Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
How can i restall windous vista home?
I find out the key F5 Load Setup Default, but nothing will be change.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you have the DVD to reinstall it or is it on a partition?
    Sergeant:
  • 336 Answers
F11 will load up the setup to restore factory settings to the computer, meaning all data will be lost. If you need further help, tell em and I will begin troubleshooting.
RCF
Posted on Sep 03, 2008
When turn on Toshiba Satellite M100-JG2,get back screen
Try FN+F5 button combination to change the default video output. Hold down the FN key and press the F5 key to change between the laptop LCD and an external monitor.
Jul 02, 2014 | Toshiba Computers & Internet
How do I reset the bios cause when I enter the setup wont let me click on it
When you go into BIOS Setup Hector, you can no longer use your mouse
You have to use the Keyboard
When you go into BIOS Setup you are automatically in the Main menu
To go on..........
There are 3 main BIOS manufacturers. Some smaller ones too, but doubt they wrote a BIOS program for your laptop.
Phoenix, Award, and AMI.
Award merged with Phoenix now.
There are also different versions produced by EACH BIOS manufacturer.
Therefore I cannot just start guiding you, without knowing.
Some examples however......
This style has the menu's across the Top.
One example - Main / Advanced / Security / Power/ Boot / Exit
Use the Left Arrow key to highlight the menu you want, then press the Enter key.
The navigation guide is at the bottom, and to the Right.
DOES NOT state navigation guide.
Tells you how to navigate around in BIOS, and how to make changes, and Save Changes.
Same thing for a BIOS Setup example, that has the menu's listed i n an order.
Standard BIOS Features (Standard CMOS Features)
Advanced BIOS Features
Integrated Peripherals
Power Management Setup
PnP/PCI Configuration
Etc.
Use the Down Arrow to highlight the menu you want, then press the Enter key.
The navigation guide at the bottom, tells you the key to press, to make changes.
THEN Save Changes.
IF you do Not Save Changes, it will be like you have done nothing at all.
It's because you HAVE done nothing at all. Just looked around, unless you save changes.
[Usually the Page Up or Page Down key; or the Minus ( - )
or Plus ( + ) key; is to make changes.
Change Value ]
You may see F12 to save changes, or a Y/N, or Yes/No
The Y is just shown as an upper case Y for clarity. Press the lower case y.
Then press the Enter key.
If everything goes bad:
Look at the navigation guide at the bottom, in BIOS Setup.
You will see a key listed to press, that is Load Default Settings.
Usually an F6, but don't quote me on that.
You made a boo-boo in BIOS Setup?
Go back into BIOS Setup. Find the Load Default Settings key.
Press it, then the Enter key.
Now you are back to square 1.
Regards,
joecoolvette
Feb 12, 2013 | Computers & Internet
Reset CMOS on IBM 2847
  1. cmossave.jpgEnter CMOS setup.
  2. In CMOS setup look for an option to reset the CMOS values to the default setting or an option to load the fail-safe defaults. With many CMOS setup screens there will be a function key to do this; for example, the F5, F6, F9, F11, or F12 key like shown in the picture to the right. Other setups may actually list an option that you can arrow over to using the arrow keys and press Enter.
  3. When found and selected you'll likely be asked if you're sure you wish to load the defaults press Y for yes or arrow to the yes option.
  4. Once the default values have been set make sure to Save and Exit and not just exit.
May 14, 2012 | IBM Computers & Internet
Load defoult configuration now
What default do we want? is it the image of the computer or the BIOS settings?
If you want to restore the computer's OS back to factory, press Alt + F10 on the Acer logo. Alternatively, you can use the recovery CD that you should have created when you got your laptop.
If you want to restore the BIOS to default:
  • 1. Turn the Acer Aspire laptop on. Restart it if it is already turned on.
    2. Press the "Del" key as soon as the computer turns on. The BIOS setup utility will load.
    3. Press F5 to reset the BIOS to defaults.
  • Jul 05, 2011 | Acer Aspire 5000 Notebook
    Solve Your "how can i
    Go to bios setup press "F5" or press "esc" key then look for the "restore default " press enter and then save and exit...
    your PC will reboot and its bios is on default..
    Have a nice day ahead :)
    Jun 19, 2011 | Computers & Internet
    Installed new bios for windows 7, not working,on start up, computer locks up, able to unlock- but didn't happen with original bios. Looking for old bios to re install sholder012001@yahoo.com
    o open the BIOS Setup screen: Reloading the BIOS default settings To reload the factory BIOS settings to the setup default:
    1. Press the F5 function key.
    2. Select Yes or OK.
    3. Press the Enter key.
    4. Press the F10 function key.
    5. Select Yes or OK to save the defaults.
    You can also complete the following steps to reload the factory BIOS settings using the menu:
    1. In the BIOS Setup utility, select the Exit tab.
    2. Select Load Setup Defaults.
    3. The system prompts you to load the optimized setup defaults. Select Yes or OK and press the Enter key.
    4. Select Exit Saving Changes.
    5. Press Esc and then press Enter to exit Setup.
    Please don't forget to rate this if it fixed your problem. Four thumbs up is basically what means your problem was solved. Anything less means your problem was not solved. Not sure people here understand that as far as how we get rated.
    Jan 15, 2011 | HP DT PAVILION ELITE E9120f DESKTOP PC
    Reset the BIOS on a Compaq server 740 jumpers settings
    Don,t do that insatead:
    Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
    1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
    2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
    NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
    2. Select Load Setup Defaults .
    3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
    4. Press Esc and then Enter to exit Setup.
    Nov 13, 2010 | Computers & Internet
    My keyboards shortcuts don't link to the screen?
    F5 is the default screen refresh for many laptops. If there is a volume change feature on your laptop which also uses F5, chances are it is a Feature enabled key. To make the volume work, look on your laptop for a key most with blue letters that is printed with the letters "Fn"
    Hold down this key while pressing the F5 key. This should adjust the volume correctly. Did it work. Please post your feedback and let me know.
    Thanks!
    Jun 10, 2009 | Computers & Internet
    Nothing happening
    When you start up the laptop, tap the F2 or F10 key like a piano in four four time and see if you do not get a bios setup screen, sometimes called a System Setup Screen. If you do post back to me as soon as you can and await my instructions, but basically you want to page through the setup screens until you find a setting for the external display default. Change this back to the laptop panel. It is probably set to an external display monitor or LCD panel.
    On your keyboard are special keys you are probably familiar with. These are used in conjunction with the Fn key. To activate an external monitor and turn off your LCD display, you would press the Fn key + the F key that has an icon on it in the same color as the Fn keytop. The icon for the external monitor looks something like this |O| with the circle here being replaced by a rectangle. Often this is just replaced with two rectangles, one filled with shade one not. The F Key is almost always the F5 key.
    To test this, start your computer, then press the Pause key. Then press the Fn key plus F5 or which ever key it was that you found with an icon as I attempted to desribe.
    My guess this is what has happened, the alternate external display is activated and this needs to be changed. Sometimes you have to go into the System setup pages and tell the laptop you are on the Panel display by default and not the external monitor, otherwise you will have to press the Fn key sequence every time you boot.
    Let me know how you make out.
    Regards,
    Worldvet
    Aug 04, 2008 | Compaq Presario M2000 Notebook
    Nas p410m
    hi im wesley. to reset the unit to default you go into the bios witch is as you turn the computer on it will say press delete or f1 to enter setup then once you in at the bottom of the screen you will see you need to press f5 or another key to load default settings then save and exit and your done.
    Jul 08, 2008 | Computers & Internet
    Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
    62 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
