Question about Panasonic Lumix DMC-FZ10 Digital Camera
I tried to take a shot of the Vanderbilt baseball stadium, and it came out a little soft and out of focus. I was in Apperture priority at F8 to maximize the depth of field, exposure compensation -2/3EV, metered in the field, and tried to focus on the two guys sitting there in the midfield. Tried one shot AF, the manually tweaking it in OIS mode 2. On screen it looked fine, but on the computer screen not so much so. What could I have done to make it better? How can I set the focus to infinity?
    Master:
  • 903 Answers
1)The exposure was actually fairly decent. Whatever you metered on wasn't far off. 2) There was no reason to force the camera all the way up to F8 as in this picture there was no challenge regarding DOF as everything you were shooting was quite far away including the foliage on the right. 3)There is however problem in the area of Sharpen. If you are going to use post enhancement you can set the sharpen and Contrast to low. If you are not going to post process the shot, putting contrast and sharpen to high will give you a better image although very rarely as good as an image post processed for sharpen and Contrast/Brighten-Darken. 4) The picture was not completely focused, you can see this in the bluriness of the stadium billboard on the right by the cars. This may have happened when you tweaked the focus manually. Sharpen and focus are two different things. Sharpen can be corrected in post but lack of focus cannot. I just push down the focus lock on the left until it locks and then worry about metering.
Posted on Sep 06, 2005
    Master:
  • 903 Answers
You used spot mode but in aperture priority for a wide area subject like that. You may want to try program mode instead. For a sort of wide angle shot like that, I don't find the smallest aperture very usable (but yes, in macro). Somebody still need to confirm how to do infinity focus on the FZ10. You may also look into the middle focal plane focusing technique to get the background and the foreground in acceptable focus.Your pic looked like no-sharp focus is uniform. Try not to spot meter/focus on the field but at a stadium part/area that has more contrast and in the middle between your foreground and your background.
    Master:
  • 903 Answers
I've played around with the 'unsharp mask' filter in Photoshop CS, and I must tell you the results were amazing. I guess I should have mentioned that I'm very new to digital photography and I'm learning new things every day. I've had my FZ10 for 10 days now, and same goes for PS. By the way, do you know where could I find a good PS tutorial? The PS copy that I have came from my university's software licence department, with no manual. I know it is an amazing piece of software, and I want to learn.
Can metz 45CL-1 support Nikon D5100?
To use Metz 45CL-1 with Nikon D5100, you need use in apperture priority mode (A), adjust same ISO and apperture in Flash and Camera (Ex: ISO400 and F: 5.6) . The flash adjust light intensity to mantain correct exposition. You need use an adapter to conect Sync cable in your camera.
Nov 13, 2015 | Nikon D5100 Digital SLR Camera With...
Our Canon Power shot A95 is used to take close up photos of jewellery ,with a white background.We have been useing the TV mode with the MF to focus.Howerev the pictures are over enposed, what can we do to...
Instead of shutter priority "Tv" mode, try setting to program "P" mode instead. Also, turn off the flash, and set to macro if shooting close-in (press downward on the little flower icon on the back disk). If pictures come out blurry, try using a tripod to hold the camera steady, or set the camera down on an object so it doesn't move while taking the shot. Try using the timer to activate the shutter to allow the camera to remain even steadier for the shot.
Feb 13, 2011 | Canon PowerShot A95 Digital Camera
I have a Nikon D90 camera with a 180 - 300 lens that I use to shoot photos of my boys playing football. I have always had crystal clear shots from the stadium. Now that my boys are playing Varsity at...
Obviously, shooting the pics at night requires a longer exposure. If you haven't changed any settings from your daylight pics, then your camera is probably setting a slower shutter speed to compensate for less light in the stadium. You need to raise the ISO setting. You could get a faster lens, experiment with both aperture priority and shutter proiority, etc. But try the ISO first...that may do the trick.
Sep 18, 2010 | Nikon D90 Digital Camera with 18-105mm...
Why is the LCD screen white? even when pictures are being taken it also appears white. What can be the possible cause and solution for this?
Well, check what mode you are using. If it's MANUAL, maybe you are using the wrong apperture/speed/iso settings for the light conditions. The picture is being made as you are ordering (with wrong settings), causing a too clear image getting recorded (overexposure); sometimes the overexposure is so extreme that a "all white" image appears on the screen.
Try changing the mode for APPERTURE PRIORITY, SPEED PRIORITY or PROGRAM (A, S or P respectivelly), so the camera will try to compensate the other variables for the correct exposure.
If so, don't give up using the MANUAL mode (which is the best one, in my opinion). Only try to learn a little more about exposure and camera's controls.
Feb 08, 2010 | Cameras
Focusing issues with canon 40D when taking sports shots
I believe I have found my problem. I think my image stablizer on my lens is on the brink! I turn it off and got good pictures.
Jun 03, 2009 | Canon EOS 40D Digital Camera
Changing my appiture
You will need to be in AV or manual mode to change your apperture.
AV is apperture priority and manual allows you full control of all settings on your camera.
Hope this helps!
May 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Sony W1 Questions
It has Multi AF, Center AF or fixed focus. The V1 i had went to 800ISO, if you turn the ISO up a little more may you can set a faster shutter speed. I think the only priority settings are the "scene modes" there may be an action ssetting in the scene modes.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Manual Shutter Priority Settings
Try the PROGRAM MODE-SPORTS setting. this will keep the shutter speed reletively high unless there is little light. Or use APERTURE PRIORITY MODE with an f2.0 to f2.8 to keep shutter speed high. If pictures were blurry when it went to AUTO then the light had to be low for the camera to select a low shutter speed. If using flash use forced or auto flash not slow sync. Also set ISO to 400 which is >>>. If inside use a larger external flash as the one on-camera is only good for about 10ft. if more than 10ft. away set focus to manual infinity so you don't have to wait for the camera to focus. Hope this helps.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
3100Z Focus Problems
re you sure the out of focus condition is due to the actually focus or do to motion blur? I think the 3100Z in auto and flash on will set the shutter speed fairly low like 1/30th of a second for wide angle and 1/90th for full telephoto. This may not be fast enough to avoid motion blur. I would suggest using manual mode and shutter priority and set the shutter speed to 1/100th of a second. This won't effect the flash output but will reduce the amount of ambient light being captured which could cause long range shots to become darker in the distance. Name of the game, don't be afraid to take it off auto mode and experiment with manual setting.
Panasonic Lumix DMC-FZ10 Digital Camera Logo
74 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
