Question about Toshiba TLP-S10 Multimedia Projector
FAN ERROR From your experience with projectors, would you say the air flow sensor is embedded in the fan itself or is it elsewhere? Any idea what it looks like? Thanks again
  • 115 Answers
Hi'
Look like led or white plastic.
Viren
Posted on Sep 27, 2008
Symptoms of faulty air flow sensor
  • How to Detect and Clean a Faulty Mass Airflow Sensor ... www.carsdirect.com > Car Repair > Engine Repair 2012-02-24 · Symptoms of a Faulty Mass Air Flow Sensor ... Here are some of the most common symptoms of a faulty mass airflow sensor: ... CARSDIRECT IS AN ...
  • Mass Airflow Sensor: An Easy Fix for Big Problems from a ... www.airtexproducts.com/news-blog-mass-airflow-sensor-an-easy-fix... news,blog,mass,airflow,sensor,an,easy,fix,for,big,problems,from,a,little,instrument. ... Mass Airflow Sensor: ... What Are the Symptoms of a Faulty Mass Air Flow Sensor?
  • Signs & Symptoms of a Faulty Mass Air Flow Sensor www.geeksofcars.com/list_5794328_signs-mass-air-flow-sensor.html Signs & Symptoms of a Faulty Mass Air Flow Sensor. The Mass Air Flow Sensor is a device used on many fuel injected automobile engines to measure the density of air ...
  • See Bad Mass Airflow Sensor Symptoms on YouFixCars.com www.youfixcars.com/mass-airflow-sensor.html Video embedded · Mass airflow sensor problems can turn on the check engine light. They can also cause a variety of other symptoms before the ... How to clean mass air flow sensor ...
  • How to ' Tell If You Really Need a Mass Air Flow Sensor ... www.youtube.com/watch?v=aDlHCjgYf8s
    • BY AUTO REPAIR QUESTIONS ANSWERED BY WESLEY HARRISON
    • 4 MIN
    2011-08-22 · Video embedded · ... How To Clean a Mass Air Flow Meter and Tell if you really need ... Mass Air Flow Sensor ' Auto Repair ' Wesley Harrison ... Sensor Symptoms ...
  • Videos too.,
  • Go to Bing homepage
    Jul 09, 2016 | Cars & Trucks
    Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
    If power indicator light red and warning indicator red flashing than according to user manual :-
    The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
    Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
    2. If anyone fan not working
    so please you check fans.
    (If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
    Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
    Our PJ-TX10 projector is turning itself off
    First, to rule out true overheating, clean any dust filters and air-access areas. There might be enough dust on the filter to cause a gradual build-up of heat which could trip one of the temperature sensors in the unit. I clean my projector once a week--There might be a cooling fan going bad--after a while, heat causes the fan motor to start to drag and slows down the air flow. Also, there might be a temp sensor that is shutting down the unit prematurely.--Rick
    Sep 06, 2009 | Hitachi PJ-TX10 Multimedia Projector
    Optoma projector overheat issue - fan comes on but switches off
    Most projectors have air filters. Yours may need to be removed and cleaned. No air flow = overheat.
    May 28, 2009 | Optoma EP721 Projector
    TLP-S10 FAN ERROR
    I'm not familiar with your specific model, but I do work on projectors all the time (some as large as 35000 lumens). DO NOT touch the lens area. Any movement of those panels will require a reconvergence procedure which is neither easy nor cheap. Use canned air to clean the area of dust. That is about all you can do.
    Keep me posted.
    Dan
    Aug 26, 2008 | Toshiba TLP-S10 Multimedia Projector
    FAN ERROR BUT THE FANS WORK
    There are air flow sensors in the unit as well which you may have blocked up when you blew out the fans. If those sensors do not detect air flow, the assumption is that there is a fan error. Try removing the fan and cleaning the entire air flow path.
    Dan
    Canon W7200 Error code E02D05
    The Service Manual says:
    E02D05 Airflow fan error
    Fan rotation could not be detected while the air flowfan as running.
    Probable problem locations
    Air flow fan, engine controller, system controller
    Remedy
    1. Cable connection check (check - replace
    2. Replace air flow fan
    3. Replace engine controller
    4. Replace system controller
    I wish success
    AToe
    May 05, 2008 | Canon imagePROGRAF W7200 InkJet Printer
    Check Air Flow
    ok " sounds like you have a bad heat sensor , it will have to be replaced.
    Jan 21, 2008 | Hitachi Performa CP-RS55 Multimedia...
    Air flow
    Hi.
    Have you checked vents for blockages & ensure fan can rotate freely.
    Oct 09, 2007 | Televison & Video
    Displayed massege to check air flow
    With most projectors there is a foam air filter behind a grill that is the opening to the cooling channels. A fan ensures air flow to cool the lamp, etc. This filter prevents dust from gumming up the works (and depending on design) may prevent dust getting into the optics. As the filter gets dirty it gradually cuts off the air and at some point a protective circuit kicks in and turns off the lamp.
    If the projector is on you will feel a stream of hot air coming out of the exit vent. Projectors vary in terms of amount of air flow, so its difficult to define what is normal for a specific model. However, you can simply hold a hand in front of the vent and see if there is air flow (It will be hot air so, careful). If there is a "good" stream of air things are fine, but if only a very light flow is felt the filter may be dirty.
    If the filter has not been cleaned or replaced recently make sure the projector is turned off and cooled down then take off the inlet cover and remove the filter. Clean or replace per the instructions for the projector (and periodically as defined .. but taking into account the operating conditions). Once cleaned turn on the projector and feel the "normal" air current for future reference.
    Heat is one of the major causes of projector failure, so make sure cooling vents (inlet and outlet) are not obstructed and filters are kept clean
    Oct 02, 2006 | Hitachi CP-S240 Multimedia Projector
    Toshiba TLP-S10 Multimedia Projector Logo
    169 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
