Question about KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
"Call Repair" Alert
We are getting a "Call Repair" alarm on our fridge that is about 6 years old and has been working very well. It is still working well but is getting this alarm. The only symptom that appears to be changed is that we are getting ice/frost buildup on the back wall behind the 3 shelf in the refrigerator compartment.
We have reset the over-temperature alarm and the water filter alarm but the "Call Repair" alarm continues to ring.
I have also taken the top grill off and vacuumed dust and lint off the upper coils.
Any further suggestions??
  • Anonymous Sep 07, 2008
    I've got the same problem just started Thursday
    Novelist:
    Champion:
  • 261 Answers
I would call service as maybe the servicing of the coils did it but that over temp is your compressor over heating and the icing up means your probably low on freon.
Posted on Sep 20, 2008
How do I fix the continuous beeping coming from my refrigerator?
LG Fridge Door Alarm ' Chris Inch
www.chrisinch.com/blog/articles/show/lg-fridge-door-alarm/
Aug 30, 2006 - It's just too bad I can't live with beeping noises going off every 30 seconds. .... took them a long time and they scratched the paint) the fridge beganbeeping ..... I opened the fridge door to let the alarm sound and then located the alarm..... I can't tell you how many times I've "snapped" since hearing this thing.
FIXED Frigidaire Professional Constant Beeping - ApplianceBlog
www.applianceblog.com/.../17546-Frigidaire-Professional-Constant-Bee...
Jan 15, 2010 - 10 posts - ‎3 authors
The refrigerator is not refrigerating and I don't here the fan go on or ... the water comes out from the water dispenser and so does the ice. ... Thank You so much! ... The unit is two years old from time of purchase. ... Then to install it you remove the #81 screws here: 11-Controls parts .... All times are GMT -6.
Fisher & Paykel fridge in alarm - Kitchen - Home - Whirlpool
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolJan 24, 2010 - I push the selector button to mute the alarm and then it may not do it again ... I can determine the fault code through the number of beeps/flashes? ... myfridge started beeping every 6 hours abut a week ago. ... posted 2012-Aug-7, 3:17 pm.... If so, defrost the coils behind freezer, you can use a hair dryer to ...
Feb 03, 2016 | Refrigerators
My fridge alarm keeps on beeping. it is eleven beeps at a time about 2 minutes apart. How do i disable or deactivate this alarm. there is no alarm button on the panel.
Beeps from electronic appliances are indicators that usually have something to do with the motherboard giving an alert. They refer to a list that tells a technician what system requires attention.
May 14, 2015 | Refrigerators
Can a Miele fridge freezer with both sections warm, fans working, be repaired?
You mean it's not an auto-defrost model? It should be, no older than it is.
Sep 05, 2014 | Refrigerators
Alarm is going off every 2 hours indicating freezer temperature is high. We can't turn off alarm, button is not working. We have to turn off the breaker but it continues to happen every 2 hours. We...
you have a defrost or system issue open freezer drawer snow on back wall you have a defrost problem not too costly
no snow on back wall and you can hear fan running in freezer most likley a low side system leak
viking warranty on sealed system 6 years full 12 years parts
also unrelated you fridge should have hinge recall done if not done yet this repair is covered by viking
Nov 13, 2017 | Viking DFBB363 Bottom Freezer Refrigerator
Two first alert smoke detectors go off for no reason. All are on 110 with good batteries. Have had these for approx. 12 years with no problems until now when 2 of the 7 have gone off many times in the last...
There may be dust built up in the sensing chamber. This can cause alarms to go off for no reason. Try vacuuming the alarm off particularly around the sensor if the cover is removable. These alarms should be replaced however, as they are more than 10 years old.
Apr 07, 2011 | First Alert Brk / First Alert Smoke...
Fridge too warm....
the fridge is short ov gas it should cost about 60 pounds to repair
Apr 23, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
I have a 6 year old American style fridge freezer. In recent times the freezer alarm has been permanently flashing and sounding periodically. The freezer does not appear as cold as it once was and it's...
Hi thanks for the question. first i would clean all the coils at the back. remove panel and clean . then check to see if the fan in freezer works. then see if any Frost has built up on back wall of freezer. if frost on wall, you have a defrost problem. thanks the appliance doc
Oct 01, 2008 | Whirlpool Refrigerators
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
Apologies, the above two guest comments are mine, not sure what happend!!
Oct 16, 2007 | Whirlpool S20DRSS33 Side by Side...
KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator Logo
182 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
