Agaitor how do you remove the agaitor? i have a seal that is leaking from under the agaitor
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
My advice on that situation is call service or you may have to spend more later!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
I have found that the jet ski will start prior to entering the water, but as soon as I launch the ski will not start...unless I remove the air filter case cover.? Any idea why this can happen?
Your stator sounds like it maybe not supplying enough ignition spark when the motor is under a load. When you put the ski in the water the motor is under much more of a load then when out of the water or on a trailer. Those are the signs of a stator going bad. Another option would be leaking crank seals. The seals need to hold pressure to pump the fuel to the motor. Sometimes the crank seals can burn up the stator if the seals are leaking. You can remove the flywheel cover and to inspect for a leaky front crank seal. It should be dry inside, but if it is all oily and wet, your seals are leaking.
Aug 18, 2015 | Yamaha 2004 WaveRunner GP 1300R
Do i need a special tool to remove the transmission seal on a 2002 kia sportage?
Which Seal?
Have you gotten under & checked the driveaxle seals?
The big leak will be the torque converter pump seal
That requires removing the transxale
Sort of old to do that & not rebuild the trans while your at it
May 16, 2014 | 2001 Kia Sportage
Water in lower unit of merc 1994 20hp
the seal around the drive shaft is leaking ---split the leg and replace or the seal behind the prop is leaking -- remove the prop and replace I would go for the drive shaft seal as it is under pressure from the water pump.
Mar 28, 2013 | Cars & Trucks
HOW DO I FIX THE OIL LEAK COMING FROM UNDER MY GXV 120 LAWN MOWER ENGINE?
Depends where it is leaking from, wash it off to see where it is coming from, it may well be the bottom crankcase seal, once the blade and carrier are removed you should gain acess to this, if it is leaking you will need to remove the seal and replace.
Oct 07, 2012 | Garden
My transmission leaks what should i replace
There are at least 5 places on the Automatic transmission that can over time, and mileage develope fluid leaks. Front converter seal at the front of the transmission,pan gasket in the center,dipstick tube o ring at the center on one side ,speed sensor o ring,and the tail shaft seal at the rear,of the transmission.
Place a flat piece or huge card board,under the engine and transmission,after driving you will see where the fluid,red in color is dripping. Its easier to spot exactly where the leak is comming if you can look under the car,while it is running, The easiest leak is the pan gasket,the dipstick tube, and the speed sensor,then the rear housing tail shaft bushing and seal.
If the front seal(converter seal) is leaking the transmission will need removed,and the seal,and maybe even the front pump bushing Replaced,it would be a good idea to replace the bushing esp if it has high mileage,80,000 or 100,000 miles of use.Change the fluid and the filter,while repareing the leak or leaks.Is a good idea.
Sep 17, 2010 | 1995 Chevrolet Camaro
Oil leak under front sproket
The oil seal on the sprocket shaft has probably gone bad. Remove the sprocket then clean the shaft to aid in removing the old seal. A screw driver and small hammer is used to pry the outer edge of the seal inward. Realize that you will butcher the old seal in the process of removal. The only other way to remove the old seal is to pull the engine and split the center case.
Jan 18, 2010 | 2001 Yamaha YZ 426 F
I have antifreeze leeking out a pin hole under the water pump
It is very likely the water pump seal. It is always a good idea to replace the bearing while you have it opened up.
Jan 13, 2010 | 2002 Honda CRF 450 R
Maytag performs washing machine
you need to tilt the dispenser to one side then it will pop off once you get that off you need a socket set to remove the bolt from the center of the agitator after removing the bolt the agitator just lifts up
Dec 26, 2008 | Maytag Performa PAV2200
Water leaking under the tank
If the water is coming from under the cold water tank on the back of the machine it probably the o-ring seal in the grey machine recepticle which is visable when you remove the tank for filling. This seals the tank to the machine body and over time can leak (mine has!!). You can get them from Gaggia UK in Halifax
Dec 24, 2008 | Saeco Magic De Luxe Espresso Machine
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe? water...
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Sep 07, 2008 | 1999 Toyota Camry
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
