Question about Olympus Camedia C-2500L Digital Camera
When I printed the photos none of them was even close to film-based photos
I got my C-2500L yesterday. This is my first digital camera. I shot a dozen SHQ frames last night. They all look great on the monitor. But when I printed them with my Lexmark 3200 (1200 by 1200 dpi), using photo papers, none of them was even close to film-based photos (4 by 6). Could anyone please tell me if I need to get a better printer/better paper, or just improve my skill? I greatly appreciate your help.
    Master:
  • 852 Answers
Try using a good program like Photoshop and when you adjust for printing...make sure you DO NOT subsample the image so it can fit on a 4x6 photo paper page. What I mean by that, is in fact reduce the image to fit on such a small page but do not kill the resolution.... In Photoshop, you would open up Image Size under the Image menu and turn uncheck resample image...as you adjust for paper size...you will notice that your resolution stays intact on the top of the window. I assume that is your problem since the 2500 is highres and should give you fantastic results in a 4x6 format.....
Posted on Sep 06, 2005
SOURCE:
Film is not developing
There is not any in camera developing. This is not a digital camera it is a film camera wherein we put a film cartridge with a specified number of shots into the camera then thread the film leader to the takeup spool, close the camera advance the film a few frames, then we are ready to shoot. After the specified number of shots, 24 or 36, film is rewound into the canister, camera back opened film canister removed then taken to the lab for processing.
Oct 04, 2012 | Pentax ME Super 35mm SLR Camera
My pictures are all coming out very blurry
With digital cameras, blurred photos are almost always a result of camera shake. You need to hold the camera still even after pressing the button, as there is often a short delay before the shutter fires.
Many digital cameras have a two-stage shutter press- first pressure causes the camera to focus, then the follow through pressure takes the picture. If you are rushing this, you may get unfocussed shots.
Finally, make sure that you have not left the camera in Macro mode. This is a special extreme close-up mode offered by some cameras, and it does not allow autofocus on objects at normal distances. The icon for Macro mode is a little flower.
If none of these is the problem, there may be a fault requiring service (probably not economically viable unless they will do it under warranty).
Nov 26, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Question on SnapSights waterproof camera
The SnapSights SS03 is a non waterproof camera supplied with 200 ISO film so you clearly have the SS01 model for 800 ISO. Both cameras have fixed aperture and shutter speed and rely on the wide exposure latitude of print film. 100 ISO is ideal if you have a camera with a wider aperture than yours, but if you use it then photos will be three stops underexposed; you'd possibly get away with this on land but underwater shots typically have more shadows than highlights and you'd lose a lot of photographic detail. By using 800 ISO the camera will produce photos which are noticeably grainy and with high contrast demonstrated by less detail in shadow areas and overexposed highlights, but for most purposes the photos will be acceptable and far better than none at all.
Colour negative film has a wide exposure latitude so you may wish to experiment with using 400 ISO or even 200 ISO. 400 will be one stop underexposed, but the printing stage can compensate to produce shots which are less grainy with better shadow details but which will lack some highlight detail. This can be partially compensated for if you tell the processing lab to "push process" your film at 800 ISO, but this will usually cost extra and for just one stop under I wouldn't bother, 200 ISO is really stretching it though and you may find that results are unacceptable unless you push process. Ultimately, it all depends upon how dark and how deep you go, but at much below 1,5m everything gets a strong blue colour cast anyway unless you use a powerful underwater strobe light mounted away from the lens axis.
Basically your camera is designed just to give you a taste of underwater photography and is very limited in what it can achieve. Even with a good specialist 35mm underwater camera such as the Sea & Sea MotorMarine II I usually find that I only have one or two usable shots on a 36 exposure roll, so if you do get the underwater photography bug then invest in a decent quality underwater digital model which accepts a proper external strobe lamp. The ratio of failed photos is similar, but at least you can review and delete them immediately without expense.
Jan 09, 2010 | SnapSights Intova Snap Sights SS03 Film...
Dear experts! i have a G9 powershot camera, and yesterday i have encounterd a problem.....the screen is not showing any image and i have checked and it is not the display button...it's like trying to take...
If it takes normal pictures even with the black display, your LCD display is likely shot. If photos come out black, chances are that your shutter is stuck in the closed position. Sorry, but there is no safe DIY fix for either problem The camera will require professional repair.
Nov 15, 2009 | Canon PowerShot G9 Digital Camera
Ixus 750 Blurred photos shot at a distance greater than a meter.
Check to see that the camera is not in "macro" mode, which would only allow focusing at a close range, but not allow focusing at beyond about 2 meters (look for the "flower" symbol to tell you that macro is activated). Could also be an out of adjustment lens, due to impact or force. Also check to make sure it's not as simple as a dirty lens. Digital cameras are more succeptable to blurry pictures from a smudged lens than film cameras were. Of course, that wouldn't explain why close shots are OK but distant ones aren't. Probably the first two suggestions.
Oct 06, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Olympus ilp 100 photo printer
make sure you are using the correct type of paper. If you aren't using the long kind with the perforated edges then it isn't going to feed.
Nov 13, 2007 | Olympus D-555 Zoom Digital Camera
Panoramic pictures??
A panoramic photo on 35mm film is just cutting off the top and bottom. even if you can't set the camera that way, you can ask your local photo store to print any shot that way for you. Usually 2x the price of 4x6.
Sep 13, 2007 | Minolta Freedom Zoom 115 QD 35mm Point and...
Sony Cyber-Shot Optical Zoom 3X
Still photos (what you think of as printable photos) and movies (video clips) are completely different beasts, unfortunately. In order to extract or print individual frames within a movie, you will need some sort of movie player/editor software. Standard "photo"-oriented software won't know how to deal with video clips.
Mar 16, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Olympus Camedia C-2500L Digital Camera Logo
37 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
