Question about Kenwood KAC-7251 Car Audio Amplifier
Need help my amp blows my fuses & gets real hot quick
  • 631 Answers
If the fuses only blow after remote turn-on voltage is applied to the amplifier, the amp probably has shorted output transistors. If that's the case, they will need to be replaced.
If you're interested in repairing it yourself, read through the following page.
Amplifier Repair Primer
Let me know if you have any other questions.
Posted on Aug 27, 2008
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
My Peavey Envoy 110 won't turn on
Most likely a blown fuse, but the real issuse would be why is blew the fuse. If you replace it and it quickly blows again, take it to a repair shop.
Jan 31, 2014 | Peavey Envoy 110 Amp Combo
Hello........ looking for a schematic for Bose 501 series 3 speakers. I need to replace the fuse in line with the tweeters.... its blown & does not have a value on it (unmarked, quick blow, twin lead,...
Did you find a solution? Dunno if it's much help, but I just today picked up some 501s - Series I I think - ugly heavy brown material grilles - but with a manual! No fuses in these, but booklet recommends installing your own in-line fuse holders (!?). Specifies a BUSS AGC-3 fuse for amps under 50wpc; or a MDL-2 fuse for amps over 50 wpc. Can be placed is series with either or the two signal wires. Very strange.... Robin
May 14, 2011 | Bose 501V Speaker
Im looking for replacment fueses for my jbl tr225 and was wondering if something that can handle more power would be safe
I would only increase the fuse size by 5 amps if I could not find the right size.... If you have a direct short it will blow the fuse if it is a little over sized. If you use the range alot for a long period of time and if the wire size is matched real close to the fuse size then you could run the risk of getting the wire to hot and cause a fire hazard if you use a larger fuse then is needed..... Hope this helps.
Feb 05, 2011 | Kitchen Ranges
Hello i need a 6.3a - 125v fuse for my 100w amplifier the reson the old one blew was my step down transformer failed
You can fit a 5 amp fuse at 250volts if you can't find that one. As long as you don't exceed 6.3 amps it should be OK. It will only blow if there's a real problem. Use a quick blow if you don't know the type. Your local parts shops should stock them.
Jan 08, 2011 | JVC Audio Players & Recorders
My amp gets real hot and then turns off, what is the problem? Also If i choose to the setting of "Low Pass" as the filter option, would this blow subs?
Your amp is getting hot possiblily due to under power? of the amp. First try to turn the gain down (sensitivity) see if that helps, if not then add a fan to the amp to cool it. Also put the amp in an area where air runs freely....
Low pass means that it is allowing low frequency to pass by so No it won't blow your subs but it will hit certain frequencies!
Sep 15, 2010 | Car Audio & Video
On Memera fuse box, 30 amp fuse catridge carrier gets very hot, in fact can smell the plastic melting, but why does the 30 amp fuse cartridge (definitely rated as 30 amp) it is carrying NOT blow (240 volt...
OK well at 120 Volts at say 25 Amps (well below blowing potential) that equals 6000 WATTS 6KW, on a near short circuit. going through it...You would melt TOO.
I always use Ceramic ones myself, look they get HOT real HOT, BUT shouldn''t melt.
But in saying that your Electric shower shouldn't draw that much anyway, in reality. it may draw 10A - 15A, at most? more like 5A - 10A,
So i suspect you have a fault to earth somewhere you need to call an electrician. You may just have discovered a very bad fault. Some sort of short or leakage to earth or something?
A shower shouldn't draw anywhere near enough current to cause this type of occurrence. Please disconnect it by tripping the breaker and call a professional. get that melted one changed anyway.
Aug 11, 2010 | Water Heaters
Radiator fans blows fuse fans manualy spin free
thats normal,,, the motor is likley to have a shorted coial in it, if sit will pull far more amp's that is should and it blows the fuses, dont try fitting a biger fuse in,,,,,,you will just start a fire in the car!
Oct 22, 2009 | 1993 Dodge Intrepid
Fuel pump fuse blows quick
You have a short between the fuse and the reset valve . you have to trace the wires in between the fuse box and the fuel reset valve to see if they are pinched and a short is occuring.Follow the wiring from the fuse towards the back .
Dec 15, 2008 | 1990 Pontiac Trans Sport
Kenwood KAC-7251 Car Audio Amplifier Logo
59 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
