If one of your electric stove top burners isn't heating, it could be a bad burner, a bad connection in the burner socket or a faulty switch. ... If that burner won't heat, the problem is either the burner socket .
Remove the burners and make sure that the burner terminals are not bent. Replace the burners making sure that burners plug into their receptacles. MAYTAG Gemini MER6772 User Manual
Just to be clear, the burner does not heat at all? Is this the small or large burner? Swap the burner with another one to see if it is the burner itself or the infinite switch. Post back your results.
I had a similar problem. I took off the burner heat deflectors and seen gaping holes in the burner tubes. Get your model number and serial number and call Weber. Most Ducane grills have a 5 year warranty on the burner tubes. They will ship them free if under warranty!
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone
burners - the burner power indicator light stays lit whether the heat
control knob is on or off, there is no heat coming from the burner on
or off. You pulled the burner from the receptacle and one of the tabs
broke off and stayed in the receptacle. You removed the tab and made sure
no pieces remained in the receptacle then bought a replacement burner,
no change. You put the replacement burner in the back burner of the same
size and had heat within 10 seconds. You changed out the burner with the
one that had been in the back of the range, no heat. As long as the
breaker to the range is on the power light stays lit but no power to
that one burner only.
What is the model number and the age of your range?
