Question about Mitsubishi VS-70601 70" Rear Projection Television
Convergence Problem? I have a Mitsubishi VS-70601 ,the picture is bowed down at top,up at bottom & bowed in on left side.I replaced the 3 STKs ,checked the source resistors,the + & - sources are correct,any suggestions? Thanks rioconcho
  • 6 more comments
  • earl mccain Aug 26, 2008
    This Convergence moduel is both the( out-put & control) for the convergence,it has no peco or other fuses on it.You would have to have worked on this model to be able to help,guessing is really not helping.
  • earl mccain Aug 27, 2008
    I have a Mitsubishi VS-70601 ,the picture is bowed down at top,up at bottom & bowed in on left side.I replaced the 3 STKs ,checked the source resistors,the + & - sources are correct,any suggestions? Fuses are ok,set didn't have power surge.Voltages are correct,horz. & vert. convergence control works on both red & blue.just have these bows. Rioconcho
    Still looking for help on this convergence problem
    No one is addressing the problem & has obviously ever worked on this convergence moduel.This moduel uses 3 STKs (Mit. model VS-70601),The amp,control,& STKs are all (one) moduel.I've beek working on these tvs for 30 yrs,but got stumped on this one.Just telling someone to replace the board really isn't very helpful. Rioconcho
  • earl mccain Aug 28, 2008
    It's obvious that none of the experts on this site has ever seen or worked on a Mit. VS-70601. If you haven't then you can't give (expert) or even a good guess,so far thats all i've gotton.Thanks anyways.
  • earl mccain Sep 16, 2008
    None of the advice worked on the Mit. I also have a AKAI PT5499HD Perfect Black & White picture but absolutly no color,
  • JTK25GUNS Jan 27, 2009
    I have the same problem but I can't move the convergence buttons on the remote and I am debating on havng someone come out to fix it,My big question is do I fix it or should I just buy a new updated TV.....
    Thanks,
    John
    Novelist:
    Champion:
  • 203 Answers
Seems like you have been having some hard times on here getting good help. If you will tell me everything from start to where you are now I will help you for sure. I own and opperate a tv shop here in jacksonville, fl. Also if its easier just email me experttv@comcast.net I need to know everything you have done and if the pic looks the same as when you started or if it has changed at all.
Posted on Sep 16, 2008
    Scholar:
  • 163 Answers
Perhaps link below helps on your problem. Have a look
The EURAS repair tip database for professional technicians and service engineers supplies the following faults for VS70601 / MITSUBISHI.
List of fault symptoms:
  • No start-up.
  • Relay clicks and power LED lit at start-up. Shuts down at start-up.
  • Vertical tearing.
  • Shuts down (intermittently).
  • Tripping.
  • Convergence adjustment code.
  • Shutsdown at power up. Short detect circuit activated (pin 13 of IC700).
  • Picture shifted to the right. OSD OK .
  • No OSD.
  • Shutsdown at power up. X-ray shutdown activated (pin 55 of IC700).
  • Shuts down. (VS70601 MITSUBISHI repair tip)
  • Dead. after power failure.
  • No picture.
  • Option codes.
  • Dead.
  • Circuit adjustment code.
  • No audio. No picture (at start-up). Shuts down.
  • Shuts down. at start-up. (VS70601 tip from MITSUBISHI)
With this service information, you may repair MITSUBISHI VS70601 faster/better when it fails.
http://www.euras.com/repair_tips_1/MITSUBISHI/VS70601/VS70601_MITSUBISHI.htm
Posted on Aug 28, 2008
    Genius:
  • 2,920 Answers
They will charge you for the service and repairs to the tv.its not in the convergence area its going to be a resistor thats gone bad but take some friendly advice and take it in for proper repair,
    Genius:
  • 1,665 Answers
If you dont feel familiar with electronic repairs better take it to an authorized service station to troubleshoot and estimate if is cost effective to repair.
Posted on Aug 27, 2008
    Genius:
  • 1,226 Answers
Check also the regulator and the capacitor near the vertical and Horizontal panel.
melnavz
Posted on Aug 26, 2008
  • 157 Answers
Is their any signs of burns on the circuit boards
Your Tv may have suffered a power surge from a storm
Check for any signs of thermal damage to the board
    Master:
  • 638 Answers
If stk are properly replaced then it could also be the problem of fuse.if its blown this problem could occur.
    Master:
  • 521 Answers
Actually you have detected the perfect problem.and also fitted the 3STKs very properly and correctly.so it shows proper negative and positive.it could also be the track short some where on the board and also because of the capacitors.so if you have proper technical knowledge check all the tracks.aan trace which one is faulty and give a minute joint to that track by soldering iron.but if you do not have proper technical knowledge just get it repaired by the technician.as the board is very costly.and at present it is not in that worse condition.and your problem is very minor.it will not cost you more then the technicians service charge.hense tou have replaced the main problem of 3STKs.
pls do rate the solution
thanks.
regards.
fixya expert team
  • tech expert12 Aug 26, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
  • Mitsubishi Master
  • 19,396 Answers
On the service manual you find a convergence setup procedure, did you do that?
Left convergence on mitsu vs-60609
Convergence IC's inside of your TV are nearing end of the life. If during adjustments that you made Red and Blue was moving in all directions (left, right, down, up) than resistors and fuses still probably OK. IC's (part number will start with "STK" and they attached to huge aluminum radiators) have to be replaced and fresh heat sink compound have to be applied.
After that convergence adjustments should not be a problem. And color will stay together for another several years.
regards.
Russ.
Apr 04, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Hey I have a mitsubishi vs-80803 i have picture but it is a bit bowed on the right side and bottom of picture (black curvature space showing no colors or picture) maybe the convergence needs to be reset?...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 05, 2010 | Mitsubishi VS-80803 TV
Tv turns on. There is a picture but it looks like your looking through a fish bowl. Bowes into the middle from both sides. It also looks 3D. Any Clue??
This is usually a convergence problem, although the bowing normally is from the top and bottom rather than from the sides. There may also be an issue with the pioncushion circuit that causes the bowing. Try the automatic convergence adjustment first. If that fails to resolve the problem, then resoldering the convergence ICs would be next followed by replacing the ICs should the resoldering fail.
If you wish to attempt the repair, please update this and confirm the model number to be VS-60607 and I'll provide additional details.
Thanks,
Dan
Dec 08, 2009 | Mitsubishi VS-60607 TV
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
Hitachi 50fx30b picture bows on top and bottom and the colors misaligned---can anyone help???
Rplaqce Both of your STKs convergence ICs and 7 low ohm resistors If STKs are STK392-110s upgrade to 180s.
Jul 20, 2009 | Televison & Video
Bowed screen left side top to bottom probably 1 1/2" deflection... need to know how to adjust the projector lenses
Projection sets have two very common problems outlined below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Jul 15, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
MITSUBISHI MODEL NO. VS-5043 BOWED AT TOP AND BOTTOM.
This is a convergence problem. The output ic needs to be replaced.
Apr 01, 2008 | RCA HD52W59 HDTV Projection Television
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Televison & Video Logo
198 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
