Question about Maytag Dryers
Sock went up the dryer vent - Maytag Dryers
  • 550 Answers
Unplug dryer
on the bottom of the front panel, just where it bends in to form a kick plate, there are two screws, remove them.
  • may be torx secure screws, cut a slot in the head and use a flat screwdriver, or buy a #2 torx secure bit at the local tool store, replace with phillips or flat screws, easier next time
swing front panel forward and up from the bottom, unhook from upper catches, unplug door switch wires
set front panel aside.
dryer vent is accessible, the screen holder comes away with the door.
the sock should be visible in the pipe, it should not have been able to proceed beyond the fan, the space between fan blades is too small
just in case, do not operate without screen fitted, or with holes in screen, as well as sox, lint will build up and block the exhaust vent, dryer will overheat and blow thermal fuse
reassemble in reverse order
Posted on Aug 27, 2008
I ran the dryer without the lint screen and am now 'missing' some socks. The dryer makes a rumbling noise. How do I get the socks out and did I break something
you better inspect inside the exhaust vent tubes for the socks. You did not break anything but they might start on fire later. You to take off the back of the dryer to take the vents apart.
Feb 17, 2015 | Samsung DV330AE DV330 Large Capacity...
LG2701V stopped working after lint trap was not in place
Pull the dry out and clean (UNPLUG IT FIRST) out the entire exhaust vent system..
Sep 20, 2017 | LG DLE2701 Electric Dryer
Ihave a whirlpool gas dryer and my wife droped a sock into the hole where the filter is. Made some noise and then seemed to work just fine. Where did the sock go and shoukd I be worried? Thank you
the sock ended up down below at the bottom where the vent fan blows, I would remove the back of the machine,, remove the vent housing inside, and you'll see the fan which runs off the back of the motor,, ( and probably the sock) and remove it , and any other debris thats collected there, Its a fairly simple task
May 26, 2011 | Whirlpool CGE2791KQ Gas Commercial Dryer
I have a wdr1242 washer dryer the dryer seems to take forever to dry clothes sometimes 2 hours or more even for just half a dozen socks
If your dryer is still heating up; Check the dryer vent hose, also check down inside where the lint screen goes. If no lint is obstructing there, check the exterior dryer vent. Sometimes you have a screen to keep birds and rodents out of there, and may become clogged with lint. If no screen, check inside the flap, maybe someone moved in, or dryer lint is clogging up your exterior vent.
Dec 08, 2010 | Tricity Bendix WDR1040W Front Load Washer...
Takes extra time to dry the clothes.
You may need to clean out your lint trap. Not just the part that you pull out. I'm talking about the entire tunnel. Even though we empty the lint trap regularly there's a lot that gets left behind and over time can become a fire hazard. Your arms and hands cannot reach everywhere in there. For this you can attach an old sock or rag to a coat hanger that has been opened up. Go down in there a couple of times with it. You'll be surprised at how much stuff comes out. To further help this problem you can also pull dryer out and check that the vent hose in back is clear and free of debris. Cleaning the trap screen (the part you pull out to empty the lint) with HOT water occasionally will also clear residue that has built up from using dryer sheets. Over time that residue will make those tiny screen holes smaller & smaller & smaller. All of this can affect your dryer's performance.
I hope this info was helpful to you. Good luck!
Jan 29, 2010 | Whirlpool GEW9250 Electric Dryer
Model 87577800 sock went thru the lint vent
The model number you have listed has the dryer vent on top of the dryer. Small items commonly fall down into the vent chute on these dryers. Articles can easily be retrieved by following these steps:
1. UNPLUG the dryer. Dangerous voltage is still present inside a dryer even when it is turned off.
2. Remove the lint screen and remove the two screws that connect the vent chute to the top panel.
3. Turn the dryer around so you can access the rear, and remove the exhaust vent hose.
4. Locate and loosen all the screws from the perimeter of the dryer back panel.
5. Remove the back panel of the dryer.
The air blower assembly and dryer vent chute are located on the left hand side (as viewed from the rear of the dryer). Remove the screws that hold the vent chute in place and you will be able to access anything that has fallen into it.
NOTE: Anything left in the vent can eventually get caught in the blower fan. So, it is important to retrieve anything caught in this area to prevent damage to the fan and to ensure the dryer ventilates properly.
If you have any questions about these procedures, please let me know. I hope this helps you.
Oct 27, 2009 | Dryers
Sock fell down lint vent and daughter turned on dryer
Turn off you power to the dryer and then,
You could run a coat hanger straightened out with a hook bent on the end of it into the lint vent at try to hook the sock.
But probably you will have to remove the back to follow the lint vent.
You may try to remove the vent hose and run the straightened coat hanger in there to try and remove the sock.
Hope this helps
Sep 30, 2009 | Whirlpool LEQ8000JQ Electric Dryer
I ran the dryer without the lint filter in it and now it is noisy
First of all, You have a serious safety issue. Your dryer may catch fire. DO NOT USE YOUR DRYER.
Something went into the mechanism (yes, may be another sock), and a lot of lint went inside the dryer. The dryer needs to be cleaned by a technician. Using the dryer on its condition may cause a fire. Don't get your house burned down just to save some money doing it by yourself.
Aug 30, 2009 | LG DLE5977 Electric Dryer
A sock fell in the vent of my whirlpool dryer
If you mean the lint trap, try this: Unplug the dryer. With a dryer brush (~$10.00 @ Lowe's/similar), bend to approximate the curvature of your cavity and try to retrieve. If this doesn't work, slide/scoot the dryer out and remove the venting duct. Carry outside and dump. If no sock there, look into the dryer exhaust (where the duct connects). Use the brush again to retrieve said sock (and generally clean as you go, as it never hurts). Also look at your vent where your dryer exhaust passes through the wall, clean as you go..... This should get you back up and running.
Regards, --W/D--
Jul 17, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
