Question about Sony RM-945 Remote Control
Volume switch do not work properly
Please , could you explain the way to open the remote control RM-945 plastic case without break it ?
Thank's for your replay
Paolo
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
After you remove the 2 little black screws, must use a 'minus' (-) screwdriver. This screwdriver must be pushed between the 2 semi parts (shell) of the remote body and gently rotate until they get apart little by little. Must do this around the remote control body.Success!
Posted on Feb 15, 2009
Sony rm y186 remote
Sounds like the circuit track inside the remote control [at its PCB]; had opened. An open circuit can cause this fault. In most cases, this fault can be repaired. Contact any service technician. The remote control has to be opened.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 20, 2014 | Sony RM-Y180 Remote Control
Sony rm ss251
As all other buttons works properly except Volum Dn, the problem is with the remote control itself. Clean the remote control and check. To clean it, you have to open the remote control. If it too doesn't help you, buy one original remote control from the authorized service center for Sony. No universal remote control will go properly with Sony TVs. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Sony Televison & Video
Sony universal remote won't control the volume
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMVZ320 Try the above Sony web site, where they have support, or call a Sony Dealer. http://store.sony.com/-cms-page.sony.authorized.dealer.list?XID=M:accessories:esupport
Nov 17, 2013 | Sony RM-VZ320 Remote Control
RM-945 Remote Control codes
056,043,082,049,010 are the codes to check. If you wish to get more codes, fout digit, five digit etc: check this link.
Feb 22, 2013 | Sony RM-945 Remote Control
Dear sir, I have a Original Sony Remote Control and the model number is "SONY RM-892". I would like to know how can i open the remote control and to clean up the dirt inside the remote...
Most of the remotes can be opened and cleaned but with care. These remote boxes are self fitting plastics locks and so you need to use a thin blunt knife to wedge open the sides, like removing the car tyre from the rim.
once open you can use a remote control repair kit to clean or form the carbon contact points.
please find tips from the link below:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Apr 11, 2011 | Televison & Video
For RM-YD023, I need to control my Receiver volume while in TV mode. I can control my Sony Receiver while in AMP mode, but cannot change independent volume control so that I can keep the remote in TV mode...
I contacted Sony support for this same concern. Their response was that there is no volume lock option, you must switch back and forth from "TV" to "AMP" :(
Jan 29, 2011 | Sony RM-YD023 Remote Control
Volume control does not turn volume down. Lost remote control CD Receiver LT-1
I have opened the same unit up. The volume control knob moves a plastic paddle against a right & left micro switches. The paddle is connected to the knob by a very thin piece of plastic which breaks very easily. I tried to glue a different piece of plastic on , but it only worked for a little while. It was a pain to assemble & reassemble the unit. I do not recommend trying it. Just buy another remote (about $35.00)!
Good Luck
Dec 07, 2009 | Teac LT-1 Clock Radio
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
I have a chunghop universal remote, RM-133E and i need the 3 digit code for an LG tv please. Thanx.
I could not find the code, but here is a solution that should work. Please give me good rating
1. Manually switch on the TV set, and aim the remote control at the TV set, as shown in the figure:
2. Hold the "SET" key until the indicator light illuminates.
3. Repeat to press the "VOLUME +" key and see whether a volume symbol appears on the TV screen.
4. Upon appearance of the volume symbol, press the "SET" key immediately, and then the
indicator light goes out.Setting is finished.
5. Test whether the keys on the remote control function well; If keying does not work, reset from Step 2.
Jul 01, 2009 | Universal Remote Control Remote Control
Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Jan 08, 2008 | JVC AV-27230 27" TV
Televison & Video Logo
308 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
