Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool Gold Conquest
The ice maker will not dispense the ice through the door. We called the authorized service dealer once before and the repairman who came out said that the problem was caused by using the crushed ice feature versus the cubed ice. He defrosted the freezer, and reset it, and left. It worked for a couple of hours only and stopped again and no one used the crush ice feature. This refridgerator is only 9 months old. I am afraid that if we call the service dealer again they will say the same thing and not fix whatever is causing this problem. Can you tell me what I should say to the repairman to help him find and fix the problem?
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Okay here we go,Good advice!
You have manufacturer's warranty for 12 moths!
Do not be afraid to call service every week if necessary!
Try the service I recommend to my customers!
They are nation wide!
Be firm!!!!!!!!!!!! Do not give up till they repair the problem! And if they come out again.After that second time demand that Whirlpool replaces the fridge! They call this a push pull!
Whirlpool gets a authorized retailer to deliver the same model fridge for free and remove the problem one to be sent back!
YOU PAY NOTHING NOT EVEN DELIVERY OR PICK-UP!
Whirlpool has a special dept. that does this!
Follow my advice and do the switch if it's not good after this repair.
DO NOT WAIT!!!!!!!!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
I purchased a new whirlpool conquest and have had on for two days. i have water coming out of the water dispenser but still no ice production. There is no water in the chute leading to the ice maker. ...
Maybe it won't call for water until it goes through the cycle. Try putting water in the ice mold and see if it starts working when it freezes and dumps the ice. Make sure the water line is open by swapping the wires on the dual water inlet valve. Then the water dispenser will send water to the ice maker and you'll know the valve and line works.
Sep 01, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker does not work, but water dispenser does
you may have a bad icemaker or water valve or defrost problem i thinh you should call service
Apr 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser working but ice maker not working
is water is in side ice maker if not check hose at the back if water in icemaker call for service
Mar 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not dispense the ice
When you press the lever to dispense the ice, there are multiple switches being activated. Chances are, the one that moves the motor to turn out the ice is bad. Or that motor itself is bad.
Mar 13, 2009 | Whirlpool GS6SHAXLB / GS6SHAXLL /...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Conquest UltraEase Plus Water Filtration System ice dispenser
DEAR FRIEND,
It is not worth doing it your self!!!!
Sometimes its not easy to find out what part is bad on a
side X side with ice and water on the door, even for the trained tech. call service!
Not expensive!
A&E Factory Service
Thank You
Bless you,ngfam1
Aug 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
120 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
