ViewSonic RC00070P remote issue
I have a ViewSonic RC00070P remote and a ViewSonic N3252w flat panel HDTV. The remote was working just fine 8 hours earlier, but when I tried recently the TV didn't respond. I tried removing the batteries for 5 minutes, and still no positive results. I didn't see any codes to reprogram the remote. Any ideas would be greatly appreciated.
  • 4 more comments
  • jdsoldan Sep 01, 2008
    Nevermind, purchased new remote.
  • it2howland Feb 23, 2009
    I'm having the same problem but on top of that, I can't get the tv to work manually! I can't even turn it off!
  • Anonymous Apr 27, 2009
    yo theres like no screws on this thing either do i have to just pull it apart?
  • Anonymous May 06, 2009
    i have the same problem and i fixed it once a while ago but it happened to me again and i cant remember how i fixed it
  • jesus Sep 17, 2013
    it2howland hola me puedes hacer un favor , de indicarme que numero de cristal lleva ese control remoto
    hola it2howland me puedes colaboarar didicndome que referencia es el cristal de este control remoto, gracias
Hi jdsoldan,
Where did you buy the new one? I have the same problem.
Thanks,
Posted on Sep 13, 2008
  • thow1906 Jan 13, 2011
    I would suggest that you first point your remote towards a digital camera to see if you can see the remote transmitting a signal (light will blink in digital camera's view lens)..... If no light than the remote's battery is dead OR there are other problems that is preventing the remote from working. Below is what I did with mine to get it to work.....
    I was having problems with my Viewsonic RC00070P remote control. It would not turn on TV or change channel/volume. So I removed the batteries and I pulled the remote apart by inserting a flat nose screwdriver in the side and twisting it to separate the two parts. Once I pulled it apart, I let it sit overnight....
    Vuala, the next morning I pointed the remote at my digital camera and I could see the blue light (indicating that the remote is transmitting a signal). It now works...
    http://www.remotes.com/store/help_deadre...
    T
Hello, I have a Viewsonic n3252w. It works for about an hour or two then black screen. Unplug it for an hour or two it works. Looked at lot of internet help sites and think its bad caps.
Most likely the power supply board needs to be replaced. Viewsonic is notorious for failure, it may not be worth trying to fix.
If you don't know what you're doing, DON'T OPEN THE MONITOR UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE MONITOR IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 20, 2016 | ViewSonic N3252w 32 in. LCD Television
ViewSonic N3252W LCD TV went pop and completely died. No power whatsoever. Not even the red light indicator that is always on as long as its plugged in.
The main power regulator board [SMPS board] has damaged. It should be replaced. Normally there is no repair to these boards. Only card base replacement is done. Check this to know more.
Jan 07, 2013 | ViewSonic N3251w 32 in. LCD HDTV
Power lock is on
There are keyboard locks that will lock the remote out on all functions there and remote lock outs that will do the same for the remote but both usually will not lock just one feature out especially if the power button works on the set but not with the remote.
Dec 18, 2012 | ViewSonic N3252w 32 in. LCD Television
Viewsonic n3252w psu change,pwr on screen go blue 1sec.to black
The main board will have faulty component/s. Seek tech support.
Jun 07, 2012 | ViewSonic N3252w 32 in. LCD Television
Viewsonic N3252W picture ok but no sound
Download the repair book to this TV by net. It will have all details.
May 23, 2012 | ViewSonic N3252w 32 in. LCD Television
How to reboot N3252W
Unplug the power, wait an hour, then plug it back while holding the power button down. This will reset back to factory settings and most likely will solve your problem.
Mar 01, 2012 | ViewSonic N3252w 32 in. LCD Television
TV won't turn on with remote, but remote does work.
If the control buttons on the side/back of the tv works then you can verify the remote works.
Take a digital camera(turned on) and point the remote at the lenses. Press the remote buttons and look for flashes on the camera's lcd.
If the remote works then the remote receiver on the set may be bad and need to be repair/replaced.
Feb 13, 2011 | ViewSonic N3252w 32 in. LCD Television
Programming a universsal remote. My comcast remote never works with the TV. I'm frustrated. Been trying for almost 2 years no luck.
Buy an aftermarket universal remote such as a Harmony, they will control nearly anything. Don't wast your time with the comcast remote they are rubbish. I have a viewsonic TV as well and harmony had the codes.
Mar 22, 2010 | ViewSonic N3252w 32 in. LCD Television
My ViewSonic N3252 display is just a black screen in all inputs. Sound works fine but no picture.
As with most LCD screens the two most problems that cause black screen are bad a solderjoint on the inverter board or bulging capcitors, the next problem would be most likely the power mosfets witch break down after time.
Jul 28, 2009 | ViewSonic N3252w 32 in. LCD Television
Televison & Video Logo
849 people viewed this question
Top Televison & Video Experts
Electro Med Services...
