Question about Panasonic Lumix DMC-FZ10 Digital Camera
SD Card I just bought a panasonic Fz10 Digital Camera, spectacular btw, but it only came with a 16mb sd card, and obviously i need a bigger card. I see that the Ultra II SD ( 512mb ) cards are available, and i just wanted to check whether this would work in the FZ10.
    Master:
  • 903 Answers
They have not had a good reputation for reliability here, you might want to do a search on SanDisk. The consenses on SD cards seems to be Panasonc, SimpleTech & Lexar (32x best), in that order. Some (Pixy) have had good luck with th Ultra II, but several others have had SanDisks of all kinds fail.
Posted on Sep 06, 2005
Does the SD card come with it?
From the Amazon.com web page for this camera:
"This camera has a 3MP (2048x1536) photo resolution and 640x480 video resolution, and 16mb of internal memory expandable to 2GB with an SD card (not included)"
This means that the camera has 16MB of built-in memory (enough to hold maybe 4 pictures), so you'll need to buy a 2GB or less size SD card too.
Dec 30, 2010 | GoPro Digital Hero 3 Digital Camera
DC6550
We need to be sure of some things:
Are you saving the picture to the internal flash memory or an external SD card?
1) The internal memory will only hold 16MB of pictures, check if it's full.
2) The external SD memory can only be up to 1GB in size, anything bigger will not be recognized by the camera
1. Make sure the SD card is not "locked". Some SD cards have a little switch to prevent them to be written into.
2. SD card should be formatted by the camera preferably or as the FAT format in your PC.
Does this help you in any way?
Please give us more information as to how you are saving them and/or any further questions you may have.
Dec 12, 2007 | Cobra Digital DC6550 Digital Camera
I own a Panasonic Lumix DMC-FZ10, but have never been able to use it because of a 'memory card error'. the camera is brand new. despite trying other SD cards, i an unable to shift this error. any...
This camera should be able to use any SD card of 1GB or less capacity. If you have been trying to use larger capacity cards, that will be your problem (larger cards are actually SDHC, which fit the same slot but are different electrically). If the cards you have been trying are smaller than that, then there is most likely a fault.
These cameras come with a memory card that will work with them (it is very small capacity). If you have tried to use that one and it won't work, then return the camera under warranty.
Dec 25, 2010 | Panasonic Lumix DMC-FZ10 Digital Camera
Is there a maximum SD memory card that I can use on my Panasonic Lumix DMCZ7. I have tried to use a 16 & 24Mb SD card but the camera will not read it and displays a ' card error reading message'
I think you mean 16 and 24 GB (Gigabyte), not MB, but those would not be SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If you really mean 16MB, then that would be rather small, not too big. 16MB is definitely compatible with the camera and is mentioned in the manual.
The maximum memory card size mentioned in the manual is 1GB, and that is quite big enough. If you really need more space, then just carry a spare, like people used to take extra film with them on holiday.
Dec 09, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
Number of photos
You can't get room for more than 33 pictures on a 16MB card.
I'd suggest you buy a bigger SD card for the camera.
Your camera can use up to 2GB cards.
Jan 14, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Using a sdhc card in a Panasonic DMC-FZ10
There is no "new" firmware upgrade for this model. Meaning it is NOT compatible with the SDHC card. Largest you can get is an SD 2GB card.
Sorry
Dec 18, 2008 | Panasonic Lumix DMC-FZ10 Digital Camera
Memory
Secure Digital cards, Panasonic proprietary cards recommended, though I've heard that any SD card with a transfer rate > 10 MB/sec will fill the bill.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Where does Lumix® digital camera store the pictures I take?
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
Aug 30, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
89 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
