Question about Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 6 red flashes and i replaced the thermostat, no change
I followed the link on the post and bought the part for the tv, replaced the thermostat and still get the 6 red flashes
  • Jeff Souza
    Jeff Souza Sep 15, 2008
    i ordered another thermostat from that should be here in 5 days, if that does not work i might kick the screen in. ok maybe not. it did the exact same thing as before, light turns green for 1 second then 6 red flashes over and over. i called and they have two part numbers to the same thermostat and that was why the ones i have now (old one and the first replacement) have diffrent numbers on them.
  • Jeff Souza
    Jeff Souza Sep 02, 2009
    ya i do have a meter and know how to use it i just gave up on it for a while but i want to get it fixed to give to my friend. i replace the thermal but no luck there. i have heard that it could be the G board but i want to confirm that but i dont know witch one it is. do u have any service info on it. id like to get this thing going soon.
  • 1,952 Answers
E.. Sony KDF-E42A10 6 red flashes and i... I followed the link on the post and bought the part for the tv, replaced the thermostat and still. ... -
Posted on Sep 15, 2008
  • 203 Answers
I have never seen the thermal fuse replacement not fix this problem. What is the part number that you put in the set? Do you know how to use a meter? After you replaced the thermal sensor did the set try to come on at all? or was it the same exact problem as before?
Let me know
When i turn on the tv the power light starts blinking red and it turns off
Hi I have a Sony KDF-55WF655 and I just installed a new lamp, now when I got to turn on the tv my power light flashes 5 green followed by 6 red flashes and continues to flash a series of 6 red flashes and has no pic, Any help would be great
Jul 13, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Overheat issue on kdf-50we655 sony tv
this link tells about the blinking and how it's an self-diagnostic system that the tvs are programmed with. the number of blinks indicates the problem.
Jul 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV won't turn on and red light flashes 6 times.
Jul 14, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Tv just shut off and red light is flashing
Most Sony 6-blink codes for projection TVs follow this pattern:
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV turned off by itself and now blinks red led 6 times
6 blinks means a low B error. Which is no DD 6volt output on G1 board . This will cause no picture and no sound. To fix this yourself you would need the manual to get the correct sequence to test and proper part to order. You can get a service manual for 10.99 at the following link and they will ask if you'd like it emailed to you after purchase. Here is the link,
Feb 01, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
KDF-E60A20 Going on and off by blinking lights
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Dec 05, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
5 red flashes on your Sony indicates the power supply for lamp is not working .Or 5 pin harness to it is not seated properly.Possibly needs replacement..
Aug 01, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-E42A10 42 in. LCD Television Logo
269 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
