I have a Panasonic DMR HS2 dvd recorder which did work fine except when the dvd holding unit would get stuck and after when times of taking it apart I accidentally tore the about 2 1/2 inch ribbon cable that connects the dvd drive board to the rest of the unit. I need to replace this ribbon cable.
  • jpeb237 Aug 26, 2008
    I did that first but they needed the numbers to which it connected
    and the only numbers they had that would relate to the boards I
    gave them and they just left me hanging. ,I sent them another
    copy and I still never heard from them. There are no numbers. I
    gave them the name and description on the ribbon cable, which is the same on any place a ribbon cable is connected
  • jpeb237 Aug 27, 2008
    I have opened the unit many many times there is no number where
    the cables connect. That is how I tore the cable in the first place. The dvd gets stuck in the drive the recorder goes into a recovery mode but never recovers until you get the DVD out and the only way to get
    it out is to take the unit and physically take the DVD .
  • 6,487 Answers
Probably there''s some piece of mechanism there that is still not align or connected properly why you still have this problem, so better open it again and double check all the mechanism of the player..
Good luck.......
Posted on Aug 27, 2008
  • 157 Answers
Should be simple to replace. First verify if the dvd drive is sata or ide/pata . Then buy a cable that suits best ur DVD drive and attach it.
Cheers
Posted on Aug 26, 2008
  • 928 Answers
Try calling www.shopjimmy.com the number is on the top left you can request a part and normally they specialize in hard to find parts.
    Master:
  • 521 Answers
For that you have to open the unit.its very very simple.
  • 19,396 Answers
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: broken cable
Here is one of the biggest parts dealer
If you cannot identify the part number contact them calling
(800) 648 - 6657
(708) 946 - 9500
SOURCE: FINDING A PART FOR A DVD RECORDER DMR HS2PP
Is it a flat 40 contact (Zif cable) Panasonic uses those in a lot of their products?
http://www.sourcingmap.com/zif-micro-ide-hdd-adapter-converter-p-32516.html
Posted on Nov 25, 2009
I want to reset the reorder but i don't know how.
If you do not have your original instruction manual, you can download a free pdf from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-HS2
(right-click and save link/target as... - it is a 3.2MB file (total size))
It may or may not help. Either way it's free.
Apr 25, 2011 | Panasonic DMR-HS2 DVD Recorder
Panasonic dmr-hs2 dvd recorder / player disc stuck in door will not open
try opening the cabinet and release the friction
Thanks for using Fixya
Jul 06, 2008 | Panasonic Televison & Video
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
My Panasonic DMR-EZ17 DVD Recorder keeps saying
You have to use the remote for this unit or a remote for a similar dvd recorder, when you have it hold the enter/ok button and the number 1 or which ever number your stuck on 2 or 3 for 5 second and then go into setup and change it to the one you want RC1 ,2 or 3 !
Jun 26, 2010 | Panasonic DMR-EZ17 DVD Recorder
Remote control doesnt work
Go to the manu and try new remote code, Hopefully by changing remote code, from Codeset 2, to code set 1
will solve your problem.
Jan 17, 2009 | Panasonic DMR-HS2 DVD Recorder
My panasonic dvd recorder dmr-hs2 keeps switching to standby mode
I have the same problem, but it takes a while longer...just get the circle rotating in the LCD on DVD!
tried unplugging HDD...still does it.
Jan 13, 2009 | Panasonic DMR-HS2 DVD Recorder
I got no help. I just gave up. The 9.99 was just thrown away. I needed to find a cable for dvd recorder which connects to the
dvd drive and all they were telling me was stuff I had already done
and places I had already looked but still no part , part no. NO
HELP THanks for nothing...
Aug 27, 2008 | Televison & Video
Broken cable
(800) 648 - 6657
(708) 946 - 9500
Aug 26, 2008 | Televison & Video
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
