Question about Friedrich Heating & Cooling
Bought an airconditioner about two weeks ago,the unit is 26.000 btu and is not performing the way it should be.
Hey,, have you checked ot the back coils from the inside out? This unit should cool enough to hang meat! If dirty and plugged, itwon't remove heat and sends it back in the front coils,,,(see where I'm going with this !) A window unit should have at least 20*- 25* temp. different from the air blowing out the front coils and the air sucking in! (If less than 15*, low on freon!) Thank-you-very-much!
Posted on Aug 27, 2008
Frigidaire airconditioner compressor keeps running after turning the unit off
Thanks for the post, friend!
I understand that the compressor continues to run after your Frigidaire air conditioner has turned off. From that information it sounds like there could be a possible issue within your control panel or relay. I would recommend a reset on the appliance, to perform a reset unplug the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in. If you continue to have an issue with your compressor I would seek assistance from a professional. Hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire 18,500 BTU Window-Mounted...
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
How many BTU's?
British themal units : BTU: the indicative units describe the cooling capacity of the Airconditioner. So please check tables to see your capacity.
May 16, 2011 | Heating & Cooling
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
Can't find btu ratingfor serial#m7x05f2a-b.thanks
5400 btu's
Note: should be a metal/paper tag somewhere on unit to indicate voltage, amps, and btu's.
Jun 08, 2010 | Maytag M7X05F2B Air Conditioner
Window Unit doesn't cool
Peace,
ngafm at your service,
You do know that you have a one year service warranty with all major appliances you buy?
You do not have to do anything ! Just call service and have your sales receipt ready to give them the sales information!
I think this is the easyest thing to do and i's free if you bought it new!
ngafm
please rate me before you sign of!
Sep 05, 2008 | Samsung AW0503B Air Conditioner
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Why the word ton used for airconditioner.
hi there..
this what i found for you...
The unit ton is used in refrigeration and air conditioning to measure heat absorption. Prior to the introduction of mechanical refrigeration, cooling was accomplished by delivering ice. Installing one ton of refrigeration replaced the daily delivery of one ton of ice.
  • In the United States, a standard ton of refrigeration = 12,000 BTU/h = 200 BTU/min ≈ 3,517 W. It is approximately the power required to cool 1 short ton of water by 1 °F every 10 minutes; or the power required to melt one short ton (2,000 lb) of ice at 0 °C in 24 hours.
  • A ton is also a unit of energy equal to that power for a period of a day, or 24 h × 12,000 BTU/h = 288,000 BTU ≈ 303.9 megajoules.
  • A less common usage is the power required to cool 1 long ton of water by 1 °F every 10 minutes = 13,440 BTU/h ≈ 3,939 W.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 24, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
