LG LSK 243H-1 Air COnditioner
Cannot seem to make it heat up, even when I put it on to 30c it still blows cold air.....any suggestions...do not have the owners manual!!!!
30c is 86F. I have the same problem.
Posted on Sep 20, 2008
Hey, all I know is 100*c= 212*f 50*c=100*f so 30*c=50-60*f try to change your centigrade to fahenheit! thank you very much!
Posted on Aug 27, 2008
My LG Model LP0910WNRY2 will not get cold even though the compressor turns on
check the outside and see if its blowing cold air out of condensor otherwise low on freon.
Jun 28, 2014 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
LG LS-D2461HS air con on turn on just blows air out. no heat or cod air at all even when temperature setting increased to 30 degree for cold air.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 27, 2011 | LG Heating & Cooling
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
Only blowing cool air, even having set on 30C on remote. No user manual.
Mate, I had exactly the same problem. When I set the thermometer to 30c it cut out, then five minutes later it started blowing hot air out. Hope this helps!
Apr 27, 2009 | Heating & Cooling
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Jan 30, 2009 | LG LSC121PMA Split System Air Conditioner
My Heater blows cold air
is this a gas furnace if so does the burner ignite
Nov 25, 2008 | Intertherm P3RA-048K Air Conditioner
Hi i have a cs-w24ekr air conditioner. The problem is it blow's cold air when set to heat even at 28degrees.
you have pressed the mode button on remote until it has said heat aswell? becasue 28 degrees in cool mode will still seem cold unless the mode is also set to heat.
Aug 12, 2008 | Panasonic Heating & Cooling
LWHD1200HR - LG 12000 BTU Heat / Cool Window Air Conditioner
i have a lg lwhd 1200hr window ac the heating system dont work . it blow cold air out not heat. can you help me
May 28, 2008 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
297 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
