Connecting a photocopy to pc or network
Please how can i connect a canon gp215 to pc or network.
i don't know is there any port and even can i connect it to use like a printer or no,.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Can you tell if your copier has an ethernet network adaptor on it?
  • 48 Answers
Look for a nic. Its the same connection like you use on a computer its usually in the back of the machine.
Posted on Oct 17, 2009
  • jinn_0502
    jinn_0502 May 01, 2012
    what is mean of "nic"?
How do i connect Konica Minolta photocopy Biz211 to a computer for network printing?
First of all, make sure that there is network interface card is installed in your photocopier.
If yes, then connect the network cable to the machine.
Then from the control panel of machine, Go to "Administrator Mode" Administrator Setting.
Press--Utility---then select "Admin Setting"
Now enter Admin Password=000000, press "OK"
Now go to "Network Settings" and Assign the IP address to the machine.
After assigning the IP address, install the relevant printer driver, (compatible with your operating system) You can also download the drivers from the internet.
During the installation of drivers, select "TCP/IP Port" This port is used for network printing.Enter the IP address of Photocopier in this port number.
After finishing the installation, your machine is ready for printing.
If you are still facing difficulty at any point, feel free to ask any time.
Jul 01, 2015 | Konica Minolta bizhub Office Equipment &...
How to connect a 3 computers to one photocopier machine using an IP address.
As all your PCs have Internet connection, I'm assuming that you have some kind of "network" already installed.
On each PC connected to LAN (Local Area Network) use "add printer wizard" and choose "add network printer" option. The wizard should be able to find your Canon device.
Oct 16, 2014 | Computers & Internet
GP215 Canon Photocopier says close front door when its closed!
THIS PROBLEM DUE TO YOUR COMPOSITE POWER SUPPLY PROBLEM
Nov 28, 2013 | Office Equipment & Supplies
How do I clear error E100 on my Canon GP215 photocopier? The paper keeps on jamming continuously.
Odds are you will need to replace the fixing unit. The error code deal with the fixing unit not heating up to the correct temp.
May 22, 2012 | Canon Office Equipment & Supplies
I have a canon ir2016 photocopier which can print documents directly from a computer if connected to it! I have connected it to my windows xp2 pc through a usb port but it is not detected at all. how do I...
As far as I know, Canon IR2016 is stand-alone copier. Printing is optional using Network connectivity. The USB port found at the back is for upgrading purposes only.
Sep 08, 2011 | Canon iR 2016i Black and White Copier
How iconnect photocopy mechine to pc?
first of all do u have the driver .if u have one and u want to connect to a single pc then simply run the driver in ur pc and the connect the machine to the pc when prompted by it.u have to use a USB printer cable for it. To install it to a network u have to install the driver in the server and then give IP address to the machine in system settings/network settings and connect it with a R?J 45 cable in lan port .
Aug 20, 2011 | Canon iR 2016i Black and White Copier
I want to know what cable i need for my canon gp215 photocopier to connect to my mac comuter to use as a printer?
this photocopier has an ethernet network card installed. you need to connect the copier to a switch, hub or router and connect your mac to the switch, hub or router.
i think this copier also has a parallel port. you need to get a USB to Parallel port converter. this comes with a cable and will cost you about €10. You can use this to connect directly to the copier and use it as a printer.
You will need to download drivers for the copier and install them on your mac, see here
http://software.canon-europe.com/products/0000676.asp
Hope this helps!
Tom
Jul 22, 2011 | Computers & Internet
Let me know how can I connect canon c3100 to my PC so that I can use it as a printer.
U can connect through a network or even as standalone printer through usb port.In network connect the machine to the network through rj 45 cable and then load the driver in the server and access it from there .
Through usb simply run the driver when it asks to connect the machine connect the usb lead and rest it will take care of.
May 23, 2011 | Canon imageRunner C3100 Copier
How to network a Canon Imagerrunner 3030 copier
Set the Ip address on the copier to match your network's Ip - only use different last 3 digits (3 digits that aren't currently in use on your network. Set the Subnet to the same as your network's Subnet. Set gateway to your Router's IP address.
Then install printer driver on your server, or all individual PC's if you are not using a server . When prompted select "create new port", then select Tcp/Ip port from the drop down menu, then type in the Ip you set on your copier, and continue to follow prompts.
If you are using a server, then you should select "share this printer" when prompted, and after installation is complete, go to each PC, and go to the "add printer wizard, and select network printer, then select "browse" to find it on the network, and select it.
that's it.
good luck!
Jul 21, 2009 | Office Equipment & Supplies
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
The BD signal is not generated during image formation
because this error is related to LASER UNIT & BD UNIT we suggese try to repairing with help of a technician, don't self.
Thank's for using FIXYA
Jun 21, 2009 | Canon Office Equipment & Supplies
409 people viewed this question
jasbo
jasbo
