Question about Radio Shack VGA PC Camera Webcam
Tiny screen I just bought the gigaware 2.0 webcam and installed the software with no problems. However when using aim to chat is the video chat window supposed to be microscopic or is it just my computer?? Please let me know if this is what I paid for, or how I can fix it! Thanks!
    President:
  • 8,637 Answers
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Posted on Jan 13, 2009
Error during capture error code 800706f8
The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
windows-xp-other-device.jpg If the device is not recognized in Windows XP, it will be listed under Other Devices.
windows-vista-device-error.jpg In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the webcam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to uninstall the software that came with your webcam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party uninstaller.
After uninstalling the software, restart your PC and then reinstall the webcam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your webcam during the software installation.
If the drivers and webcam software are correctly installed, and you still cannot see any video, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the webcam feature. If you have multiple devices that qualify for video, you might need to select your webcam device as the source for the webcam feature in that program.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
Lastly, if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
video-capture-properties.jpg Do keep in mind that not all settings will be enabled depending on the webcam and the webcam driver installed on your computer. In the example you can see that some settings are disabled. The example shows the video capture properties for an Acer Crystal Eye webcam.
What else to try: download missing webcam drivers! If you are using your webcam for instant messaging with one of the popular chat programs, have a look at EatCam, which allows you to record your webcam chats from MSN, YM, ICQ, Skype, AIM and a few more!
Mar 05, 2011 | Computers & Internet
I am trying to install a gigaware webcam with mic. It wont install the webcam. The mic works.
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
May 30, 2010 | CIBA Vision Gigaware 2.0MP Webcam
Howhow to install my gigaware web cam
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Jan 04, 2010 | CIBA Vision Gigaware 2.0MP Webcam
When I tried to use my HP Deluxe Webcam thru AOL Instant Messaging (AIM) for a video chat, the other person could see the video but could not hear me. The software that came with the webcam is ArcSoft...
See section D. AIM AOL Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
On the VIM sign-in window, click on Edit.
Microphone
Speaker
Camera
conversation before running setup. Would you like to disconnect now? Click the Yes button.
Notes:
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Jul 14, 2009 | HP KQ246AA Deluxe Webcam
Giga ware 2.0 webcam
See section B. Yahoo Messenger in the info below to setup the Audio & Video.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
http://ca.messenger.yahoo.com/download/
After downloading and installing Yahoo Messenger set it up as follows:
1. Click on Messenger at the top left and then go down to Preferences and then the Preference Window will come up.
2. Next click on Calling and Devices. In the Calling & Devices on the right and set the Microphone and Speakers to the computer Audio Card or sound device installed in the computer.
3. Just below that, go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
4. Then after completing the Audio Setup, on left panel, go to down and click on Super Webcam and click on Start Super Webcam Mode Automatically.
5. Then click APPLY and then OK.
6. Next click on MESSENGER and then click on MY WEBCAM and you camera should BRODCSAST and you will see your picture.
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
Microphone
Speaker
Camera
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
Jun 17, 2009 | Computers & Internet
I lost my gigaware webcam software
Copy this site and paste it in your web browser address bar and hit your enter key.
http://www.radioshack.com/uc/index.jsp?help=yes&page=software
It has the Description and Model number.
Then download the driver for your camera and install it as below.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Jun 02, 2009 | Radio Shack VGA PC Camera Webcam
Gigaware camera wont work AFTER i installed drivers
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Apr 27, 2009 | Radio Shack VGA PC Camera Webcam
Gigaware pc camera with mic
i have a gigaware webcam and no matter how i try to install it with the CD it is not connecting
Aug 30, 2008 | Computers & Internet
Dv2000 laptop webcam
1) Reinstall the Webcam Drivers in the Notebook :
Webcam Drivers for XP :
ftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35414.exe
Save the Drivers in the Notebook and double click the downloaded file to install the Webcam Driver.
Webcam Drivers for Vista :
ftp://ftp.hp.com/pub/softpaq/sp34501-35000/sp34746.exe
Remember to restart the notebook after installing the Webcam Drivers.
Now, download the Cyberlink Youcam software from HP which is integrated with latest Notebooks to use the webcam with :
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39372.exe
You can use the instructions in the link below to test the webcam using Youcam application in Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01414839&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You can also try this application to access your webcam :
http://www.yawcam.com/
Using webcam with.....
AIM Video chat:
http://www.ucalgary.ca/it/help/articles/networks/videoconf/aim
Yahoo Video chat:
http://www.ucalgary.ca/it/help/articles/networks/videoconf/yahoo
MSN Video chat:
http://www.bus.umich.edu/Technology/WebServices/DesktopVideoConferencing.pdf
Windows Live messengers:
http://www.ucalgary.ca/it/help/articles/networks/videoconf/livemessenger
Skype Video chat:
http://www.ucalgary.ca/it/help/articles/networks/videoconf/skype
Hope this helps..
Jul 16, 2008 | HP Pavilion dv2000t Notebook
Sending email with webcam
Normal 0 Double click on this site to get the Gtalk Plug-in for “Voice & Video Chat
Gmail voice and video chat
A few days ago Google just release a new chat functionality for Gmail, this is a new video and voice chat plug-in that will let us to see and hear our family, friends and contacts from within Gmail with a high quality audio and video.
To start using this new functionality you just only need to download and install the new Gmail voice and video chat plug-in and a webcam.
The voice and video chat plug-in for Gmail is free and only works with the newer version of Gmail in supports Browsers FF 2.0+, IE 6.0+, Safari 3.0+, and Google Chrome.
BTW, the video and voice plug-in only can be installed on Windows XP or later.
For more information and Download the Plug-in please visit the Gmail voice and video chat page.
Click on “Voice and video chat” It's free and installs in seconds
System requirements:
  • Windows XP or later
  • Intel Mac OS X 10.4 or later
  • Chat more ways than ever from within Gmail
  • Look and sound your best with high quality audio and video
  • Get started easily -- all you need is a webcam
Dec 27, 2007 | Computers & Internet
Radio Shack VGA PC Camera Webcam Logo
76 people viewed this question
Top Radio Shack Computers & Internet Experts
Mark Gough
micky dee
Mike
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
