Question about Refrigerators
Hi there I am trying to fit an Electrolux RM 4206 onto a boat. Standing in the middle of the cabin it will freeze on strength 2 ( out of 8), but when I put it into the position where it's meant to be, it wil immediately start to defreeze. Obviously I have a trouble with air circulation. This is a 3=way fridge which is only used on AC power. I have got a small small computer size AC fan that I want to wire into the fridge wiring to cool down the back. I have seen this done on DC circuits and the fan will switch itself on and off as temperature fluctuations dictate, but I haven't seen it done on an AC system. My efforts so far have only resulted in the fan being on all the time, so obviously I am wired up wrong. Could you talk me through as to whereI need to wire in, and whether I would need another thermostat? I seem to remember that the 12 volt system that I saw did have a thermostat wired in to the finned cooler at the back of the fridge. Hope you can help Many thanks Harry
  • tattya Aug 26, 2008
    All connections are A OK. I need to know where I should wire into the existing loom and if I'm going to need an extra thermostat.
    The refrigerator is in perfect condition, as stated. I cannot put the problem clearer than I have in my initial letter. Have you read it? It's now midnight and I am going to bed. Goodnight. Thank you.
    Harry
  • 958 Answers
Hello there harry,
i don't know if you can still see this post cause i think i am the last to answer here.
i have work for boat's refrigerator for quite some time now and i think i could help you with your problem.
just use the "ask me" button and i will gladly assist you.
tnx, drcool
Posted on Aug 27, 2008
  • 1,512 Answers
Even using a fan to circulate air about the fridge will not help a lack of ventilation issue. The hot air needs to escape to somewhere. Its not about getting air moving across the condensor coils to make it work, its about evacuating the heat from the area. The Fridge will be creating heat the whole time you have things in it and everytime you open the door. Best solution is to ensure that the fridge has the required ventilation about it, and from there vent air out of that space with a low power 12v computer fan. They only use a few watts and can be on all the time. I would wire it into the accessory circuit of the boat so that it runs when you are using the boat. A thermostat is a waste of effort, as whilst the fridge is cooling at all, it will need the ventilation. It will also use more power if you have not ventilated the coils properly. Hope this helps
regards
robotek
    Top Expert:
  • Refrigerators Master
  • 77,499 Answers
You can buy a thermistor kit that will turn the fan on at different temps, they are used in home computers to control the cooling fans, they should be availiable as a kit from any large on line PC parts house, the ones that sell parts to buils your own PC.
Posted on Aug 26, 2008
  • yadayada
    yadayada Aug 26, 2008
    That's build, not buils. typo sorry.
  • yadayada
    One comment PC fans are 12 volt, they are very cheap and come in a wide range of CFM air output, you will need one of these to use my idea about a temperature activated fan controller
  • 157 Answers
Ok, youll need a thermostat connected to the power switch board of the fan. Now set the thermostat at the desired temperature. When that temperature is reached and starts to elevate the fan will start. When the temp cools down, the fan will stop
Obviously, ull need to attach the fan wiring to the thermostat of the fridge. Probably ull need a smart card setup that is programmed to read tempretures and start the fan.
Hope this helps
Jigsaw
FixYa Team
  • 2,071 Answers
WHAT IS WRONG WITH YOUR REFRIGERATOR?
Hi there
I am trying to - small_4_1.jpg For a detailed Refrigerator illustration, click below.
Side by Side
Freezer on Bottom
redarrow.gif Under counter
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Hope this may help;
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Sep 01, 2008
    Did the solutions from all of us experts solved your problem if
    not then let us know the current updates so all the fixya experts can
    assist you further.
    Master:
  • 521 Answers
Check all the connections first.
  • tech expert12 Aug 26, 2008
    yes it is possible to attach the fan in your refrigerator.and the another thermostat is definately required for this.with a high voltage stabilisor fuse.because if the extra load of curren flows through the unit only fuse will blow and the remaining parts will be safe.but for your safety i would suggest a technical help is very much necessary for this.because if some thing goes wrong and if the compressor blows out.then it would cost you very much to get it repaired.as at present what you want to do is very minor thing.it would cost you not more then the engineers service charge.so please utilize your unit properly as it is perfect do not make it scrap by exprimenting.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
Maxim 20'7 boat with a cuddly cabin and a 120 horsepower Mercury force outboard engine. What is the weight of this boat?
if you cannot get the details from the manufacturer of the boat and it is not on the compliance plate that should be attached to the boat( plate shows length, max hp motor to be fitted , registered no of passengers possible ,weight etc ), the only thing left to do is to put it on a trailer that is big enough and have it weighed at a public weigh bridge /station
you will be expecting a weight in excess of 1.5 tons or 1500 kgs
most 20 ft boats run on a tri axle trailer because of the weight and length
Sep 17, 2016 | Boating
Can I fit a SUZUKI RM 250 Engine into a 2000 RM 125 frame?
Hi, Anthony sounds like something I would try when I was a kid but after careful deliberation 4 out 5 Suzuki Gods give this one a thumbs down, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm it's just not worth the time trouble and expense you would be better off getting a used 250 bike. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
swapping rm 250 engine into rm 125 frame Suzuki 2 Stroke
Dirt Rider Magazine
RM125 250 frame
will my 250 motor fit in newer 125 frame Suzuki 2 Stroke
Jul 24, 2016 | Suzuki Motorcycles
Does an 1998 Suzuki RM 125 Engine fit into a 2000 Suzuki RM 125 frame ?
Hi, Anonymous after careful deliberation 4 out 5 Suzuki Gods give this one a thumbs down, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
RM125 250 frame
Dirt Rider Magazine
http://www.vitalmx.com/forums/Moto-Related,20/Suzuki-RM-250-Conversions,1247347
Electrolux rm 4200 repair
Try 1,000 Volts, proceeding up to 10,000 Volts. I'm sure something will happen.
Sep 18, 2014 | Refrigerators
Hi just bought campervan which has an electrolux rm 2200 fitted we are unable to use it on 12v but works well on mains.
was the engine running on vehicle when you tried to operate 12v mode. From the user manual it needs the fridge cooled down on gas or mains first and it will only operate at 12V if the engine is running to prevent vehicle battery running flat.
Aug 13, 2014 | Refrigerators
Heating element
Remove back plate and you should see it middle bottom of machine ,it has two Spade Terminals with two wire fitted to it also an Earth onto its case,You can look up heating elements on the net, this will give you some idea of what they look like and cost.
Jan 15, 2014 | Electrolux Washing Machines
Rm 250 starting problem
Hi, Dave and the usual suspects are:
1. Enrichner system plugged, not properly functioning or improperly operated.
2. Fuel overflow.
3. Restricted fuel supply.
4. Gas cap and or fuel tank not venting properly.
5. Plugged slow jet or passages.
6. Inlet system air leak.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
RM250 will not start
Why The RM250 Was Hard To Start
Suzuki RM250 Owner Service Manual
OEM parts for Suzuki
http://www.crservice.dk/Suzuki%20cross/RM-Z250/RM-Z250_01A_L1.pdf
Mar 15, 2017 | Suzuki RM 250 Motorcycles
Can't get dustbag to fit
The dust bag doesnt fit into hose your supposed to out ur bag into the plastic bag holkder then sit inside the canister and this model does not take an ox bag it takes an s bag y
Apr 10, 2009 | Electrolux Harmony Canister Vacuum -...
How to Fit a Cabin Filter
Hiya...the cabin air filter is located below the front passenger/windshield area.
It's only accessible by standing outside the Equinox with the hood open.
Here's how to do it...(before you pop open the hood)
1) Stand outside at the front-right door area.
2) Just below the front windshield area, pull up a few small black plastic clips that's on the black windshield wiper cowl area- a small flat screwdriver or a special clip-remover tool is handy.
3) Raise the hood up.
4) There may be a triangular-shaped hard foam sound damper at the left side nearby the hood hinge...pull it off if it allow you to work around it with ease.
5) Continue to find a few black plastic clips around the black windshield wiper cowl area.
6) Gently pull up the black windshield wiper cowl cover with care not to bend it too hard during removal.
7) You should see the cabin air filter inside that's held in place by a black rectangular box inside.
8) There's 2 black tabs that holds the cabin air filter in place.
9) Insert your finger or tool to pry the cabin air filter away from the tabs.
10) Remove old cabin air filter.
Remember to reinstall the clip parts back into place when you're finished.
Nov 12, 2008 | 2006 Chevrolet Equinox
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
