Question about Weber Spirit SP-310 Propane Grill
On my Webber Spirit E 310 the ignitor no longer works. it does not click. i changed the battery and tried it both ways because I forgot which way I took it out. It had slight corrision on the battery which I cleaned up but still nothing. Any ideas? Does the positive go up or dorn? Is part number 1819-51 still available? Thanks Kirk Mckee
    Brigadier General:
  • 4,736 Answers
Hi, Kirk. The positive end of the battery should face you, when you install it. Before you rush out to buy a new ignition module, check all the wiring from the module to to each spark ignite. You want to make sure that all wiring is in intact, that the ground wire for the module is attached to the grill frame and that the spark igniters are clean & free of grease.
If you find you need to replace the igniter module, you can find it at the following link.
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=496283&modelsID=124200
Hope this helps you. Don't forget you can match light the burners if necessary, until the igniter module is replaced. Happy Grilling!!
Posted on Jul 12, 2011
  • Rich Landrum Jul 12, 2011
    Glad I could help you, Kirk. Thanks for the 4-Thumbs Up Rating. I really do appreciate it.
First, just pull off the igniter cap/button straight up.
change the AAA battery. Mine lasted 3 years.
this should solve most igniting issues.
Posted on Apr 18, 2015
How do I change the battery on my Weber Spirit igniter
does it have a battery
most cookers are pizo operation which operates by the button being pushed action
Jun 25, 2016 | Weber Spirit? E-310 Propane Grill
Weber spirit ignitor
The metal contact inside the push button ignitor is probably sticking.
Aug 25, 2014 | Weber Spirit SP-310 Propane Grill
Grill was lit and when I went back to check it was off and i can't get it started, just clicks, seems like the starter.ignitor is broken?
Did you try to light it with a match? If it lights, then you have propane. If the ignitor is :clicking, usually it is sparking also.
Jun 04, 2011 | Weber Spirit? E-310 Propane Grill
Ignitor will not strike
Have you changed the battery in the Ignitor Button? If not, unscrew the plastic ring that holds the ignitor button/cap in place. Once you have, you will see either a AA battery or a AAA battery. Note which way it's facing. Replace the battery with a new one out of the package, being sure it's facing the right direction. But, before putting it in, check inside the holder for any corrosion that the dead battery may have caused. If you see corrosion, carefully clean it out.
If the above didn't solve the problem, check all the ignitor contacts at each burner for grease deposits. If you find some, clean it with a cotton ball dipped in alcohol. If that fails to solve the problem, check all the ingnitor wire connections to make sure they are still firmly in place.
Any or all of the above should solve your problem and get you back up grilling again.
Hope this helped you.
Feb 22, 2011 | Weber Spirit? E-310 Propane Grill
My weber spirit 310 igniter will not work. It does not click or make a spark. I have changed the battery. I did notice that the battery chamber was very corroded so I cleaned it out but still no click....
I suspect that the corrosion you found has taken it's toll. You will need to replace the the ignitor box.
if it's still under warranty, Weber may cover it. Either way, you can get the part from Weber on line. Make sure you have your Model #, Serial # of the Grill and the date and proof of purchase.
Feb 13, 2011 | Weber Spirit? E-310
Ignitor doesn't work
change the ignitor it is bad weber might send you one if you call them
Apr 18, 2010 | Weber Spirit? E-310
Ignitor does not work on EP-310 WEBBER GRILL
It could be a couple of things, if the ignitor does not click when you push the button, it could need to be replaced. It could also be a bad wire or electrode.
Dec 13, 2009 | Weber Q Grill
In June I bought a new Weber grill but the auto ignitor does not work--there is no click--therefore no spark. I can light the grill manually.
If there is no click, it is most likely the igniter module is bad. The igniter module should be available at any Home Depot or Lowe's; in any case, your owner's manual will show you how to remove and replace the igniter module. If you don't have the owner's manual, I will include a link to one online; you will need Adobe to open it. Here is the link: http://www.bbq.us.com/images_templ/weber-manual-3741001.pdf
Try this and if it doesn't fix your problem, come back and let me know and we will troubleshoot further. Good luck!
Nov 16, 2009 | Weber Spirit? E-310 Propane Grill
Gas grill ignitor no longer ignites burners
it is bad you need a new igniter, the flint part goes bad
Feb 20, 2009 | Grilling
Weber Spirit SP-310 Propane Grill Logo
7,040 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
