field. This is digital, film is cheap :-) Using the same focus spot, take one shot at each aperture and decide which aperture gives the desired results in terms of sharpness, I think you will find that will be around f4. Then try different focusing spot [closer or further away] to adjust how much between you and infinity is in focus depending on the results YOU wish to achieve.
Posted on Sep 06, 2005
We have an outside landscape light time that has quit working. Model pb115m1. Do you carry these?
Fixya does not sell timers or parts.
Timer system is not identified for certain.
If landscape system still turns on-off with override switch, then you can work around and buy cheap plug-in timer, set landscape to override, and plug landscape system into cheap timer.
Open following link for low voltage transformer resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more help.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 28, 2011 | Hardware & Accessories
What is a landscape?]
hi, are your referring with the document landscape?...
Landscape is the settings of the file on which you can expand the width of the picture or documents, it also gives you a more space size in terms of horizontal spaces, rather than a portrait...
Aug 20, 2011 | Computers & Internet
My copier at work is copying my work In the landscape mode, I need it in the Portrait mode. Help me , phone # 718-617-5586
are you sure that drawer did you choice ? I mean, you must select paper drawer.
first drawer is A4 (portrait)
second drawer F4/Folio/U2 (landscape)
third drawer....
see on the display...
May 03, 2011 | Canon imageRUNNER C3200 Copier
Can't get it to print landscape in microsoft word
If the printer is set up to over-ride program settings then your Word settings for a landscape print will be ignored. To fix this, go to your Printer Settings (accessible from Word's Print window) and look for a paper settings option that will allow the printer to either use the print settings from Word, or set the printer to always print in landscape. If you go with the second option just remember that next time you want to print portrait pages you'll have to revert this setting from landscape to portrait.
Jan 14, 2011 | Kodak ESP 5 Printer
I somehow put my camera setting onto panorama, how do i change this back to normal?
I think you mean Landscape. Just push the button next to the top display panel. Push it again until it shows the setting you want.
Panorama is not available on the QTsi. Panorama mode blocks out the top and bottom of the frame to give you a shorter picture top to bottom.
Landscape mode just biases the camera towards smaller lens openings to get more of the image in focus. By default, this makes exposure times longer, so use a tripod for landscape images.
lightspiritphotography.com
Dec 11, 2009 | Konica Minolta Maxxum QTsi with 35-80 lens...
3000z Landscape Mode Broken!
If you are thinking you need to get to minimum aperture to maximize depth of field, keep in mind that the depth of field is determined by the PHYSICAL size of the iris, not the RELATIVE value (which is what the f-stop measures) -- for example, on a 35 mm camera, a 28 mm lens at f5.6 will have much greater dof than a 200mm lens at f5.6 - because the actual iris opening is effectively 5 mm on the wideangle, but almost 36 mm on the telephoto. The physical apertures on digital cams, with their MUCH shorter real (not 35mm equiv) focal lengths, range from effectively about 7 mm at max telephoto wide open to *less than 1mm* at wide angle stopped all the way down. The issue with digicams is not that you have too little dof, but that it is a real pain in the a$$ to try and not have too much dof for portraits and such. I'm guessing the Epson firmware deliberately tries to avoid the max aperture for two reasons - to avoid camera shake at slow shutter speeds (are you shooting at telephoto zoom lengths?) and to avoid essentially turning the camera into a pinhole Brownie, with the inherent edge distortion that will occur. You seem to have written off the epson and are looking (really hard, IMO) for reasons to make sure that you've made the right decision. If you are unhappy with it, it will be hard to swing the pendulum in the other direction (speaking from personal experience after I bought a Kodak 240 and decided I wanted something "more"). You might as well return it and move on to the next contestant.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Difference between Auto Picture/Program Mode
Auto Picture-selects on of the picture mode such as landscape(mountain), macro(flower), sport/action(running man) mode, etc. P-sets shutter and aperture. You set everything else. happy face- sets shutter, aperture and everything else.
Sep 08, 2005 | Pentax *ist DS Digital Camera
The best situation to use each of the shooting modes
The shooting modes are described as follows: AUTO (Factory default setting) Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. SCENE Scene mode enables you to select one of the following scene shooting modes available in the menu. Landscape + Scene shooting Landscape + Scene shooting is suitable for taking pictures of landscapes and other outdoor scenes. This mode produces clear, sharp pictures with excellent detail, making it ideal for shooting natural scenery. Landscape + Portrait shooting Landscape + Portrait shooting is suitable for taking photos of both your subject and the background. The picture is taken with the background as well as the subject in the foreground in focus. The camera automatically sets the optimal shooting settings QuickTime Movie Quicktime Movie mode lets you record movies. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. My Mode Enables you to make settings manually and register them in the mode dial's mode so you can call up your own shooting mode whenever you want. Program shooting (P) Program shooting allows you to shoot using an aperture and shutter speed that the camera sets. You can set the flash, white balance, or other functions manually. Aperture priority shooting (A) Aperture priority shooting allows you to set the aperture manually. The camera sets the shutter speed automatically. By decreasing the aperture value (F-number), the camera will focus within a smaller range, producing a picture with a blurred background. Increasing the value will let the camera focus over a wider range in the forward and backward directions, resulting in a picture in which
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Shooting modes
What is the best situation to use each of the shooting modes? The shooting modes are described as follows: Program Auto (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Landscape + Portrait mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies with sound. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
Panasonic Lumix DMC-FZ2 Digital Camera Logo
101 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
