Question about Refrigerators
My dometic refrig. doesnt cool good in hot climate of Las vegas, I,ve been told their is an adjustment on the fins located on top shelf off frig. can I slide it up or down to make it colder. Thanks Larry
  • 51 Answers
Move it down away from freezer to make it colder. You also may look into adding a fan to the back of the fridge to help in air flow upwards. Much like a fan on a computer.
Posted on Sep 08, 2008
How much is a door handle for a Crosley Shelvador 1952 model?
The only place I have ever seen that refrig is on the TV show "American Restorations" The are located in Las Vegas. Worth a try.
Dec 09, 2014 | Westinghouse Refrigerators
Both refrig and freezer won't cool. the compressor has power but doesnt seem to get warm or hot. I think it is suppose to.
unplug the frig, then wait about 20 min.. to let compressor cool down. then plug back in..wait to see or look at compressor..see if you can see or hear it start up...if not..good chance you compressor has failed....
Dec 19, 2010 | Refrigerators
I have a dometic rm 2652 rv frig.. it is 4 years old and is not cooling. you can feel heat in the tube on both propane and electric but no cooling. can you be of any help on what I can do to fix this...
Inside your fridge there are fins, on the far right there is a plastic piece that slides up and down, this will adjust your temp. OR it can be your thermister. At the back of your fridge access from out side your camper there is a black box with lots of wires going to it , pop cover unplug wire P2 (your thermister) Then you will need an Ohm meter buy at any auto parts store, at the back of the plug test buy putting the red in one prong and black in the other you should get a reading of 6 Ohms now the plastic piece in the fridge pop it off the fin and remove the little wire with little tip and place it in a cup of ice and little water wait for 5-10 mins. and you should get a reading of 15 Ohms. And one other thing it might be a bad ground. Good luck.
Sep 18, 2010 | Dometic RM2652 Refrigerator
Noises in freezer area of refrigerator
Some refrigerators have a small plastic fan under the bottom shelf of the freezer that circulates air. It's not too unusual for a heavily loaded shelf to rub the fan blades making the noise you describe. If you empty the freezer, you'll fin a few screws holding the bottom shelf in. remove the shelf and inspect the fan and surrounding parts for signs of rubbing. Also tug on the fan blade lightly to see if it is still attached to the motor's shaft securely. New fan blades can be purchased at a good appliance repair shop. Good Luck
Nov 30, 2009 | Hotpoint HTR16BBSR Top Freezer...
Not cooling at all
Youneed a new sealed system, you have lost gas. ( Smells of amonia)_
May 27, 2009 | Dometic RM2193 Compact Refrigerator With...
My 1995 Dometic 2611 runs OK all day but not at night
Yes more than likely the cooling unit is going bad. If your boiler tube is hot the cooling unit is no good. Your frig is 13 years old, it has reached its life span and beyond. A cooling unit or a new frig can be purchased from Just send them an e-mail.
Feb 28, 2009 | Dometic RGE400 Top Freezer Refrigerator
Dometic 2652 runs sparatically, then quit
If the burner area is geting hot its has a leak
Dec 11, 2008 | Dometic RGE400 Top Freezer Refrigerator
Not getting cool enough
this sounds like a compressor problem. if the outside coils are getting hot (and properly ventilated) but the inside of the unit is not getting cold then the heat is coming from the compressor.
Jun 28, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
