Question about HP Office Equipment & Supplies
My HP Photosmart C6200 all-in-one is not responding to any command buttons. The view screen says "shutting down". I do not know how to proceed. I am unable to even make a simple photocopy.
  • Anonymous Nov 13, 2008
    do not have disc to install
    Problem Solver:
  • 12 Answers
Are U sure the cartdge install properly? when last time U the printer can be use? is that anything happend like paper jam or lightning strike before?
Posted on Aug 26, 2008
I am on my husbands computer, however, here is my problem. I had Vista Windows on my computer. It crashed and Windows 7 was installed. Now it will not let me install my printer. I have a HP Photosmart...
Go to HP's website (hp.com), click on Support & Drivers, do a search for "Photosmart C6280", click on "Photosmart C6280", download the drivers and software for Windows 7 (you'll need to know whether you've got the 32 or 64 bit version), then follow the install instructions.
Aug 04, 2011 | HP Photosmart C6280 Printer
My HP Photosmart C6280 will not scan documents to my computer. I have it connected to USB port on my wireless PC. I try scanning thru solution center and that does not work. I have turned off the computer,...
Solution
For Windows XP
*Go to Control Panel > Printers > HP Photosmart c6200 series > Right Click > select Delete
*Load the CD / Downloaded Software for HP c6200 series
*Select add a device > select usb (if preferred)/ wireless
*Wait for the installation to finished and repair the settings.
*Restart PC/ Try Scanning Again.
If it doesnt work, I suggest try uninstalling and reinstalling the software completely using the CD itself.
Hope this works. Good LUCK!
Feb 14, 2010 | HP Photosmart C6280 Printer
HP Photosmart C7280 All-in-one has stopped printing. Window just keep saying Shutting Down What next?
Just unplug it, wait a few seconds, then plug it in again. That should fix the problem.
I had the same problem - my Photosmart C7280 AIO displayed "Shutting Down" message all night, and would not respond to any buttons on the control panel, even holding down the Power On/Off button got no response. I was worried about a couple of ink cartridges that it had warned were low before I tried to shut down, so I replaced those.
After looking in the manual and online for troubleshooting help from HP and others, and finding nothing but a suggestion to unplug it (not on an HP site), I finally did unplug it, after first disconnecting the USB cable to prevent any trouble due to interaction with my Mac. Then I aited about 30 seconds, plugged it back in, turned it on, and it started up fine, with no apparent problem.
Jan 13, 2010 | HP Photosmart C7280 Laser Printer
Smple script for graceful shutdown of Windows OS
a simple batch file could be used
down.bat
@echo off
IF "%1"=="" GOTO DEFAULT
IF "%1"=="a" Shutdown -a
GOTO END
Shutdown -r -t %1
GOTO END
:DEFAULT
Shutdown -r -t 30
:END
This batch file accepts the inputs as follows
"down.bat" This will shutdown in 30 secs and is default
"down.bat 120" This shuts down in 2 mins
"down.bat a" This aborts any shutdown operation.
Hope this is what your after
May 07, 2009 | HP 3000 XR (j4367a) UPS System
Photo paper will not print
check these 2 links and go through the sites
link 1
link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 17, 2009 | HP PhotoSmart 1215 InkJet Printer
My HP Photosmart C6200 All IN ONE serial # MY7AJH63BB, will not print photos coming from my Mini Mac computer on to the photo paper in the photo paper tray. It will only print onto 8x11 paper sheet. I...
None of the buttons on my 3 in 1 photosmart c6280 work but I can use to HP solution to get prints ,scan , and copy. Can not turn off or clear '! "button with out unpluging
THANKS
Nov 29, 2008 | HP Office Equipment & Supplies
We have a HP Photosmart C6280 All in One Printer/Scanner/copier. We want to scan to computor.The menu only shows "scan to copy" and "scan to memory card" The manual that came with the...
If possible, find the software disk that came with the printer, and reinstall. One of the options should be to scan from the scanner to the computer. Just make sure that option is selected on re-install, and that the necessary communication cables for that option are installed.
Nov 19, 2008 | HP Office Equipment & Supplies
HP pavilion will not shut down
pull the power cord out and the battery (or just let it run out). Then, try turning it back on again. If it does the same thing again then yes it may be old blue death and your harddrive may be worse than dead. I don't believe that the power button doesn't work. Hold it in for 10-15 seconds or so, any computer is DOS programmed to respond to the power commands above all, even above the dreaded blue screens. Let me know if I'm an ******* and I don't know what I'm talking about or if you need more help.
Mar 07, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
66 people viewed this question
Ben Johnson
