Question about Dell Inspiron 5160 Notebook
Power on immediately powers off
I put some of that "grease" on the processor, after straightening out a couple of pins on the processor, re-installed it and same thing. The laptop turns off after about 4-5 secs of being turned on.
Any other suggestions?
By the way...thanks for your help on this.
  • Dell Master
  • 3,051 Answers
Ok i see can u tell me what happness if you take out the battery and try to start it
Posted on Aug 27, 2008
Front end lube
Look for small threaded plugs and remove them and install grease fittings. If that doesn't improve the turn effort you may have a defective power steering pump or a defective steering rack and pinion
Mar 21, 2014 | 2002 Volvo S60
P6TD fusible resitor blown near memory P0207?
What a minute hold the phone here!
Those are Ferrite Iron Choke Coils.
The 'little round cans' with the Red(?) edge on top, are Solid Polymer Capacitors, going around the processor socket.
Those are Ferrite Choke Coils going around the top side of the processor socket, immediately near the copper heat pipe fins. (Black/Square shaped top, rectangular shaped body)
The choke coils, and solid capacitors are part of the Motherboard Voltage Regulator Circuit. These particular ones are for the processor.
The ones down by the Ram Memory slots are also in the Motherboard Voltage Regulator Circuit.
May be for the Ram Memory slots, but easily could also be for the expansion slots, too. (PCI-E x16, PCI-E x1, PCI, etc)
Here is more info on the Motherboard Voltage Regulator Circuit,
http://www.hardwaresecrets.com/article/616
So; Are you using the correct voltage ram memory, or have you installed 'performance stuff', and had to change voltage in BIOS Setup?
More importantly,
1) Are you running a graphics card?
2) More than one?
3) Have the proper amount of power, (Wattage and 12 Volt power rail/s)
4) Proper power cables from Power Supply?
4) Same thing for the motherboard;
IF, you are using a Processor that requires a LOT of Wattage, and you are using a graphics card; are you plugging in an 8-pin EPS +12 Volt power cable into the motherboard?
The 8-pin EPS +12 Volt power cable connector, is called an EATX12V power cable connector by Asus. It's up at the top edge of the motherboard, above the top left corner of the processor socket.
Called EATX12V to keep people from confusing it with this power cable,
They are NOT the same;
EATX12V, or EPS +12 Volt power cable; has FOUR Yellow wires.
A Yellow insulated wire is a 12 Volt wire. Black wires are Ground wires.
An 8-pin PCI Express power cable has THREE Yellow wires, and FIVE Black wires.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
BOTH, a 4-pin ATX +12 Volt power cable, and an 8-pin EPS +12 Volt power cable; are power for the PROCESSOR.
Quad-Core, or a processor that uses this much power? 8-pin EPS +12 Volt power cable.
The MAXIMUM amount of Wattage a PCI-Express x16 slot can deliver is 75 Watts.
EACH 6-pin PCI Express power cable is capable of delivering 75 Watts.
Total of 150 Watts available for a graphics card.
An 8-pin PCI Express power cable is capable of delivering 150 Watts by itself.
Point?
Use the correct power cable IF needed for the graphics card, and the correct number of them if two are required.
Also; IF you did not have the correct power cables; AND used a power adapter cable, USE all of the required 4-pin Peripheral power cables needed, for that power adapter cable.
For example;
I have noted those who did not have TWO 4-pin Peripheral power cables, required for a 6-pin PCI Express adapter power cable.
Just one was available, and just one was used.........
!O_O!
Nope!
This will result in;
1) PCI Express x16 slot contact pins - Burn
2) Gold plated contact pins on bottom of PCI-Express graphics card -Burn
3) 6-pin PCI Express power cable connection on graphics card - Burns
4) Contact pins in connector for 6-pin PCI Express power cable - Burns
That to me could also result in damage to electronic components, in the Motherboard Voltage Regulator Circuit;
Hence -> Ferrite Iron Choke Coils
Awaiting your response,
Regards,
joecoolvette
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Oct 30, 2012 | ASUS P6TD DELUXE Motherboard LGA 1366...
What is the difference between a pin less and pin processor?
A pin processor have the pins at its bottom which merges in to the motherboard!
A pinless processor has no pins.pinless processor has a flat bottom with around an extra 297 connections to the motherboard. You cant fit one to a pinned socket. vote me if it is helpful
Sep 20, 2011 | Intel Core Duo T2600, 2.16 GHz Core Duo...
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I changed my cpu fan out, when i started it up it ran 30sec and shut down. So i replaced new mother board without fan., it still shuts down after a few sec. I disconected the 4 pin power source and it will...
From your problem description it sounds like the CPU was overheated (and failed) before you replaced the CPU fan - so the fan replacement was too late. Since the procesor already failed, installing a new motherboard without a fan did not accomplish anything.
The 4 pin power plug provides +12 volts DC to the processor. When you disconnected it, the processor essentially could not run at all and the system is no longer capable of detecting the CPU failure and shutting down the power supply.
You need to install a known good CPU which is the right type and speed for your computer. Unless you are experienced in replacing,CPU's, fans, heat-sinks and applying thermal grease I recommend that you have a PC technician perform these tasks.
If you believe that this information is of value to you please rate me on the FixYa website.
Regards,
Yavacotech
Nov 29, 2010 | Computers & Internet
The bios chip,if removed,wich way does it go back in?and if it was put back in upsidedown,and the power turned back on,would it be damaged?..thank you,michael and can i use another one from a different pc?
Look at the chip one corner will be cut off and look at the pins if they are bent you have to straighten them first if you powered it up and did not have it in the right way it may have destroyed the chip. The pins have one corner missing on the chip and on the chip socket you will see it has one pin missing in the corner. also you need to use the dielectric grease on the heat sink before installing the fan or it will overheat the chip good luck hope this helps.
Dec 24, 2009 | EliteGroup K7S5A Pro Motherboard
I have install a new mother board, but when i power the computer the power come on, but no response on the monitor
Or reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 15, 2009 | Asrock K7S41GX SiS741GX Mainboard...
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
No beeps noboot only fans spinning
Skotock, My guess is that you damaged your processor or some thermal grease (paste-like material that physically bonds your heatsink to your processor) is shorting something. Unplug your power cord, remove the heatsink and processor. Check the processor for surface cracks and bent pins. Make sure NONE of the thermal grease has oozed over the edge of the processor onto either the processor pins or the motherboard itself. This material is both thermally and electrically conductive and can cause shorts. If you don?t find anything let us know and provide us with as much details about exactly what you did and how so that we can continue to troubleshoot. If this did solve your problem please let us know and don?t forget to rate this posting.
Feb 19, 2007 | Shuttle AV40S Motherboard
Dell Inspiron 5160 Notebook Logo
27 people viewed this question
Alun Cox
