When driving 35 mph or more a clicking noise occurs. It kinda sounds like a card clicking on bicycle spokes, but does it when accelerating or slowing down. I can push in the clutch or put it in neutral and it quits.
Check your CV joints - usually you'll hear them clicking the most when you turn a corner while pressing on the gas, but they can make noise like that while you're driving straight. Given that it's most prominent above 35mph, I'm not sure that this is going to be the issue, but it's worth checking - if it is a CV joint, and it breaks, your car will coast to a stop and you won't be going anywhere except on the back of a flatbed.
Hello
The
Engine and Automatic Transmission (not applicable to manual
transmissions) in this vehicles drive train are fully
electronically controlled by a computer called the PCM and TCM (Power
Train Control Module, Transmission Control Module). When a problem
like this or other drive-ability related problems occurs the computer
stores a record of the problem (there are of course some exceptions
to this, like the fuel pump, engine coolant temperature sensor and
MAF sensor for instance) in the form of a fault code in its memory,
to read these fault codes you must have the systems memory scanned
with a special tool. Once the fault code(s) are read you then must
perform the appropriate diagnostic testing to find and resolve the
problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED
TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD
EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always
check fuel pressure for correct spec for your make and engine type.
