Question about Acer NSK8458AN Keyboard
Acerr Aspire 5315-2940
Type moves from one line to the next and all over the place
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Posted on Oct 19, 2008
MY 2001 FORD ESCAPE V6 MAKES A WHISTLING SOUND WHEN ENGINE RUNNING.
Guessing you are saying you checked vacuum lines, the next probable place is the exhaust.
Can you tell where it is coming from? If the front end of the engine then remove belts one at a time to disable accessories.
You need to locate it. Use a piece of fuel line of a hose of some type, you should be able to move it around and locate the source of the whistle.
Feb 16, 2015 | 2001 Ford Escape
Why does my text prompt tab to the next box, move within a line of text, or otherwise disappear when I start typing?
The touchpad membrane is bouncing as you type; the bouncing is letting contacts move the pointer to a new spot. You need to replace the touchpad, or disable it if you use a mouse.
Feb 15, 2018 | Gateway LT2030u Netbook
My child unit is a Aspire One with windows 7. He changed the Windows password. Now he doesn't remember or he is just saying he doesn't remember. He is only 10 years old and as a Mother I would like to see...
  1. you will need your Acer recovery disk
  2. insert into CDROM tray
  3. Restart the Acer Aspire. When Windows boots up, select the username you want to reset the password for and press "Enter."
  4. Click "Use your password reset disk" to launch the password reset wizard. The password reset wizard enables you to create a new password for your user account.
  5. Click "Next" on the password reset wizard and insert the password reset disk. Click "Next." Type your new password in the "Type a new password" box and type the password again in the confirmation box.
  6. Type a hint to you use in case you forget your password next time. Click "Finish" to activate your new password. Restart your computer and log on to Windows using your new password.
Feb 04, 2011 | Acer Aspire One Netbook 8.9" Notebook
Something happened to my friend's ACER netbook and it is not able to open. It shows the message to Press Ctl+Alt+Del but after you do that it goes back to the same message again. We tried Alt+F10 but it...
Did you hold down the alt key while continually pressing the F10 key?
  • Back up all data on the Acer Aspire One that you wish to keep.
  • Install the battery and connect the AC adapter to your Acer Aspire One.
  • Turn the system on by pressing the "Power" button.
  • Press and hold the "Alt" key immediately after pressing the "Power" button and tap the "F10" button.
  • Continue holding the "Alt" button and tapping the "F10" button until a screen saying "Acer eRecovery" appears.
    You will see three options:
    Restore system to factory default
    Restore system from CD/DVD (grayed out if an optical drive is not connected)
    Exit
  • Click on "Restore system to factory default." A notice will appear informing you that all data on the "C:" drive will be overwritten and reminding you to plug in the AC cord.
  • Click "OK" to begin the recovery. A message will appear stating once again that all data on your hard drive will be overwritten.
  • Click "OK" to acknowledge the message. The screen will show you a progress bar as the recovery progresses. Wait until the recovery is complete. The time will vary depending upon the individual netbook. A message will appear when the recovery is finished.
  • Click "OK" to restart the computer. The netbook will reboot. Windows will load, asking you to wait. A "Welcome to Microsoft Windows" screen will eventually appear with background music playing. It is time to help Windows set up your computer.
  • Click "Next" to continue. You will be asked to input your system settings. Enter your region, language, and keyboard type, then click "Next." The next window is for your time zone.
  • Select your time zone and, if desired, place a check in the box beside "Automatically adjust clock for daylight savings time," then click "Next." The EULA (End User License Agreement) will appear next.
  • Place dots beside "Yes, I accept" on both places to accept all points of the EULA, then click "Next."
  • Place a dot in the radio button beside "Help protect my PC by turning on Automatic Updates now" and click "Next."
  • Click "Skip" to avoid setting up network information at this time.
  • Click "Skip" to avoid setting up an Internet connection at this time.
  • Place a dot beside "No, not at this time" to avoid registering with Microsoft at this point, then click "Next."
  • Click "Skip" to avoid inputting registration information now.
  • Put your name and the names of others who will use the computer here, one per line. Click "Next." Microsoft will thank you for setting up your computer. Click "Finish" to begin using your newly restored computer.
  • Read more: How to Use eRecovery for an Acer Aspire One ' eHow.com http://www.ehow.com/how_5827957_use-erecovery-acer-aspire-one.html#ixzz19AQiNO5g
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
    Dec 25, 2010 | Acer Aspire One Netbook 8.9" Notebook
    Battery timing issue..
    Click Start
    Click Control Panel
    Click Classic View
    Click Power
    You can adjust your computer to run more slowly, and use less power per minute, to maximize the amount of time that the battery will last, before it needs to be recharged.
    Dec 24, 2009 | Acer Computers & Internet
    I WANT TO MOVE MY EMAILS IN TO A SAVE FOLDER
    Select File, Import, Messages.... Choose Microsoft Outlook Express 6 and press Next. Select Import mail from an OE6 store directory and press Next. Now on the next screen, browse to the location that you've placed the message store we saved from your old machine. Import, and your messages should now be transferred.
    Oct 30, 2009 | Acer Aspire 5315 Notebook
    I purchased two 1GB pc2-4200 memory sticks and my Acerr Aspire T180 wont recognize it. It starts beeping and wont Boot. The reason I bought them was that my computer was running very slow after I re...
    Hello there:
    first off you will need to ensure that the memory that you have purchased is fully inserted in the slots next ensure that the memory is compatable with the motherboard that you have and your system
    go to the manufactures web site of the computer and there will be a technical support option there with phone numbers to help you.
    Also you may also want to swap slots with the memory sticks and see if this helps ok so please try these ideas. ok
    best regards mike
    Jul 31, 2009 | Acer Aspireā„¢ T180 PC Desktop
    Mouse and Keyboard seem to be working together to stress me out
    Turn off your mouse pad and use a usb mouse. Sounds like your mouse pad is very sensitive.You can also go into your mouse properties and change the sensitivity.
    Dec 14, 2008 | Acer Aspire 5315 Notebook
    Check disc makes the screen go blank
    The disc check stopping and going to a blank screen, indicates a bad sector in the hard drive, and the drive will need replaced. If you can still use the machine by skipping the check disc, then you need to back up any files that you want to keep, eventually the hard drive will fail completely, if it hasn't already.
    Jul 30, 2008 | Acer Aspire 5050-3242 Notebook
    Acer NSK8458AN Keyboard Logo
    231 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
