Question about Panasonic Lumix DMC-FZ10 Digital Camera
Filter I like to keep a filter on at all times to protect my lens on my new FZ10. I am fairly familiar with the effects of various filters on 35mm cameras but don't know what affects these digitals. I have several UV and Skylight filters around that I can use on my FZ10 with my PD62 adapter. Which works best with digital cams? What do you use?
    Master:
  • 903 Answers
Skylight filters don't generally block UV, they change the colour tint optically, which you can do without danger of image degredation in post-processing, so I woudn't really recommend using a skylight filter for digital cameras. I haven't tried a UV filter on my fz10, only my circular polarizer. From what I've heard however, a uv filter may act as lens protection (or use the lens hood), and might in some circumstances reduce haze (rarely), and there are unconfirmed rumours of possibly reducing purple fringing. If anyone could ever confirm this, I might consider one. Otherwise, UV filters also seem peripheral for digital photography. Probably the most important optical filter you can use is a polarizer. This can cut a lot of excess scattered/polarized light and reduce excess contrast, increase sky colour saturation, etc. It's effects are extremely difficult or impossible to get in editing.
Posted on Sep 06, 2005
Will the Quantaray 49mm to 55mm step up ring work on a Sony a100 DSLR camera
The step-up ring will on any lens with a 49mm filter thread, regardless of the manufacturer. The easiest way to find out whether it works with any given lens is to see whether the ring fits onto the front of the lens (you could also read the filter size written on the lens itself).
If it doesn't fit, purchase the appropriate step-up ring. That will be much cheaper than buying a whole new set of filters.
If the new lens(es) have a 55mm filter thread then you don't need the step-up ring at all. The filters will mount directly onto the lens.
Mar 17, 2013 | Cameras
I am a sigma lens and filter user for my Nikon D60. I haven't used filters before and have acquired a 72 mm DG Filter. I would like to know how to use it properly, Any suggestions would be gratefully...
It depends on the filter.
If it's a DG UV (ultraviolet) filter, it cuts reduces the ultraviolet light reaching the lens. UV light scattered from particles in the air is what produces much of the haze that can obscure distant objects like mountains. Other than that, it has little visible effect. Some photographers like to keep an UV filter on their lenses at all times, on the premise that it's cheaper to replace the filter instead of the lens should it bash into something.
If it's a DG Circular Polarizer filter, that's something completely different. A polarizer cuts light waves bouncing in a particular orientation. You get this kind of light in reflections from glass and water, for example. Try looking out a window through the filter. By turning the filter (it has a rotating ring on it), you should be able to accentuate or reduce reflections and glare. It can also darken the sky, reduce reflections from leaves, and has other effects. The best way to explore its uses is to go out on a relatively sunny day and look at things through it. Try taking pictures with and without the filter and compare the results.
Since the D60 meters through the lens, you don't have to do anything to compensate for either filter. Just put it on and take the picture.
If you have any other questions, please feel free to ask.
Jan 04, 2011 | Cameras
Small scratch on front lens causing shadow on some photos, in particular on clear blue sky when a small area in the photo appears slightly deeper blue than the rest.
You have only two fix options:-
1. Get the front lens element replaced by Panasonic. This will be fairly expensive. Afterwards, buy and fit a skylight filter to protect the lens.
2. Buy a skylight filter to protect the front of the lens from further damage and use photo processing software to retouch the affected images. This won't necessarily cost much, but will be a real pain to have to do all the time.
Whatever you do, do not attempt to polish out the scratch as this will destroy the lens coatings and will also reshape the lens slightly ruining it's optical qualities.
Feb 03, 2010 | Panasonic Lumix DMC-FZ18K Digital Camera
I just purchased the Zeikos fisheye lense for my 50mm Nikkor lens and when I attach it, it doesn' take fisheye photos - just regular with some distortion around the edges... am I using this incorrectly?...
The 50 mm lens is a full frame lens, and the D80 is a DX camera. This means that the 50mm lens puts an image out that is bigger than what the D80 can "see". The good part of this is that the D80 (and most of the other Nikon DSLR's) use only the image from the center part of an older lens. The bad part is that if you put the fisheye filter on it, the fisheye effect that is mostly seen at the edges of the lens doesn't show up on the D80 sensor. If you could put the fisheye filter on a DX lens, it would give you the full effect.
Sep 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
I would like to know what these do
Bower is brand name skylight is slightly yellow helps soften light there are diffrent densitys. Filter is mostly used to protect orginal glass of lens from dirt smudges scratches & rough treatment. Keep on lens most of the time.
Hyda brand name. PL 3 i believe to be a dark polarizing filter.
Quantaray 1A4 I believe is a haze or skylight filter.
Haze filter does almost the same as a skylight filter.
Hanimex brand name. Polarizing filter used to shoot through reflective glass or surfaces (water), also in color used to sharpen colors. The reason it is turnable is it is light directional beaning light comes through it at a angal hold up to light & turn it you can see how it darkens or litens. Also can stay on lens when not useing skylight filter.
reason you have 2 is one of each for two diffrent lens, 49mm & 55mm.
Hope this helped. Please rate.Thank You.
Mar 11, 2009 | Pentax K1000 35mm SLR Camera
Does my Nikon D200 have built-in filters? or do I need to buy the Cokin filter system?
Your camera doesn't have any filters built in, but you can simulate a lot of the filter effects in post-processing. You would be advised to have polarizing filters for your lenses, and possible neutral density graduated fiters (which do work in the Cokin System). Those are difficult to do without.
Apr 22, 2008 | Cameras
F717, protector and lens cap (question)
Had the same problem with my polarizing filter. The Sony lenscap was not a snug fit onto the polarizer. Solved the problem by purchasing a cheap third party 58mm lenscap at a retail photography shop. Cost under $5.00.
Sep 12, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
Types of filter lenses to use with DSC-F505 camera
I bought a Hama skylight filter for the express purpose of protecting the lens. I've not noticed any degradation in image quality. Of course, ultimately the filter will block some of the light that's hitting the CCD, but it's so little as to not be noticeable. Being as the lens cap clips into the thread of the lens then yes, it does still fit perfectly into the thread of the filter, so no problem there!
Sep 08, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
90 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
