Question about Creative Labs ZEN V Plus MP3 Player
ZenVPlus2GB My Zen VPlus lights up with ZenVPlus in window but nothing else happens this occured after useing wall charger, wont shut off goes out on its own.
  • brucewilliam Aug 27, 2008
    If battery is bad how do you access without damaging unit and what kind of battery
    I know i need to replace battery or I at least think so. My question is what is the procedure as not to ruin I pod, I see no acceess points.
  • 1,879 Answers
You have to crack that thing open to access the battery. no access point, not meant to have it's batteries replaced. yes same as ipods.
Posted on Aug 27, 2008
  • 813 Answers
U have go with a professionl repairer
  • Creative Labs Master
  • 1,800 Answers
Its an internal battery.
use the solder took to replace it but u need a proper one that fits with the place and got same volts like the damaged one.
most of those problems occur with a faulty outlet!!
plz rate this post^^
  • 6,487 Answers
I belive changing the battery of this is just the same changing the battery of Zen Vision M so check this link for the step by step video that will help you in replacing it http://www.videojug.com/film/how-to-replace-the-battery-on-the-creative-zen-vision-m
Hope that helps..........
  • 282 Answers
Watch this http://www.youtube.com/watch?v=22T_gkkZjmM
Posted on Aug 26, 2008
  • 19,396 Answers
You will need to remove the battery to fix this.
    Master:
  • 521 Answers
Check the battery.normally the weak or faulty battery give this types of problems.
Computer wont recognise my zen Vplus
replace or usb cable...f not chek usb port of ur unit
Jun 30, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative zen stone plus wont turn on
the battery is dead use a car charger it worked on my creative zen stone plus and ipod touch. the car should charge it
Jun 10, 2009 | Creative Labs Zen Stone Plus MP3 Player
I have the same problem, wont charge, comp cant recognise
I tried to charge my Zen Vplus 8 Go, using a wall plug : it didn't charged and it came with Black screen !!! I didn't fixed my problem by using the reset button. So i finally succeed to fix it, by both : - pluging my Zen on my my computer - using the reset button. You should succeed also if you are using my method !!! Joel from Paris
Jun 09, 2009 | Creative Labs ZEN V Plus MP3 Player
Wont turn on
you need a new battery for you zen
look on ebay.com
or do a search for creative labs zen vplus battery
on the inetrnet
May 25, 2009 | Creative Labs ZEN V Plus MP3 Player
Zen Problems
My screen did not blink. Nothing happened until I plugged it in the back of my pc. The wall charger did not work and plugging it into my laptop did not work. Did you try the back of your pc? I left it in there for over 6 hours, but I knew it was working when I plugged it in and right away it powered up.
Jun 09, 2008 | Creative Labs Zen Digital Media Player
Erm....
Hi there, you need to purchase the accessory which has the usb 2.0, DC in and A/V out on it. This is the accessory that allows you to plug your Zen into the TV to play the movies.
May 30, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen vplus 4gb Stuck on start up screen that says "ZEN vplus"; it will not shut down once on, unless using the reset button
see recovery mode info here:
http://www.anythingbutipod.com/forum/showthread.php?t=6714
(thank you)
holding play button while powering up, then running Clean Up & rebooting did the trick.
Mar 14, 2008 | Creative Labs ZEN V Plus MP3 Player
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Vplus hangs while charging
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
May 29, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
62 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
