Question about Rowenta DG-980 Iron
Rowenta DG980 Owners Manual needed
I have just inherited a Rowenta DG980 that is missing the tank, and whatever else goes with the tank. Would like to have access to the manual to find what parts are needed and how to operate. Thanks.
    Scholar:
  • 70 Answers
Go to the Rowenta USA website. They will have a users manual in PDF format (you will need Adobe Acrobat Reader to be able to view, download or print the manual. It is free...yay! :o)
Sorry I cannot attached the hyperlink because my Internet Explorer keeps locking up when running on my new VISTA equipped machine.
Posted on Sep 16, 2008
Steam switch won't work
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
God bless you
Apr 01, 2013 | Rowenta Irons
The dial on the Rowenta Iron DG980 has broken off so I cannot adjust the temprature. Is there a replacement part I can purchase???
I do not know where you are, but I have found these people as the most knowledgeable when it comes to helping you troubleshoot and get replacement parts:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Hope this helps :o)
Aug 27, 2011 | Rowenta DG-980 Iron
My puppy has just chewed the sealed plug off my Rowenta Master. Is it safe to wire up a basic new plug? Bit worried about the water/electric combo. Puppy is fine! Thanks.
The cord that comes with the DG980 is mighty handy because it is nice and long. I would just get a brand new one, You do not want loved ones to be around a "modified" cord. JMHO :o)
Aug 16, 2011 | Rowenta DG-980 Iron
What is the best way to clean my Rowenta iron.
I always run the DG980 till the steam runs dry, unplug and let cool. Rowenta recommends using clear water ONLY. They even provide a small hose & faucet adaper to flush out the steam tank reservoir.
Since it sounds like you do not have it, the next best thing is to use filtered water (I have a 3 cylinder water filter in the kitchen for drinking water), The tank has a plug on the side which should be removed once unit is cold, tank flushed with filtered water and drained completely and leave the treaded metal plug and trim cover off to air dry completely, as well as the blue tank.
May 24, 2010 | Rowenta DG-980 Iron
Power switch blew
you can go to small appliance.com and buy a
new switch. i have do this and orther parts .
for the same model.
Aug 27, 2009 | Rowenta DG-980 Iron
Trouble with Rowenta Irons
If your Rowenta DG 920 is chucking guff from the steam jets you need to flush it as per the instructions. ( ie. Flush every 10 uses ) If you haven;t done it for somewhile, you'll next need to expel the reamining guff with lots of steam. Then no more probs.
Aug 05, 2008 | Rowenta DG-980 Iron
Rowenta DG980
Hi Linda,
Here is the information you requested. My wife puts this unit on the top of her list. It saves her hours of ironing time and she uses on all her dress clothes for work.
In California, the name of the place is
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
Enjoy!
Jul 07, 2008 | Rowenta DG-980 Iron
Steam from rowenta preassure iron and steamer
Hi, It is likely you have too much residual water in the iron or have mineral deposits from the tap water you have been using. Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
Apr 16, 2008 | Rowenta DG-980 Iron
No steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
Dec 18, 2007 | Rowenta DG-980 Iron
Rowenta DG-980 Iron Logo
578 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
